eduring Posted 11 hours ago Posted 11 hours ago (edited) Hi Armbian forum people! I'm trying to setup bcache for my openmediavault. But it seems the `bcache` module is not installed? Quote root@rpi5b:~# uname -a Linux rpi5b 6.18.10-current-bcm2711 #12 SMP PREEMPT Fri Feb 13 11:56:58 UTC 2026 aarch64 GNU/Linux root@rpi5b:~# modprobe bcache modprobe: FATAL: Module bcache not found in directory /lib/modules/6.18.10-current-bcm2711 Which means I cannot use `bcache` at the moment with openmediavault. I do know that the bcache has been added only recently: * https://github.com/armbian/build/pull/9550?ref=blog.armbian.com * "Enable BCACHE on Raspberry Pi build" But no go so far.. Is there anything I can do? Edited 9 hours ago by eduring 0 Quote
Werner Posted 55 minutes ago Posted 55 minutes ago Newer kernel packages may not have hit apt repo yet. Use the build framework to generate a set of kernel packages to be installed via dpkg -i by yourself: https://docs.armbian.com/Developer-Guide_Overview/ ./compile.sh BOARD=rpi4b BRANCH=current kernel 0 Quote
