Connecting Nokia 5510 LCD to OPi One: pin PA14 already requested by 1c28c00.serial; cannot claim for 1c69000.spi
Go to solution Solved by heltheowl,
I'm trying to connect Nokia 5110 / PCD8544 LCD to my Orange Pi One H3 (Board v1.1). This is my wiring:
Connection (LCD to OPi)
Nokia 5110 LCD pin Orange Pi One pin
GND GND
LIGHT GND
VCC 3.3v
CLK PC2 (CLK)
DIN PC0 (MOSI)
DC PA6
CE PC3 (CE)
RST PA9
This is my LCD:
image.png.0fd8b311e8f31013448acb6226e15eb0.pngimage.png.6515f6b254ad6789e491438a1c3ebd5a.png
The backlight is working upon turning on OPi One.
The official Orange Pi One H3 manual suggests using fbtft_device kernel module, which is LONG deprecated and no longer supported.
On Raspberry Pi forums, someone was suggested to use a Device Tree Overlay  instead.
I've stumbled upon an Orange Pi Zero overlay file for my LCD. So I've changed a few lines:
/dts-v1/;
/plugin/;
	compatible = "allwinner,sun8i-h3";
	fragment@0 {
		target = <&spi1>;
		__overlay__ {
			status = "okay";
			spidev@0{
				status = "disabled";
			spidev@1{
	fragment@1 {
		target = <&pio>;
		__overlay__ {
			opiz_display_pins: opiz_display_pins {
                pins = "PA9", "PA6";
                function = "gpio_out";
	fragment@2 {
		target = <&spi1>;
		__overlay__ {
			/* needed to avoid dtc warning */
			#address-cells = <1>;
			#size-cells = <0>;
			opizdisplay: opiz-display@0{
				compatible = "philips,pcd8544";
				reg = <0>;
				pinctrl-names = "default";
				pinctrl-0 = <&opiz_display_pins>;
				spi-max-frequency = <400000>;
				fps = <30>;
				buswidth = <8>;
				reset-gpios = <&pio 0 33 1>;
				dc-gpios = <&pio 0 7 0>;
And compiled, loaded it into an DTS user directory.
I've connected Arduino as a Serial-to-USB convertor to OPi and it would seem it has loaded successfully:
Applying user provided DT overlay nokia5110opizero.dtbo
4185 bytes read in 14 ms (291 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 45000000
Kernel image @ 0x42000000 [ 0x000000 - 0xa0ea90 ]
## Loading init Ramdisk from Legacy Image at 43400000 ...
   Image Name:   uInitrd
   Data Size:    17670074 Bytes = 16.9 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
Working FDT set to 43000000
   Loading Ramdisk to 48f26000, end 49ffffba ... OK
   Loading Device Tree to 48eb5000, end 48f25fff ... OK
Working FDT set to 48eb5000
But according to armbianmonitor -u output , the overlay ends up creating new errors:
[    1.630221] sun8i-h3-pinctrl 1c20800.pinctrl: pin PA14 already requested by 1c28c00.serial; cannot claim for 1c69000.spi
[    1.630250] sun8i-h3-pinctrl 1c20800.pinctrl: error -EINVAL: pin-14 (1c69000.spi)
[    1.630269] sun8i-h3-pinctrl 1c20800.pinctrl: error -EINVAL: could not request pin 14 (PA14) from group PA14 on device 1c20800.pinctrl
[    1.630288] sun6i-spi 1c69000.spi: Error applying setting, reverse things back
I know the overlay is for Zero series, but i figured it should be the same since H3 is mentioned in there. Or at least I would be glad to know how to modify this for my board.
Attached below are both logs for Serial and the kernel.
So far my goal is display anything, even a black square, on the screen. Would be sick to use it as a screen for console (like /dev/fb0).
Hoping for your help since I'm stuck. Thanks in advance!
dmesg.txt serial.txt
Edited by heltheowl
/dev/fb0 mention
For a start it looks like you are wiring to spi0 and so fragment0 does not make sense.  It also might be causing the pa14 pin problem as the op1 does not have an spi1.  Pin pa14 is used on a uart output.  I suggest you get rid of fragment0 and just use armbian-config to enable spi0.
Try this google AI search instead:
create overlay on armbian orangepione for Nokia 5110 / PCD8544 LCD
You might also need to add to armbianEnv.txt after enabling spi-spidev
root@orangepione:~# more /boot/armbianEnv.txt
verbosity=1
bootlogo=false
console=both
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
rootdev=UUID=f39623a3-f9cf-4fa1-be36-6854d244c378
rootfstype=ext4
overlays=spi-spidev
param_spidev_spi_bus=0
root@orangepione:~#
On successful startup of spi you should have a device:
root@orangepione:~# ls /dev/spidev0.0
/dev/spidev0.0
root@orangepione:~#
  • Solution
So.... This is what I've came to with Gemini:
/dts-v1/;
/plugin/;
    /* Target the SPI0 controller */
    fragment@0 {
        target = <&spi0>;
        __overlay__ {
            status = "okay";
            #size-cells = <0>;
            /* Disable default spidev to free the bus for the framebuffer */
            spidev@0 {
            /* PCD8544 LCD Node */
            pcd8544@0 {
                reg = <0>; /* Use SPI Chip Select 0 (PC3) */
                spi-max-frequency = <4000000>; /* Max SPI frequency for PCD8544 */
                buswidth = <8>;
                /* Data/Command (DC) Pin Mapping */
                /* PA6 -> Port A (0), Pin 6, Active High (0) */
                dc-gpios = <&pio 0 6 0>;
                /* Reset (RST) Pin Mapping */
                /* PA9 -> Port A (0), Pin 9, Active High (0) */
                reset-gpios = <&pio 0 9 0>;
                /* Rotate display if needed (e.g., 0, 90, 180, 270) */
                rotate = <0>;
I've got /dev/fb0 to show up this way. Except... It's not usable at all. Can't even print out the console. So there was no point to begin with.
What DOES work though, is a Python script using CircuitPython and Blinka:
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
This demo will fill the screen with white, draw a black box on top
and then print Hello World! in the center of the display
This example is for use on (Linux) computers that are using CPython with
Adafruit Blinka to support CircuitPython libraries. CircuitPython does
not support PIL/pillow (python imaging library)!
import board
import busio
import digitalio
from PIL import Image, ImageDraw, ImageFont
import adafruit_pcd8544
# Parameters to Change
BORDER = 5
FONTSIZE = 10
spi = busio.SPI(board.SCK, MOSI=board.MOSI)
dc = digitalio.DigitalInOut(board.PA6)  # data/command
cs = digitalio.DigitalInOut(board.PC3)  # Chip select
reset = digitalio.DigitalInOut(board.PA9)  # reset
display = adafruit_pcd8544.PCD8544(spi, dc, cs, reset)
# Contrast and Brightness Settings
display.bias = 4
display.contrast = 60
# Turn on the Backlight LED
#backlight = digitalio.DigitalInOut(board.D13)  # backlight
#backlight.switch_to_output()
#backlight.value = True
# Clear display.
display.fill(0)
display.show()
# Create blank image for drawing.
# Make sure to create image with mode '1' for 1-bit color.
image = Image.new("1", (display.width, display.height))
# Get drawing object to draw on image.
draw = ImageDraw.Draw(image)
# Draw a black background
draw.rectangle((0, 0, display.width, display.height), outline=255, fill=255)
# Draw a smaller inner rectangle
draw.rectangle(
    (BORDER, BORDER, display.width - BORDER - 1, display.height - BORDER - 1),
    outline=0,
    fill=0,
# Load a TTF font.
font = ImageFont.truetype("/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf", FONTSIZE)
# Draw Some Text
text = "It's working!"
#(font_width, font_height) = font.getsize(text)
left, top, right, bottom = font.getbbox(text)
font_width, font_height = right - left, bottom - top
draw.text(
    (display.width // 2 - font_width // 2, display.height // 2 - font_height // 2),
    text,
    font=font,
    fill=255,
# Display image
display.image(image)
display.show()
Unless /dev/fb0 on this things is even a little bit usable on the LCD, I guess I was running for circles because I was bored :)
I've deleted the overlay altogether since it's probably useless in this case. But I think someone else could benefit from me posting all this here, I don't know.
Either way, thank you for leading me along the way!
