Kodi on Orange Pi Win plus
pumuckl
Hello
I try to install Kodi on a Orange Pi Win plus,  but it stops with errors
http://kodi.wiki/view/HOW-TO:Install_Kodi_for_Linux
this commands are working
apt-get install software-properties-common
add-apt-repository ppa:team-xbmc/ppa
apt-get update
at this poit i have  Troubles
apt-get install kodi
root@orangepiwin:~# apt-get install kodi
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 kodi : Depends: kodi-x11 (< 2:18.0+git20180102.0202-3e7ef02-0xenial.1~) but it is not installable
        Depends: libshairplay0 but it is not installable
        Depends: libcec4 but it is not installable
E: Unable to correct problems, you have held broken packages.
i didnot find a soulution on google
i know the builds are not ready, but is ther a soulution
or what  can i to.
sry for my bad english
Link to comment
Share on other sites
Thanks for you answer.
I tried a lot the last days, and I noticed that the Armbian Ubuntu build is ready to use. So I downloaded it and installed it on sd.
And everything was working, so I tried to install kodi and it also worked.  In a quick test I noticed that the video quality is not very good.
I also installed vlc and the video quality was the same, also with mpv.
Even watching YouTube is just with 480p possible, above it is not not ok.
I found something about Hardware Accelerating, but I belief it’s already integrated in this apps.
Is there something I can to, to make it better?
Or is this the maximum of this cpu/gpu, what I can accept.
Greetings
Link to comment
Video acceleration works only with preinstalled mplayer as a demonstration and can be probably used as a player within KODI. But this is out of my interest area - never done it.
Youtube the same. There is some ytplayer which plays the stream on mplayer and again, it works accelerated.
Link to comment
I made many test and i found out that:
The preinstalled mpv player works, 720p with about 20% cpu usage. Even 1080p works as long as u don’t move the window.
The GTK Youtupe player works also.
It looks like kodi don’t support the Hardware Acceleration, with the same 720p file, the cpu usage gets to 80% and the playback is jerky.
Looks like Kodi use its one video player.
Found something about here:
https://forum.kodi.tv/showthread.php?tid=313544
Why the Acceleration works only with mpv?
The PVR add-ons are also not working, I can install it and activate it but they are not running and every restart of kodi I get a message to activate it.
I can live with that issues, or I use this board for some think different.
The Cpu in this board is powerful .
The Gpu is good enough for desktop, but compared with TV boxes its weak, should have checked this before buying.
Thank to all  for you work and  this operating system
Link to comment
Because it was built with a proper support. What you are asking is enough work for a serious project, not something that we could fix on a side.  OSMC, https://osmc.tv is a good example of this. It looks seemingly big project while their "single task" is to make KODI working on top of Debian base. It looks it runs smoothly, but only on Rpi, Vero and Apple.
At least not for KODI. Even H3 boards are better for this since we have a good working (older) version of Openelec.
Software support is making electronics useful. Remember that before buying some fancy TV box claiming super specs while running crappy Android without getting an update.
Link to comment
This for example?
It has the same gpu as the A64.
https://www.armbian.com/orange-pi-plus-2/
Known issues
Mainline kernel images (all boards) (next/dev branches)
No Mali drivers
No hardware accelerated video decoding
looks like the ASUS-Tinker-Board ist better.
link pls
greetings
thanks
Link to comment
