October 29Oct 29 I have two boxes that show 0 updates that have kernel updates enabled (ie. UPD001) but do not show any updates to get Linux aml-s9xx-box 6.18.57-current-meson64 v26.11 rolling for aml-s9xx-box running Armbian Linux 6.18.53-current-meson64 Packages: Debian stable (trixie) Support: for advanced users (rolling release) Linux aml-s9xx-box 6.18.53-current-meson64 v26.11 rolling for aml-s9xx-box running Armbian Linux 6.18.56-current-meson64 Packages: Debian stable (trixie) Support: for advanced users (rolling release) Linux aml-s9xx-box 6.18.56-current-meson64 tried sudo armbian-upgrade 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. tried sudo apt clean sudo rm -rf /var/lib/apt/lists/* sudo apt update sudo apt upgrade Edited October 29Oct 29 by perpetual more info added
October 30Oct 30 14 hours ago, perpetual said: but do not show any updates to get Linux aml-s9xx-box 6.18.57-current-meson64 Nighly builds sometimes breaks. Do you notice this like "now" or on longer period?
October 30Oct 30 Author @Igor thank you very much for your reply I totally understand community maintained nightly builds may break, and really appreciate the amlogic tv boxes still are very useful with armbian, saviour of hardware for sure! It must have been a recent change, let me know if you have any troubleshooting tips i forgot to capture the logs but when apt upgrading the Linux aml-s9xx-box 6.18.53-current-meson64 box i remember seeing "hash sum mismatch" for the kernel updates I've restored the 6.18.53 box with a microsd backup image created with gnome-disk-utility the restored box no longer gets the "hash sum mismatch" because the kernel updates do not get detected Edited October 30Oct 30 by perpetual
October 31Oct 31 I have an rk3588 based board running minimal Armian Debian 13 and it is on 6.18.53 and sees no updates and is using linux-image-current-rockchip64
October 31Oct 31 Author Found this - may have happened in the past https://github.com/armbian/build/issues/8261
November 1Nov 1 Author @Igor All fixed! the boxes are now getting the latest kernel / firmware updates againuname -aLinux <hostname> 6.18.53-current-meson64 #2 SMP PREEMPT Mon Sep 21 13:06:06 UTC 2026 aarch64 GNU/Linuxsudo apt list --upgradablearmbian-bsp-cli-aml-s9xx-box-current/trixie 26.11.0-trunk.118 arm64 [upgradable from: 26.11.0-trunk.57]armbian-config/unknown 26.8.0-trunk.426.1101.070345 all [upgradable from: 26.8.0-trunk.426.1028.173834]armbian-firmware/trixie,trixie 26.11.0-trunk.118 all [upgradable from: 26.11.0-trunk.57]base-files/trixie 26.11.0-trunk.118-13.8+deb13u7-trixie arm64 [upgradable from: 26.11.0-trunk.57-13.8+deb13u7-trixie]linux-dtb-current-meson64/trixie 26.11.0-trunk.118 arm64 [upgradable from: 26.11.0-trunk.57]linux-image-current-meson64/trixie 26.11.0-trunk.118 arm64 [upgradable from: 26.11.0-trunk.57]tzdata/stable-updates 2026f-0+deb13u1 all [upgradable from: 2026e-0+deb13u1]sudo apt upgradeoksudo rebootokLinux <hostname> 6.18.60-current-meson64 #1 SMP PREEMPT Fri Oct 30 12:06:41 UTC 2026 aarch64 GNU/Linux
November 1Nov 1 3 minutes ago, perpetual said:All fixed! the boxes are now getting the latest kernel / firmware updates againGood, a temprally issue then. Like I mentioned, our daily build can stay behind in case build fails. This will happen here and there.
