October 29Oct 29 Anyone here who switched to Canonical/Ubuntu maintained kernel? I use my odroid basically as a headless server so HDMI, video decoding etc. isn't important to me. Is it as simple as installing linux-image-generic or did you have to do a lot more?
November 2Nov 2 Small ARM boards generally don't have UEFI support, so can't just run a generic kernel.They're pretty dependent on board specific DTBs, which are often tied to certain kernels that are bleeding edge or heavily patched.I think the Armbian team would love to reduce the number of images maintained.But if you do get that working, definitely share. Edited November 2Nov 2 by tparys
November 2Nov 2 Indeed, even its not a problem having so many kernels. We designed whole Armbian project that this is not really a problem. Canonical lack such infrastructure.Closests generic approach is https://github.com/armbian/build/blob/main/config/boards/uefi-arm64-dt.conf which supports device tree and can run multiple boards with single image. I recently moved Nvidia Jetson Nano there with practically 100% hw support. And we could / will move other similar, namely Qcom and Cix based. With addition of recently developed service https://github.com/armbian/cve we will also provide kernels with uptodate security fixes for LTS kernels. There are no reasons to run Canonical kernels.
