Matt Talbot Posted January 26, 2018 Share Posted January 26, 2018 (edited) I have been trying to boot various images for a while. Recently I have tried the latest Armbian and Libreelec Images but without success. I have tried both usb and sd card. Today I managed to get my serial UART connected to the box to see where things are stopping. I have attached a log from the serial console. I have tried just about every single dtb I can find and I have removed the dtb for it to load from emmc, it still fails at the same step. I have waited over 15 mins and still nothing. Boot logo of the X92 is on the screen but nothing else. GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0; TE: 114034 BL2 Built : 16:42:36, Nov 3 2016. gxl g3eddb43 - xiaobo.gu@droid05 set vdd cpu_a to 1120 mv set vdd cpu_b to 1050 mv set vddee to 1000 mv Board ID = 3 CPU clk: 1200MHz DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0+1 @ 912MHz - PASS Rank0: 1024MB(auto)-2T-13 Rank1: 1024MB(auto)-2T-13 DataBus test pass! AddrBus test pass! -s Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x0000d600 Load bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00015400 Load bl33 from eMMC, src: 0x00038200, des: 0x01000000, size: 0x000a9a00 NOTICE: BL3-1: v1.0(debug):2e39a99 NOTICE: BL3-1: Built : 16:36:21, Sep 20 2016 aml log : bl31 normal boot ! [Image: gxl_v1.1.3154-065f772 2016-09-29 14:08:54 yan.wang@droid05] OPS=0x82 c0 37 bc bf 4e 8 1f 9e 49 24 b0 14 [0.361644 Inits done] secure task start! high task start! low task start! INFO: BL3-1: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader ERROR: Error initializing runtime service opteed_fast INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01-gd4b2965-dirty (Jan 07 2017 - 16:03:55) DRAM: 2 GiB Relocation Offset is: 76ec9000 register usb cfg[0][1] = 0000000077f5f578 vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters vpu: clk_level = 7 vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300) vpp: vpp_init boot_device_flag : 1 Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc. init bus_cycle=6, bus_timing=7, system=5.0ns reset failed get_chip_type and ret:fffffffe get_chip_type and ret:fffffffe chip detect failed and ret:fffffffe nandphy_init failed and ret=0xfffffff1 MMC: aml_priv->desc_buf = 0x0000000073ec96b0 aml_priv->desc_buf = 0x0000000073ecb9d0 SDIO Port B: 0, SDIO Port C: 1 emmc/sd response timeout, cmd8, status=0x3ff2800 emmc/sd response timeout, cmd55, status=0x3ff2800 [mmc_startup] mmc refix success [mmc_init] mmc init success mmc read lba=0x14000, blocks=0x400 Amlogic multi-dtb tool Multi dtb detected Multi dtb tool version: v2 . Support 3 dtbs. aml_dt soc: gxm platform: q201 variant: 2g dtb 0 soc: gxm plat: q201 vari: 1g dtb 1 soc: gxm plat: q201 vari: 2g dtb 2 soc: gxm plat: q201 vari: 3g Find match dtb: 1 start dts,buffer=0000000073ece270,dt_addr=0000000073ed9270 parts: 11 00: logo 0000000002000000 1 01: recovery 0000000002000000 1 02: rsv 0000000000800000 1 03: tee 0000000000800000 1 04: crypt 0000000002000000 1 05: misc 0000000002000000 1 06: instaboot 0000000020000000 1 07: boot 0000000002000000 1 08: system 0000000060000000 1 09: cache 0000000020000000 2 10: data ffffffffffffffff 4 get_dtb_struct: Get emmc dtb OK! overide_emmc_partition_table: overide cache [mmc_get_partition_table] skip partition cache. Partition table get from SPL is : name offset size flag =================================================================================== 0: bootloader 0 400000 0 1: reserved 2400000 4000000 0 2: cache 6c00000 20000000 2 3: env 27400000 800000 0 4: logo 28400000 2000000 1 5: recovery 2ac00000 2000000 1 6: rsv 2d400000 800000 1 7: tee 2e400000 800000 1 8: crypt 2f400000 2000000 1 9: misc 31c00000 2000000 1 10: instaboot 34400000 20000000 1 11: boot 54c00000 2000000 1 12: system 57400000 60000000 1 13: data b7c00000 2ec200000 4 mmc read lba=0x12000, blocks=0x2 mmc read lba=0x12002, blocks=0x2 mmc_read_partition_tbl: mmc read partition OK! eMMC/TSD partition table have been checked OK! mmc env offset: 0x27400000 In: serial Out: serial Err: serial reboot_mode=cold_boot hpd_state=1 [2160p30hz] is invalid for cvbs. set hdmitx VIC = 95 config HPLL = 2970 HPLL: 0xc000027b config HPLL done j = 6 vid_clk_div = 2 hdmitx phy setting done hdmitx: set enc for VIC: 95 rx version is 1.4 or below div=10 hdmtix: set audio [store]To run cmd[emmc dtb_read 0x1000000 0x40000] read emmc dtb Amlogic multi-dtb tool Multi dtb detected Multi dtb tool version: v2 . Support 3 dtbs. aml_dt soc: gxm platform: q201 variant: 2g dtb 0 soc: gxm plat: q201 vari: 1g dtb 1 soc: gxm plat: q201 vari: 2g dtb 2 soc: gxm plat: q201 vari: 3g Find match dtb: 1 Net: dwmac.c9410000 wipe_data=successful wipe_cache=successful upgrade_step=0 [OSD]load fb addr from dts [OSD]fb_addr for logo: 0x3d851000 [OSD]load fb addr from dts [OSD]fb_addr for logo: 0x3d851000 [CANVAS]canvas init [CANVAS]addr=0x3d851000 width=3840, height=2160 amlkey_init() enter! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 [KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet gpio: pin GPIOAO_2 (gpio 102) value is 1 get_cpu_id flag_12bit=1 get_cpu_id flag_12bit=1 saradc - saradc sub-system Usage: saradc saradc open <channel> - open a SARADC channel saradc close - close the SARADC saradc getval - get the value in current channel saradc get_in_range <min> <max> - return 0 if current value in the range of current channel InUsbBurn noSof Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 (Re)start USB... USB0: USB3.0 XHCI init start Register 3000140 NbrPorts 3 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Bad device usb 0 ** ** Bad device usb 1 ** ** Bad device usb 2 ** ** Bad device usb 3 ** card in [mmc_init] mmc init success Device: SDIO Port B Manufacturer ID: 3 OEM: 5344 Name: SL16G Tran Speed: 50000000 Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 14.8 GiB mmc clock: 40000000 Bus Width: 4-bit reading s905_autoscript 1641 bytes read in 5 ms (320.3 KiB/s) ## Executing script at 01020000 ** Bad device usb 0 ** ** Bad device usb 1 ** ** Bad device usb 2 ** ** Bad device usb 3 ** reading uInitrd 5175341 bytes read in 283 ms (17.4 MiB/s) reading zImage 16887960 bytes read in 919 ms (17.5 MiB/s) reading dtb.img ** Unable to read file dtb.img ** [store]To run cmd[emmc dtb_read 0x1000000 0x40000] read emmc dtb Amlogic multi-dtb tool Multi dtb detected Multi dtb tool version: v2 . Support 3 dtbs. aml_dt soc: gxm platform: q201 variant: 2g dtb 0 soc: gxm plat: q201 vari: 1g dtb 1 soc: gxm plat: q201 vari: 2g dtb 2 soc: gxm plat: q201 vari: 3g Find match dtb: 1 ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 5175277 Bytes = 4.9 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Amlogic multi-dtb tool Single dtb detected load dtb from 0x1000000 ...... ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 Loading Ramdisk to 739c7000, end 73eb67ed ... OK Loading Device Tree to 000000001fff2000, end 000000001ffff226 ... OK signature: fdt_instaboot: no instaboot image Starting kernel ... uboot time: 7276219 us domain-0 init dvfs: 4 domain-1 init dvfs: 4 Hopefully you can help me get further. Thanks Matt Edited January 26, 2018 by Matt Talbot Inserted too much log code from my uart Link to comment Share on other sites More sharing options...
balbes150 Posted January 26, 2018 Share Posted January 26, 2018 You need a version q201_2g 1 hour ago, Matt Talbot said: aml_dt soc: gxm platform: q201 variant: 2g Judging by the log , you don't have a file dtb.img in the root of the first partition (FAT). Add in the root the correct dtb (it means to copy from /dtb to the root of the file, and rename it to "dtb.img"). 1 hour ago, Matt Talbot said: reading dtb.img Unable to read file dtb.img Link to comment Share on other sites More sharing options...
Matt Talbot Posted January 26, 2018 Author Share Posted January 26, 2018 This was because I noticed it tried to load one from the emmc if it was missing. I will retry with the one you suggested and try again. Link to comment Share on other sites More sharing options...
Matt Talbot Posted January 27, 2018 Author Share Posted January 27, 2018 I can confirm using gxm_q201_2g.dtb and it boots fine. 1 Link to comment Share on other sites More sharing options...
Matt Talbot Posted January 27, 2018 Author Share Posted January 27, 2018 It boots fine to a console on my UART adapter but I dont have a desktop on the TV, Just pieces of text from the boot sequence tabbed across the screen. Do I need to set something else for the desktop to work? Im using the mate image named Armbian_5.37_S9xxx_Ubuntu_xenial_3.14.29_mate_20180116.img.xz Thanks again Matt Link to comment Share on other sites More sharing options...
Matt Talbot Posted January 27, 2018 Author Share Posted January 27, 2018 I tried the debian xfce version and the desktop starts after I do the setup procedure. On the mate one it doesnt. Link to comment Share on other sites More sharing options...
balbes150 Posted January 28, 2018 Share Posted January 28, 2018 17 hours ago, Matt Talbot said: Do I need to set something else for the desktop to work? Link to comment Share on other sites More sharing options...
Allwonder Posted August 19, 2018 Share Posted August 19, 2018 How to get X92 more fully working: I can use the image Armbian_5.44_S9xxx_Debian_stretch_4.18.0-rc5_xfce_20180806.img.xz quite fine with the X92 2G/16G box. However, you need to use the meson-gxm-vega-s96.dtb file instead of meson-gxm-q201.dtb (only change to q201 in s96 is activation of correct external gbit phy) to get Ethernet working. Also for working WiFi, download firmware-nonfree and place the files "brcmfmac43455-sdio.bin brcmfmac43455-sdio.clm_blob brcmfmac43455-sdio.txt" from the brcm directory into /lib/firmware/brcm on the rootfs partition of SD card. Bluetooth part currently not working. No front display support. Trying to build a complete matching dtb from original android os extracted dtb... Br, Allwonder Link to comment Share on other sites More sharing options...
hexdump Posted December 27, 2019 Share Posted December 27, 2019 @Matt Talbot - can you please explain or even better post a picture of where to find the serial port connector on the x92 box? a lot of thanks in advance and best wishes - hexdump update: ok - i have found the connection points, but they are very small and close to the heat sink - on the back side there are four more connections points close to the serial ones from the front - are they for the serial connection too maybe? if yes, they might be easier to solder i think ... any hints are welcome Link to comment Share on other sites More sharing options...
