Saturday at 12:03 PM5 days Hi again...Just a quick question...I've been having issues with WiFi on my orange pi 2w, and remembered that it had a separate antenna... Which isn't connected so need to find that...I came across a post somewhere saying armbian wasn't great at WiFi and was wondering firstly if it's still an issue, and secondly if it is can I use a usb adapter to connect?ThanksAlso.. anyone know what connector it uses to buy a replacement antenna if needed? No worries if not... ๐
Sunday at 06:15 AM4 days Solution 18 hours ago, PixRetro said:somewhere saying armbian wasn't great at WiFiWithout exaggeration, Armbian offers arguably the best Wi-Fi support among Linux distributions, particularly for the hardware we target.However, much of the hardware we deal with is super cheap. Cutting costs inevitably involves compromises, and low-cost components simply cannot be expected to deliver the same reliability and performance as first-class hardware. We regularly test Wi-Fi hardware and publish the results:https://docs.armbian.com/status/wifi-performance/When a driver is fundamentally broken and the hardware vendor doesn't maintain it properly, there is only so much we can do. Even with extensive use of AI agents to help investigate and fix issues, we cannot compensate for every hardware limitation or poorly maintained driver.https://github.com/armbian/uwe5622You are welcome to make it work better.
Sunday at 12:40 PM4 days Author Cool... I was hoping it was just a random moan from someone... The device isnt intended to be an always on internet type thing anyway so it probably is just down to the poor QC and lack of antenna... ๐I just need to stop being so ADHD and find out...I need to start making notes about things! I hope I didn't come across as moaning about armbian as it seems great... Just was curious... I didn't check the date on the post so it might even have been when support first started... Thanks again!
Monday at 03:38 AM3 days 14 hours ago, PixRetro said:it probably is just down to poor QCProbably worse - both This Wi-Fi hardware is poor, regardless of which Linux distribution you run. Perhaps less poor on Armbian as people have contributed patches to the driver we host, so I assume that at least some of the issues have been addressed.But expecting a smooth ride from a hardware that costs next to nothing is simply unrealistic. Especially when its support is the result of questionable business practices, no vendor involvement, fragmented market with different (cheap) chips and community-driven volunteer patching. Also AI agents can't fix the code just like that / automatically. They has to be driven by an experinced person.There are limits to what even the most dedicated open-source developers can do. And wireless network section is also one of the most technically complex one.And by the end of the day. Software cannot magically compensate for every hardware flaw.
Tuesday at 07:19 AM2 days Author I thought so... ๐คฃ๐คฃ๐คฃSeemed like a good idea at the time to get a zero sized board with 4GB ram... What a huge pain in the butt it is... ๐คฃ
