   I am trying to build a custom Armbian image and I would like to remove some deb packages in order to not to be installed. ¿What would be the right place to do that?
Thank you!!
is it possible to create a custom image with the "offical" compiled armbian packages. I looked in the tool chain, but I did not saw an option.
If I'm not missing something: I could add such option an send a PR, but only if there are chances, that this PR would be merged. So, is there some interest in it?
Background: I want to create some custom images with additional custom deb packages, but I see no need, to change all other packages.
Thanks,
Alex
I already read that. Adding addtional packages is perfectly working. But how to avoid compiling the armbian packages (kernel, u-boot, root, etc) and using the apt repo for that?
Thanks,
Alex
That is unfortunately not implemented but should not be a hard job, while we don't store userspace caches online - it is uploading/can be on to the server and later auto synchronized, while the rest we ATM do not have time to work on.
Since this might be generally useful and if you do it properly, I don't see a problem to accept PR? @zador.blood.stained
Yes, I saw how to add custom packages but not how to avoid some of them get installed during chroot creation...
Regards
Use apt purge method and remove them. This works out of the box, while default package list is not implemented as a user-defined variable.
Installing packages from the server will need at least some refactoring and pulling userspace cache from the server (and syncing/uploading it there, selecting whether to download or build it from scratch based on packages selection, etc.) will need noticeable refactoring and testing, I'm not sure if we need to implement this.
