Orange Pi Lite - Debian Stretch next - g_serial/g_ether does not work
I am trying to use g_serial but it does not work.
I'm using fresh install of armbian (Armbian_5.38_Orangepilite_Debian_stretch_next_4.14.14.7z),
with apt-get update/apt-get upgrade/armbianconfig Install headers.
Linux orangepilite 4.14.15-sunxi #28 SMP Mon Jan 29 07:24:48 CET 2018 armv7l GNU/Linux
This is the overlay I use to enable OTG:
sudo /usr/sbin/armbian-add-overlay usbotg.dts
/dts-v1/;
/plugin/;
  compatible = "allwinner,sun8i-h3";
  fragment@0 {
    target = <&usb_otg>;
    __overlay__ {
      dr_mode = "otg";
      status = "okay";
After rebooting OPi there are several errors like this in syslog
musb_g_ep0_irq 712: SetupEnd came in a wrong ep0stage out/status
The other computer is running Ubuntu 16.04 LTS
I use small USB hub (full speed only) between my PC and OPi lite but if I make direct connection the errors are same.
If I unplug and plug USB cable between OrangePi Lite and my computer (or if I plug the cable after OPi boots) I get same errors.
I got same errors when trying with .g_ether
usb 7-2.1: new full-speed USB device number 4 using uhci_hcd
usb 7-2.1: device descriptor read/64, error -71
usb 7-2.1: new full-speed USB device number 5 using uhci_hcd
usb 7-2.1: new full-speed USB device number 6 using uhci_hcd
usb 7-2.1: device not accepting address 6, error -71
usb 7-2.1: new full-speed USB device number 7 using uhci_hcd
usb 7-2.1: device not accepting address 7, error -71
usb 7-2-port1: unable to enumerate USB device
The result of sudo armbianmonitor -u is here http://ix.io/Fcb
Regards
I have same issue (Armbian 5.65, fresh install). Did you sovle this problem? Does anyone have working OTG on Orange Pi Lite?
49 minutes ago, Igor Martsekha said:
image which built from this repo
Use it.
In case you want this function in a quality OS with mainline kernel ... here you can see some overview how the process of mainlining looks like:
https://elinux.org/images/d/dc/Petazzoni-soc-mainlining-lessons-learned.pdf
Mainlining is expensive and long process of porting board support from a static development kernel to the mainstream. Not all boards get there and very rare with all functions.
A bit more concrete information - for Allwiner devices, what works, what not:
https://linux-sunxi.org/Linux_mainlining_effort
... while bugs in the implementation are not there.
