K1ngH0st Posted February 4, 2018 Posted February 4, 2018 Hi you all, I have flashed a good, tested and reliable 32GB SD card with the last build for Orange PI Win (armbian 5.38) and when first updating, it stucks in "waiting for headers" for too long. I have read that this is caused in Linux systems because one installs third party software whose repos take long to answer, but since here it is a first and fresh update, with nothing but armbian inside, I ask myself if it is normal or there is a problem with the servers at this moment. Only apt-get update ca take up to 1h 30 min, so it is really an annoying issue. Is anyone out there experiencing the same problem (and hopefully with a solution) ?? Thank you guys!!!
Igor Posted February 4, 2018 Posted February 4, 2018 Probably headers install script patch is not the correct one. It needs to be investigated closely. We don't provide headers package by default since some time and if they are default enabled, this is by mistake. If you don't need them, remove them and update should go with a normal speed.
