xefil Posted February 9, 2018 Posted February 9, 2018 Hello to all! I'm using Armbian on my BananaPi board. I've the following version: ARMBIAN 5.38 stable Debian GNU/Linux 9 (stretch) 4.14.15-sunxi BOARD=bananapi BOARD_NAME="Banana Pi" VERSION=5.35 LINUXFAMILY=sunxi BRANCH=next ARCH=arm IMAGE_TYPE=user-built BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=zImage I need to follow these instructions to wire a radio on the board: https://www.mysensors.org/build/orange But I cannot find the script.bin file. Why? I can remember the file was here on old releases. Any help or suggestion? Thanks, Simon
xefil Posted February 13, 2018 Author Posted February 13, 2018 Hello, Sorry but nobody can give me some hints? Thanks, Simon
Igor Posted February 13, 2018 Posted February 13, 2018 5 hours ago, xefil said: Hello, Sorry but nobody can give me some hints? Thanks, Simon Reading documentation? https://docs.armbian.com/User-Guide_Allwinner_overlays/
xefil Posted February 14, 2018 Author Posted February 14, 2018 13 hours ago, Igor said: Reading documentation? https://docs.armbian.com/User-Guide_Allwinner_overlays/ Good morning, That's a great point to start with, and as always, first rule, RTFM, you're absolutely right. I've started reading it and it's a little complicated. The part that I think it's referred on what I need is: Quote ### spi0 Activates SPI controller 0 to use it with other overlays and sets up the pin multiplexing for it SPI 0 pins (MOSI, MISO, SCK, CS0, CS1): PI12, PI13, PI11, PI10, PI14 ### spi1 Activates SPI controller 1 to use it with other overlays and sets up the pin multiplexing for it SPI 1 pins (MOSI, MISO, SCK, CS0): PI18, PI19, PI17, PI16 ### spi2 Activates SPI controller 2 to use it with other overlays and sets up the pin multiplexing for it SPI 2 pins a (MOSI, MISO, SCK, CS0): PC21, PC22, PC20, PC19 SPI 2 pins b (MOSI, MISO, SCK, CS0): PB16, PB17, PB15, PB14 Parameters: param_spi2_bus_pins (char) SPI bus 2 pinmux variant Optional Default: a Supported values: a, b Determines what pins SPI bus 2 is exposed on if SPI 2 is used ### spi-add-cs1 Activates SPI chip select 1 on SPI controller 0 This overlay is required for using chip select 1 with other SPI overlays SPI 0 CS1 pin: PI14 ### spi-jedec-nor Activates MTD support for JEDEC compatible SPI NOR flash chips on SPI bus supported by the kernel SPI NOR driver SPI 0 pins (MOSI, MISO, SCK, CS0, CS1): PI12, PI13, PI11, PI10, PI14 SPI 1 pins (MOSI, MISO, SCK, CS0): PI18, PI19, PI17, PI16 SPI 2 pins a (MOSI, MISO, SCK, CS0): PC21, PC22, PC20, PC19 SPI 2 pins b (MOSI, MISO, SCK, CS0): PB16, PB17, PB15, PB14 Parameters: param_spinor_spi_bus (int) SPI bus to activate SPI NOR flash support on Required Supported values: 0, 1, 2 param_spinor_spi_cs (int) SPI chip select number for SPI NOR connected to SPI bus 0 Optional Default: 0 Supported values: 0, 1 Using chip select 1 on SPI 0 requires using "spi-add-cs1" overlay param_spinor_max_freq (int) Maximum SPI frequency Optional Default: 1000000 Range: 3000 - 100000000 ### spi-spidev Activates SPIdev device node (/dev/spidevX.Y) for userspace SPI access, where X is the bus number and Y is the CS number SPI 0 pins (MOSI, MISO, SCK, CS0, CS1): PI12, PI13, PI11, PI10, PI14 SPI 1 pins (MOSI, MISO, SCK, CS0): PI18, PI19, PI17, PI16 SPI 2 pins a (MOSI, MISO, SCK, CS0): PC21, PC22, PC20, PC19 SPI 2 pins b (MOSI, MISO, SCK, CS0): PB16, PB17, PB15, PB14 Parameters: param_spidev_spi_bus (int) SPI bus to activate mcp2515 support on Required Supported values: 0, 1, 2 param_spidev_spi_cs (int) SPI chip select number for SPIdev on SPI bus 0 Optional Default: 0 Supported values: 0, 1 Using chip select 1 on SPI 0 requires using "spi-add-cs1" overlay param_spidev_max_freq (int) Maximum SPIdev frequency Optional Default: 1000000 Range: 3000 - 100000000 Due I'll need to connect on this board two radio (one NRF24L01+ and one RFM69), I fear to make some damages, so I ask here. I would start with one radio first, the RFM69. But here comes the first question it's not totally clear for me: 1. Is the BananaPi able to have two radio connected on the GPIO? Seems yes if the above doc speeks about SPI 0 - 1 - 2 all with required MOSI, MISO, SCK, CS.... But I've read somewhere for RPi the following: Quote Adding /dev/spidev1.0 is required since /dev/spidev0.0 is used for the onboard NAND flash 2. I'ts valid for BananaPi as well? BTW then, let's start with the first radio assuming I can start with bus0. The overlay should look like: overlays=spi-spidev param_spidev_spi_bus=0 That should create a "/dev/spidev***" device. This should give me those connections GPIO available: MOSI: PI12 -> CON3-PORT19 MISO: PI13 -> CON3-PORT21 SCK: PI11 -> CON3-PORT23 CS: PI10 -> CON3-PORT24 Then I'm missing the power 3.3v (CON3-PORT01), ground (CON3-PORT06) and IRQ, which should be ok any normal PIN (i.e. CON3-PORT22). Until here makes it sense?? Sorry, but as written above I fear I could make some mistrakes and damage the devices. Assuming the above works, how can then I add a second spidev? This is something I cannot understand from the documentation. Many thanks, Simon
vlad59 Posted February 14, 2018 Posted February 14, 2018 The banana pi only has 1 SPI Unless I'm mistaken. I used SPI some time ago and IIRC simply adding spi-spidev to the overlay did the trick. The Banana pi has no Nand. Hope this helps
xefil Posted February 14, 2018 Author Posted February 14, 2018 4 hours ago, vlad59 said: The banana pi only has 1 SPI Unless I'm mistaken. I used SPI some time ago and IIRC simply adding spi-spidev to the overlay did the trick. The Banana pi has no Nand. Hope this helps THANKS! I'll give it a try and let you know Simon
