I'mTO1 Posted February 20, 2018 Share Posted February 20, 2018 Hi I want to install some packages, but it not found on sources. When i do update repositories by sudo apt update command, the following messages shown that means the repositories is broken. Err:1 http://httpredir.debian.org/debian stretch InRelease Could not resolve 'httpredir.debian.org' Err:2 http://httpredir.debian.org/debian stretch-updates InRelease Could not resolve 'httpredir.debian.org' Err:3 http://httpredir.debian.org/debian stretch-backports InRelease Could not resolve 'httpredir.debian.org' Err:4 http://security.debian.org stretch/updates InRelease Could not resolve 'security.debian.org' Err:5 http://apt.armbian.com stretch InRelease Could not resolve 'apt.armbian.com' Reading package lists... Done Building dependency tree Reading state information... Done 3 packages can be upgraded. Run 'apt list --upgradable' to see them. W: Failed to fetch http://httpredir.debian.org/debian/dists/stretch/InRelease Could not resolve 'httpredir.debian.org' W: Failed to fetch http://httpredir.debian.org/debian/dists/stretch-updates/InRelease Could not resolve 'httpredir.debian.org' W: Failed to fetch http://httpredir.debian.org/debian/dists/stretch-backports/InRelease Could not resolve 'httpredir.debian.org' W: Failed to fetch http://security.debian.org/dists/stretch/updates/InRelease Could not resolve 'security.debian.org' W: Failed to fetch http://apt.armbian.com/dists/stretch/InRelease Could not resolve 'apt.armbian.com' W: Some index files failed to download. They have been ignored, or old ones used instead. Also i tried sudo apt update --fix-missing and sudo aptitude update or sudo apt-get update but nothing changed. I'm using Armbian_5.38_Cubietruck_Debian_stretch_next_4.14.14 How can i fix this? Is there a new source list to replace? Thanks. Link to comment Share on other sites More sharing options...
Igor Posted February 20, 2018 Share Posted February 20, 2018 Problem is DNS related. If you are getting IP via DHPC server, which is default, this is what you need to do: rm /etc/network/interfaces reboot Link to comment Share on other sites More sharing options...
I'mTO1 Posted February 20, 2018 Author Share Posted February 20, 2018 1 minute ago, Igor said: Problem is DNS related. If you are getting IP via DHPC server, which is default, this is what you need to do: rm /etc/network/interfaces reboot I'm using static IP, but my internet connection is shared true another Ethernet connection that gets IP from DHCP server. is it works for my situation? Link to comment Share on other sites More sharing options...
Igor Posted February 20, 2018 Share Posted February 20, 2018 Don't know. This error indicates that something is wrong with your network, most likely DNS settings. Unrelated to Allwinner A20 or Armbian. Link to comment Share on other sites More sharing options...
I'mTO1 Posted February 20, 2018 Author Share Posted February 20, 2018 16 minutes ago, Igor said: Don't know. This error indicates that something is wrong with your network, most likely DNS settings. Unrelated to Allwinner A20 or Armbian. Thanks a lot! Link to comment Share on other sites More sharing options...
I'mTO1 Posted February 20, 2018 Author Share Posted February 20, 2018 @Igor True, the problem was related to DNS. I've fixed it by adding DNS nameservers as follow: $ sudo vi /etc/resolv.conf Modify or enter nameserver as follows: nameserver 8.8.8.8 nameserver 4.2.2.4 Thank you once again! 1 Link to comment Share on other sites More sharing options...
