Eddy_T Posted February 21, 2018 Posted February 21, 2018 Hello to all; These are VERY exciting days for me as I installed ARMBIAN 5.37 on my s-805 MXQ box and its running beautiful! Thanks for all that made it happen. There is but one issue where I need some help: Running ARMBIAN 5.37 user-built Ubuntu 16.04.3 LTS 3.10.99, the system is unable to find my wifi adapter. Any help in how to fix this would be greatly appreciated. Eddy_T, Calgary, Alberta, Canada
balbes150 Posted February 21, 2018 Posted February 21, 2018 Have you downloaded the WiFi module ? Command from root "modprobe dhd" or " modprobe wifi_dummy".
thanh_tan Posted November 27, 2018 Posted November 27, 2018 On 2/21/2018 at 1:30 PM, balbes150 said: Have you downloaded the WiFi module ? Command from root "modprobe dhd" or " modprobe wifi_dummy". Hi, I tried to run "modprobe dhd" or " modprobe wifi_dummy" but not work Where i can download the WIFI module? 1
Danx Posted January 5, 2020 Posted January 5, 2020 On 11/27/2018 at 3:56 PM, thanh_tan said: Hi, I tried to run "modprobe dhd" or " modprobe wifi_dummy" but not work Where i can download the WIFI module? I am using a mxq black with s805 chip on it. The dtb has its name, so the installation works smoothly, on Sd card. Now... Here is mine workaround. After looking at other boxes forum. Ps..: I just try them out, and the results come. to get wifi working, running those command that balbes mentioned earlier. Then, here is trial and false phase. Typically, drivers exist in mine folder named 3.10.108 (run “sudo mobprobe abc” to find your exact directory) use any file manager, go there, search for folders with name “wifi” then, type “sudo mobprobe [driver-name]” without the “ . ko “ Just try until you see in the network icon gui, the’ wifi network’ appears with some AP( if you dont see any AP names , then try other drivers) . Check to tick “enable wifi” in the right click menu of the network icon, if no wifi names is shown. Get it up and running. ———— if you want to do this without manually re load the wifi module every next boot, you may put that line in the /boot/ hdmi.sh file. Good luck to there all.
