             Hello guys.
I try to configure AP on WiFi.
I have created /etc/hostapd/hostapd.conf:
interface=wlan0
driver=nl80211
country_code=IN
ssid=TEST
hw_mode=g
channel=6
wpa=2
wpa_passphrase=12345678
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
macaddr_acl=0
Then I have uncommented DAEMON_CONF="/etc/hostapd/hostapd.conf"
in /etc/default/hostapd.
After it, I run /etc/init.d/hostapd restart
And I try to scan WiFi via mobile phone, and no TEST.
What am I doing wrong?
You need to tell Network manager that you will use this adaptor. Did you try the armbian-config way?
9 minutes ago, Dmitriy Zhuk said:
Could you please explain me this way?
How do you mean explain? How it is made or how to run it?
Thank you.
But, for some reasons, I use older version of Armbian (5.33) for my BananaPi M2+.
And, in menu Wired Wireless Bluetooth Hotspot only 3 items:
IP
Clear
Advanced
And it is no Hotspot item.
How can I make AP via hostapd?
1
You can try with "clear", then go up and go once again into networking. You should have a menu for this but since you already made changes to configurations, this method might not work. It is not that resilient. I would still recommend you to go with the latest build or study the whole thing in deep. The main problem in a manual method is to add wlan0 to /etc/NetworkManager/conf.d/10-ignore-interfaces.conf and restart Network manager ... this way hostapd gets access to this wireless adaptor in first place. I think this is the main problem you are facing. Second is correct hostapd configuration.
My folder /etc/NetworkManager/conf.d is empty.
I have attached my hostapd.conf
I run hostapd -dd /etc/hostapd.conf
There is my output:
root@bananapim2plus:~# hostapd -dd /etc/hostapd.conf
random: Trying to read entropy from /dev/random
Configuration file: /etc/hostapd.conf
ctrl_interface_group=0
nl80211: Could not add multicast membership for vendor events: -2 (No such file or directory)
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-0f-ac:6
nl80211: Using driver-based off-channel TX
nl80211: TDLS supported
nl80211: Use separate P2P group interface (driver advertised support)
nl80211: Enable multi-channel concurrent (driver advertised support)
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 3 iftype 3 (AP)
nl80211: Setup AP(wlan0) - device_ap_sme=1 use_monitor=0
nl80211: Subscribe to mgmt frames with AP handle 0xb70891e8 (device SME)
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb70891e8 match=04
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb70891e8 match=0501
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb70891e8 match=0504
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb70891e8 match=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb70891e8 match=08
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb70891e8 match=09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb70891e8 match=0a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb70891e8 match=11
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xb70891e8 match=7f
nl80211: Enable Probe Request reporting nl_preq=0xb7088cc0
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0xb7088cc0 match=
rfkill: initial event: idx=1 type=1 op=0 soft=0 hard=0
nl80211: Could not re-add multicast membership for vendor events: -2 (No such file or directory)
nl80211: Add own interface ifindex 3 (ifidx_reason -1)
nl80211: if_indices[16]: 3(-1)
nl80211: Add own interface ifindex 7 (ifidx_reason 3)
nl80211: if_indices[16]: 3(-1) 7(3)
nl80211: Adding interface wlan0 into bridge br0
phy: phy0
BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Previous country code 00, new country code UA
Continue interface setup after channel list update
ctrl_iface not configured!
random: Got 20/20 bytes from /dev/random
RTM_NEWLINK: ifi_index=7 ifname=br0 operstate=2 linkmode=0 ifi_family=0 ifi_flags=0x1002 ()
nl80211: Interface down (br0/br0)
nl80211: Not the main interface (wlan0) - do not indicate interface down
wlan0: Event INTERFACE_STATUS (5) received
Unknown event 5
Unknown event 5
RTM_NEWLINK: ifi_index=3 ifname=wlan0 master=7 operstate=6 ifi_family=7 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
nl80211: Add ifindex 7 for bridge br0
nl80211: ifindex 7 already in the list
Unknown event 5
RTM_NEWLINK: ifi_index=7 ifname=br0 operstate=2 linkmode=0 ifi_family=0 ifi_flags=0x11003 ([UP][LOWER_UP])
Unknown event 5
RTM_NEWLINK: ifi_index=7 ifname=br0 operstate=6 linkmode=0 ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
Unknown event 5
Channel list update timeout - try to continue anyway
nl80211: Regulatory information - country=00
nl80211: 2402-2472 @ 40 MHz 20 mBm
nl80211: 2457-2482 @ 40 MHz 20 mBm (no IR)
nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
nl80211: 5170-5250 @ 40 MHz 20 mBm (no IR)
nl80211: 5735-5835 @ 40 MHz 20 mBm (no IR)
nl80211: Added 802.11b mode based on 802.11g information
Allowed channel: mode=1 chan=1 freq=2412 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=2 freq=2417 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=3 freq=2422 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=4 freq=2427 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=5 freq=2432 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=6 freq=2437 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=7 freq=2442 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=8 freq=2447 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=9 freq=2452 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=10 freq=2457 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=11 freq=2462 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=12 freq=2467 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=13 freq=2472 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=1 freq=2412 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=2 freq=2417 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=3 freq=2422 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=4 freq=2427 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=5 freq=2432 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=6 freq=2437 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=7 freq=2442 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=8 freq=2447 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=9 freq=2452 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=10 freq=2457 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=11 freq=2462 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=12 freq=2467 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=13 freq=2472 MHz max_tx_power=20 dBm
hw vht capab: 0x0, conf vht capab: 0x0
Completing interface initialization
Mode: IEEE 802.11g  Channel: 5  Frequency: 2432 MHz
DFS 0 channels required radar detection
nl80211: Set freq 2432 (ht_enabled=1, vht_enabled=0, bandwidth=20 MHz, cf1=2432 MHz, cf2=0 MHz)
  * freq=2432
  * vht_enabled=0
  * ht_enabled=1
  * sec_channel_offset=0
  * channel_type=1
RATE[0] rate=10 flags=0x1
RATE[1] rate=20 flags=0x1
RATE[2] rate=55 flags=0x1
RATE[3] rate=110 flags=0x1
RATE[4] rate=60 flags=0x0
RATE[5] rate=90 flags=0x0
RATE[6] rate=120 flags=0x0
RATE[7] rate=180 flags=0x0
RATE[8] rate=240 flags=0x0
RATE[9] rate=360 flags=0x0
RATE[10] rate=480 flags=0x0
RATE[11] rate=540 flags=0x0
hostapd_setup_bss(hapd=0xb70885d8 (wlan0), first=1)
wlan0: Flushing old station entries
nl80211: flush -> DEL_STATION wlan0 (all)
wlan0: Deauthenticate all stations
nl80211: sta_remove -> DEL_STATION wlan0 ff:ff:ff:ff:ff:ff --> 0 (Success)
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
Using interface wlan0 with hwaddr b0:f1:ec:0d:23:d6 and ssid "ARMBIAN"
Deriving WPA PSK based on passphrase
SSID - hexdump_ascii(len=7):
     41 52 4d 42 49 41 4e                              ARMBIAN
PSK (ASCII passphrase) - hexdump_ascii(len=8): [REMOVED]
PSK (from passphrase) - hexdump(len=32): [REMOVED]
Get randomness: len=32 entropy=0
GMK - hexdump(len=32): [REMOVED]
Key Counter - hexdump(len=32): [REMOVED]
WPA: Delay group state machine start until Beacon frames have been configured
nl80211: Set beacon (beacon_set=0)
nl80211: Beacon head - hexdump(len=58): 80 00 00 00 ff ff ff ff ff ff b0 f1 ec 0d 23 d6 b0 f1 ec 0d 23 d6 00 00 00 00 00 00 00 00 00 00 64 00 31 04 00 07 41 52 4d 42 49 41 4e 01 08 82 84 8b 96 0c 12 18 24 03 01 05
nl80211: Beacon tail - hexdump(len=117): 07 06 55 41 20 01 0d 14 2a 01 00 32 04 30 48 60 6c 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 0c 00 2d 1a 0c 00 1f ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3d 16 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 dd 18 00 50 f2 02 01 01 00 00 03 a4 00 00 27 a4 00 00 42 43 5e 00 62 32 2f 00
nl80211: ifindex=3
nl80211: beacon_int=100
nl80211: dtim_period=2
nl80211: ssid - hexdump_ascii(len=7):
  * beacon_int=100
  * dtim_period=2
nl80211: hidden SSID not in use
nl80211: privacy=1
nl80211: auth_algs=0x1
nl80211: wpa_version=0x2
nl80211: key_mgmt_suites=0x2
nl80211: pairwise_ciphers=0x10
nl80211: group_cipher=0x10
nl80211: SMPS mode - off
WPA: Start group state machine to set initial keys
WPA: group state machine entering state GTK_INIT (VLAN-ID 0)
Get randomness: len=16 entropy=0
GTK - hexdump(len=16): [REMOVED]
WPA: group state machine entering state SETKEYSDONE (VLAN-ID 0)
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=3 addr=0xb6f453a4 key_idx=1 set_tx=1 seq_len=0 key_len=16
nl80211: KEY_DATA - hexdump(len=16): [REMOVED]
   broadcast key
nl80211: Set wlan0 operstate 0->1 (UP)
netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=6 (IF_OPER_UP)
Failed to set TX queue parameters for queue 0.
Failed to set TX queue parameters for queue 1.
Failed to set TX queue parameters for queue 2.
Failed to set TX queue parameters for queue 3.
wlan0: interface state COUNTRY_UPDATE->ENABLED
wlan0: AP-ENABLED
wlan0: Setup of interface done.
Maybe this additional information can help...
hostapd.conf
Edited by Igor
add spoiler
3 hours ago, Igor said:
You are wasting time ... until you don't tell Network manager to give you access to the device. This step is important.
https://askubuntu.com/questions/21914/how-can-i-make-networkmanager-ignore-my-wireless-card
Do you mean, I need add
[keyfile] unmanaged-devices=mac:00:19:e0:57:86:af
to file /etc/NetworkManager/NetworkManager.conf?
By the way, without telling Network manager, I can to connect to WiFi modem via wpa_supplicant. Is it OK?
I have created file /etc/NetworkManager/conf.d/10-ignore-interfaces.conf
with
echo "[keyfile]" > /etc/NetworkManager/conf.d/10-ignore-interfaces.conf
echo "unmanaged-devices=interface-name:wlx0013ef6c46e3" >> /etc/NetworkManager/conf.d/10-ignore-interfaces.conf
service network-manager restart
I run hostapd -dd /etc/hostapd.conf and also no AP
I almost forgot this. With legacy kernel you need to load module (dhd, ap6211 or ap6212) with op_mode=2 while on mainline kernel this is not needed.
Igor, thank you for this hint.
I have the small success.
I have done
rmmod dhd
modprobe dhd op_mode=2
After it, I can scan and see my SSID via mobile phone.
But, when I trying to connect to it, my phone can't obtain IP address.
Do I have error on my hostapd.conf?
Or do I need other actions for successful connecting?
Since you don't know how to setup thing it is better to use armbian-config way. It does everything ... except switching this mode.
In case you want to do it manually, use google. There are tons of manuals around. You need to setup DHCP server or put network into bridge mode which will make use of your current DHCP server ...
And I have the second question.
When I run hostapd as daemon in background (hostapd -B /etc/hostapd.conf), how can I stop the hostapd?
The one way (I think wrong way) I can ps -ef | grep hostapd and then hill the precess.
These methods don't work:
root@bananapim2plus:~# ps -ef | grep hostapd
root      1061     1  0 23:55 ?        00:00:00 hostapd -B /etc/hostapd.conf
root      1148   948  0 23:57 pts/0    00:00:00 grep hostapd
root@bananapim2plus:~# systemctl stop hostapd
root      1154   948  0 23:57 pts/0    00:00:00 grep hostapd
root@bananapim2plus:~# service hostapd stop
root      1172   948  0 23:58 pts/0    00:00:00 grep hostapd
