I'm newbie on freescale imx6. I've just bought a hummingBoard2 rev1.4. A modem SIMCOM7600E mcpie is attached.
When I used ignition and install debian, it's works but I 've a problem with the driver of this modem, the WWAN is not configured. ATCOMMAND works fine but I would like to use it by wwan interface and I didn't know how to put the driver file.c!
I decided to install armbian_5.38 debian or ubuntu but my hummingboard doesn't boot. The autoboot stop at ##Flattend Device Tree blob at 18000000
Booting using the fdt blob at 0x18000000
after this I had "No signal" on my HDMI screen.
I use a µSDHC1 Transcend 8Go. She is erased by SDFORMATTER and I use win32diskimager for the.img.
How can I do for my H2 works fine?
Thanks in advance.
5 hours ago, Nicolas95 said:
SDHC1 Transcend 8Go
did you test the card before usage with h2testw?
replace it with etcher as recommended in the 'getting started'.
Buy a reliable SD card and follow the recommendations... ;) I guess (and that's just a guess), this card is slow as hell and therefore it struggles...
Hi, thanks for your replies!
I used this SD (an another same one) for ignition with debian, they work properly.
I tested with Etcher same problem!
I used this transcend ultimate 600x U1 for another application, and she works good!
I don't have the a Hummingboard 2, but I think the image should at least boot.  So something with your setup fulfills not the needs for proper booting... Main issues are bad powering or bad SD-Card (counterfeit or to slow)..  So test it with h2testw and ind case this doesn't show any errors replace it with a known good one..
Hi Igor
Thank you for your reply!
I'm newbie in linux debian CLI...:unsure:
I've just install debian jessie from ignition, but i ddin't find fdt_file
