carlosalberto4ti Posted March 30, 2018 Posted March 30, 2018 (edited) Hi , how a start use armbian with banana pi zero h2+ ? For frist i need compile kernel ? Have one article for help with more information ? I need use xfce with rdp desktop, is possible use ? Thanks all help - brasil - pt-br PS : this board : http://www.banana-pi.org/bpi-zero.html Edited March 30, 2018 by carlosalberto4ti
carlosalberto4ti Posted March 30, 2018 Author Posted March 30, 2018 @chwe , thanks for move my post . I understand , i need compile using toolchain . Exist one tutorial complete for this hardware ? (step-by-step)
Igor Posted March 30, 2018 Posted March 30, 2018 On 3/30/2018 at 2:45 AM, carlosalberto4ti said: Exist one tutorial complete for this hardware ? Expand All boards compile the same way: https://docs.armbian.com/Developer-Guide_Build-Preparation/ For this one, you need to use additional parameter EXPERT="yes" to see those which are not supported/untested. The building might work or not. If not, you are on your own to fix the configuration. Our resources are underpowered to take care for all boards that are out there
carlosalberto4ti Posted March 31, 2018 Author Posted March 31, 2018 On 3/30/2018 at 5:31 AM, Igor said: All boards compile the same way: https://docs.armbian.com/Developer-Guide_Build-Preparation/ For this one, you need to use additional parameter EXPERT="yes" to see those which are not supported/untested. The building might work or not. If not, you are on your own to fix the configuration. Our resources are underpowered to take care for all boards that are out there Expand thanks your information .
carlosalberto4ti Posted March 31, 2018 Author Posted March 31, 2018 One think , i found this image (above) finished (?) on forum banana pi, is possible extract from this image more information to fix problems on script builder ? Or is possible use this image as one way to create one procedure 100% correct to compile armbian ? http://forum.banana-pi.org/t/bpi-m2-zero-new-image-2017-12-04-armbian-5-36-m2-zero-ubuntu-xenial-next-4-14-3-desktop-preview-buildbybpi/4325 http://forum.banana-pi.org/t/bpi-m2-zero-new-image-ubuntu-16-04-mate-desktop-preview-bpi-m2z-sd-emmc-img-2017-09-19/3871 Thanks all
chwe Posted April 1, 2018 Posted April 1, 2018 if you read carefully the two threads I liked.. especially this one: you should be able to build an image for the bpi..
