I have a BPI-M2 and I am trying to patch kernel 4.4.1 with contents of archive
patches-4.4.1-rt6.tar.gz
for RT-Preempt while making Debian Wheezy xfce desktop image.
I have tried putting patches in
/userpatches/kernel/sunxi-dev
and
/userpatches/kernel/sunxi-dev/linux-vanilla/v4.4.1
nether worked. Made image but patches were not applied
Any help would be appreciated
Tim
Kernel 4.4.1 is "next" branch, not "dev".
Patching process displays what directory is used for user patches:
[ o.k. ] Started patching process for [ kernel sunxi-next 4.4.1 ]
[ o.k. ] Looking for user patches in [ userpatches/kernel/sunxi-next ]
I would suggest using single file patch ("patch-4.4.1-rt6.patch" extracted from "patch-4.4.1-rt6.patch.gz") instead of "patches-4.4.1-rt6.tar.gz" which contains multiple small patches.
Thank you for the quick reply
I noticed in the last day armbian updated and process is different but this is what I just done and it failed
#Reinstalled Ubuntu 14.04 LTS x64 server in Virtualbox and booted up
sudo su -
#Install armbian building script
apt-get -y -qq install git
git clone --depth 1 https://github.com/igorpecovnik/lib
cp lib/compile.sh .
#Run building script first time to set-up, (source, directorys ect.)
./compile.sh
#Wheezy
#XFCE desktop
#Latest stable @kernel.org
#Failed first run during install armbian on top debian wheezy base system while installing package x-11-server-utils, directorys were set up though
#Setup patch
cd ~/userpatches/kernel/sunxi-next
wget https://www.kernel.org/pub/linux/kernel/projects/rt/4.4/patch-4.4.1-rt6.patch.gz
gunzip *.gz
cd ~
#Run armbian tool again
./compile.sh KERNEL_ONLY=no KERNEL_CONFIGURE=yes CLEAN_LEVEL=make,debs,images
#menuconfig did not start I do not know if patch was applied screen scroll was to fast
#Failed again on second run during install armbian on top debian wheezy base system while installing package x-11-server-utils
Am I doing something wrong
Don't know, but rather than enable full logging and trying to build image from scratch you can build only kernel and install it on top of one of prebuilt images.
BTW, I think Wheezy desktop is not fully supported (as in, not tested if it works or not, only Jessie and Trusty desktop builds are present in "build all" configuration)
FYI before build script updated this worked with wheezy I still have a sdcard running at this moment but without RT-Preempt
Wheezy desktop should work but it's true that I haven't build it for some time ... will be checked.
@tjmarch
Then please add
PROGRESS_LOG_TO_FILE=yes
to your compile.sh and find exact error messages in debootstrap.log and install.log
Edit: Forgot that debootstrap.log is created only in new debootstrap, so please also add
EXPERIMENTAL_DEBOOTSTRAP=yes
#Changes to compile.sh
# KERNEL_ONLY="no" KERNEL_CONFIGURE="yes" CLEAN_LEVEL="make,debs,images" PROGRESS_LOG_TO_FILE="yes" EXPERIMENTAL_DEBOOTSTRAP="yes"
# I was using the first 3 choices on command line in terminal before with no changes to compile.sh
./compile.sh
#This time prompt came up with choices for RT PREEMPT then menuconfig also opened
It is runniing hopefuly it finishes without failure
Finished successfuly final file
Armbian_5.00_Bananapim2_Debian_wheezy_4.4.1-rt6_desktop.zip
Wrote raw to sdcard
hung for a bit then I had
bananapim2 login:
I logged in
Thank you for choosing Armbian Support: www.armbian.com
root@bananapim2:~#
typed
startx
result
-bash: startx: command not found
typed uname -a
result
Linux bananapim2_4.4.1-rt6-suxi #4 SMP PREEMPT RT Sat Feb 13 12:55:50 EST 2016 arm71 GNU/Linux
Will I have to
apt-get install xfce4 xfce4-goodies
or is something else missing that will take less time
By the way THANKS A BUNCH
