nachoparker Posted April 12, 2018 Posted April 12, 2018 Hello, I have been able to run the rock64 testing image posted in https://www.armbian.com/rock64/ I want to customize this image through userpatches/customize-image.sh, as I have done in the past with the odroid HC1. The plan is to create more SD card images with NextCloudPi As a first step, I want to replicate that testing image, that works for me. Following Igor's advice in this post, I tried with the following command ./compile.sh docker \ BOARD=rock64\ BRANCH=default\ KERNEL_ONLY=no\ KERNEL_CONFIGURE=no\ RELEASE=stretch\ BUILD_DESKTOP=no\ EXPERT=yes I was asked a few questions regarding kernel configuration ( see attached file ). Seems like defconf doesn't cover all options. I tried the defaults and the resulting image doesn't boot. What am I missing in order to replicate said working test image? Thanks! rockbuild.txt
Igor Posted April 12, 2018 Posted April 12, 2018 You need yet another switch LIB_TAG="development" / untested under Docker to switch into the development branch. I am not sure master is updated for Rock64.
chwe Posted April 12, 2018 Posted April 12, 2018 On 4/12/2018 at 11:47 AM, nachoparker said: I was asked a few questions regarding kernel configuration ( see attached file ). Seems like defconf doesn't cover all options. Expand Happens when the kernel which we use gets updated and adjustments from a dev weren't made to make sure this changes work for building a new image (or in this case only in the development branch of our buildscript). A nice example what's done 'behind the scenes' and how much efforts it needs to keep the project running. (keep in mind, this has to be done for ~30 different kernels) On 4/12/2018 at 11:47 AM, nachoparker said: I tried the defaults and the resulting image doesn't boot. Expand If you dive into development, I strongly suggest that you have a USB-UART console at hand to provide a boot-log. The image doesn't boot is not enough information to help you solving the issues you have. On 4/12/2018 at 12:14 PM, Igor said: I am not sure master is updated for Rock64. Expand would it make sense to check out with specific tags for the master branch to make sure 'everything works'? I'm a complete git noob and not sure if tags are used by the repos we use. Seems that RK uses tags, this might slow down the 'update speed' a little bit, but would avoid such issues (e.g. keep development branch at master and our master at the last tag provided by the kerneldeveloper - for bsp kernels).
nachoparker Posted April 13, 2018 Author Posted April 13, 2018 Thanks again for your answers. On 4/12/2018 at 12:14 PM, Igor said: You need yet another switch LIB_TAG="development" / untested under Docker to switch into the development branch. I am not sure master is updated for Rock64. Expand Unfortunatedly, this wasn't enough for me. I tried to rebuild with this command ./compile.sh docker \ BOARD=rock64\ BRANCH=default\ KERNEL_ONLY=no\ KERNEL_CONFIGURE=no\ RELEASE=stretch\ BUILD_DESKTOP=no\ EXPERT=yes \ LIB_TAG="development"\ USE_CCACHE=yes , and again I got asked for input because of incomplete kernel configuration. Hitting the defaults, the resulting image doesn't boot. U-boot doesn't find the kernel, and tries to get it through TFTP. See attachment for UART output. I don't want to waste your time, and I understand if a development image doesn't boot. I would just like to know if there is a way to replicate an image that I already know that works using the building system. The image uploaded to https://www.armbian.com/rock64/ must have some kind of tagging or commit that can be somehow passed on to the build script to replicate that exact image, right? Anything else I am missing? Thanks! rock.txt
zador.blood.stained Posted April 13, 2018 Posted April 13, 2018 On 4/13/2018 at 6:36 AM, nachoparker said: https://www.armbian.com/rock64/ must have some kind of tagging or commit that can be somehow passed on to the build script to replicate that exact image, right? Expand No, even if we tag the build script we are almost always using branches and not tags for upstream sources (kernel, u-boot, ATF), so it is possible that things would get changed and broken over time. On 4/13/2018 at 6:36 AM, nachoparker said: Unfortunatedly, this wasn't enough for me. I tried to rebuild with this command Expand LIB_TAG should be changed in the configuration file, it cannot be set via command line. 1
nachoparker Posted May 8, 2018 Author Posted May 8, 2018 Hi, It seems that we have a stable version now, congratulations for the hard work! -> https://www.armbian.com/rock64/ Still, I couldn't build it. I pulled the latest master and it still shows in the menu as WIP. When I build it with ./compile.sh docker \ BOARD=rock64\ BRANCH=default\ KERNEL_ONLY=no\ KERNEL_CONFIGURE=no\ RELEASE=stretch\ BUILD_DESKTOP=no\ USE_CCACHE=yes It gets stuck at U-Boot 2017.09-armbian (Apr 12 2018 - 18:09:32 +0000) Model: Pine64 Rock64 DRAM: DDR version 1.06 20170424 In LPDDR3 786MHz Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=2048MB ddrconfig:6 OUT Boot1 Release Time: 2017-05-18, version: 2.43 ChipType = 0x11, 130 emmc reinit emmc reinit SdmmcInit=2 20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=7420MB FwPartOffset=2000 , 0 StorageInit ok = 48550 Raw SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit ret = 0, SecureMode = 0 LoadTrustBL No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xa4d10 RunBL31 0x10000 NOTICE: BL31: v1.3(debug):f947c7e NOTICE: BL31: Built : 12:22:09, Mar 28 2018 NOTICE: BL31:Rockchip release version: v1.3 INFO: ARM GICv2 driver initialized INFO: Using rkfiq sec cpu_context! INFO: boot cpu mask: 1 INFO: plat_rockchip_pmu_init: pd status 0xe INFO: BL31: Initializing runtime services INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian (Apr 12 2018 - 18:09:32 +0000) Model: Pine64 Rock64 DRAM: If I add EXPERT=yes \ LIB_TAG="development"\ some patches fail [ warn ] * [l][c] 04-patch-4.4.112-113.patch [ failed ] [ warn ] * [l][c] 04-patch-4.4.113-114.patch [ failed ] [ warn ] * [l][c] 04-patch-4.4.114-115.patch [ failed ] And the kernel configuration is incomplete Debug PINCTRL calls (DEBUG_PINCTRL) [N/y/?] n AMD GPIO pin control (PINCTRL_AMD) [N/y/?] n One-register-per-pin type device tree based pinctrl driver (PINCTRL_SINGLE) [N/m/y/?] n Anything I am missing? should I wait a little bit longer? Thanks
Igor Posted May 8, 2018 Posted May 8, 2018 On 5/8/2018 at 8:55 AM, nachoparker said: Anything I am missing? should I wait a little bit longer? Expand Branch "development" is fixed. It should work now: https://github.com/armbian/build/commit/cd4f7d2423b84b3cf3ddf6e6bdc0344f3200a5d7 1
nachoparker Posted May 8, 2018 Author Posted May 8, 2018 On 4/13/2018 at 4:25 PM, zador.blood.stained said: LIB_TAG should be changed in the configuration file, it cannot be set via command line. Expand What configuration file are we talking about? I keep having the same issue with the command ./compile.sh docker \ BOARD=rock64\ BRANCH=default\ KERNEL_ONLY=no\ KERNEL_CONFIGURE=no\ RELEASE=stretch\ BUILD_DESKTOP=no\ EXPERT=yes \ LIB_TAG="development"\ USE_CCACHE=yes\ Probably not detecting the LIB_TAG parameter. If it's easier to wait a little bit I can wait. Thanks!
chwe Posted May 9, 2018 Posted May 9, 2018 On 5/8/2018 at 3:30 PM, nachoparker said: What configuration file are we talking about? Expand config-default.conf which should look like the following (not the whole file): ... CREATE_PATCHES="yes" # wait that you make changes to uboot a$ BUILD_ALL="no" # cycle through available boards and ma$ # set KERNEL_ONLY to "yes" or "no" to b$ BSPFREEZE="" # freeze armbian packages (u-boot, kern$ INSTALL_HEADERS="" # install kernel headers package LIB_TAG="development" But I've never used it with docker.. 1
nachoparker Posted May 10, 2018 Author Posted May 10, 2018 @chwe thanks for the info. I finally was able to build and boot the image!!! many thanks.
nachoparker Posted May 10, 2018 Author Posted May 10, 2018 Testing image released, initial testing satisfactory
nachoparker Posted May 16, 2018 Author Posted May 16, 2018 On 4/13/2018 at 4:25 PM, zador.blood.stained said: LIB_TAG should be changed in the configuration file, it cannot be set via command line. Expand I created a PR for this https://github.com/armbian/build/pull/961
