peter12 Posted April 29, 2018 Posted April 29, 2018 Hi there, I want to build my product on Orange Pi Zero Plus2. I want to put it to enclosure and leave just power connector accessible. But I found this scenario - if user makes mistake in his wifi settings and then he saves these "faulty wifi settings", he will not be able to recover default wifi values anymore. How would you solve this? (the best approach without any additional buttons for gpio pins or additional elements)
guidol Posted April 29, 2018 Posted April 29, 2018 If the user only access is the wifi and the user does save a faulty configuration, then you need something like a gpio for a reset button. Without access via wifi and only the power port user user has normally no access anymore....but on some SBCs you have OTG on the MicroSD powerport for using as serial USB port or Ethernet via OTG-MicroSd
