Carlos_Tico Posted May 10, 2018 Share Posted May 10, 2018 How to enable desktop in Armbian Stretch mainline kernel 4.14.y IMG ?? Link to comment Share on other sites More sharing options...
Igor Posted May 11, 2018 Share Posted May 11, 2018 7 hours ago, Carlos_Tico said: How to enable desktop in Armbian Stretch mainline kernel 4.14.y IMG ?? This feature is currently under testing. It should/might work if you switch to the beta repository. User armbian-config -> system ... or on some generic manual way. 1 Link to comment Share on other sites More sharing options...
Carlos_Tico Posted May 11, 2018 Author Share Posted May 11, 2018 7 hours ago, Igor said: This feature is currently under testing. It should/might work if you switch to the beta repository. User armbian-config -> system ... or on some generic manual way. You mean using this builds in my case: https://dl.armbian.com/orangepiplus2e/nightly/ Thanks Link to comment Share on other sites More sharing options...
Igor Posted May 11, 2018 Share Posted May 11, 2018 Yes. But also a normal build can be upgreaded to latest beta build.Wrote on mobile Link to comment Share on other sites More sharing options...
