divis1969 Posted May 17, 2018 Posted May 17, 2018 Hi, I've built the Ubuntu 18.04 image with legacy kernel (4.4) and tried to install wireguard. The problem was the kernel module which seems to be build by dkms. I've installed kernel headers from the linux-headers-rk3328_5.44_arm64.deb (built by armbian's build procedure) and tried to install wireguard-dkms package. It fails: Unpacking wireguard-dkms (0.0.20180513-wg1~bionic) over (0.0.20180513-wg1~bionic) ... Setting up wireguard-dkms (0.0.20180513-wg1~bionic) ... Loading new wireguard-0.0.20180513 DKMS files... Building for 4.4.131-rk3328 Building initial module for 4.4.131-rk3328 Error! Bad return status for module build on kernel: 4.4.131-rk3328 (aarch64) Consult /var/lib/dkms/wireguard/0.0.20180513/build/make.log for more information. The content of make.log DKMS make.log for wireguard-0.0.20180513 for kernel 4.4.131-rk3328 (aarch64) Thu May 17 21:24:11 UTC 2018 make: Entering directory '/usr/src/linux-headers-4.4.131-rk3328' Makefile:643: arch//Makefile: No such file or directory make: *** No rule to make target 'arch//Makefile'. Stop. make: Leaving directory '/usr/src/linux-headers-4.4.131-rk3328' The line 643 is include arch/$(SRCARCH)/Makefile so SRCARCH is not set for some reason. Any suggestions how to fix it? Also I've tired to build wireguard module manually with dkms and/or from source. In both cases it fails because of absent scripts/recordmcount. I've tried to build that stuff with 'make scripts' in the /usr/src/linux-headers-4.4.131-rk3328 and this fails too: HOSTCC scripts/selinux/genheaders/genheaders scripts/selinux/genheaders/genheaders.c:13:10: fatal error: classmap.h: No such file or directory #include "classmap.h" This classmap.h exists in the kernel source tree, but was not included into kernel-headers deb. Do I need to fix something in kernel makefiles?
divis1969 Posted May 20, 2018 Author Posted May 20, 2018 I've managed to build/install kernel headers correctly and build the wireguard manually. Here the is patch I've added to include absent headers (created a userpatches/kernel/rk3328-default/add_more_headers.patch), borrowed from https://github.com/armbian/build/commit/98fca07d8906555ebd419e2cd3eb2a5c0af80298 diff --git a/scripts/package/builddeb b/scripts/package/builddeb index b3ed160b..b776402f 100755 --- a/scripts/package/builddeb +++ b/scripts/package/builddeb @@ -323,6 +405,7 @@ fi # Build kernel header package (cd $srctree; find . -name Makefile\* -o -name Kconfig\* -o -name \*.pl) > "$objtree/debian/hdrsrcfiles" (cd $srctree; find arch/*/include include scripts -type f) >> "$objtree/debian/hdrsrcfiles" +(cd $srctree; find security -type f -name \*.h) >> "$objtree/debian/hdrsrcfiles" (cd $srctree; find arch/$SRCARCH -name module.lds -o -name Kbuild.platforms -o -name Platform) >> "$objtree/debian/hdrsrcfiles" (cd $srctree; find $(find arch/$SRCARCH -name include -o -name scripts -type d) -type f) >> "$objtree/debian/hdrsrcfiles" (cd $objtree; find arch/$SRCARCH/include Module.symvers include scripts -type f) >> "$objtree/debian/hdrobjfiles" This unfortunately does not fix the issue with dkms build (empty $SRCARCH), but build from sources is successful.
alanplum Posted April 12, 2019 Posted April 12, 2019 (edited) I’ve just registered to say I have this exact same problem even on the mainline kernel. I can can also build the module manually but I’d much rather it was done automatically on upgrade. This topic is nearly a year old, can someone please help fix this empty SRCARCH issue. Thanks Edited April 12, 2019 by alanplum Spelling
Igor Posted April 12, 2019 Posted April 12, 2019 11 hours ago, alanplum said: I’ve just registered to say I have this exact same problem even on the mainline kernel. I can can also build the module manually but I’d much rather it was done automatically on upgrade. This topic is nearly a year old, can someone please help fix this empty SRCARCH issue. Thanks Wireguard is sourced and compiled at build time. It is possible that its temporally broken - by our fault or by their fault. What about telling us first which kernel are you using? (armbianmonitor -u)
