I am trying to understand and construct a script that will run my 3g usb modem at startup. I have great difficulty in understanding the syntax. I am using a PI PC+ with Ubuntu Xenial. If I type the following at the command prompt:
sakis3g --sudo connect --sudo USBINTERFACE="3" --sudo APN="telstra.internet"
My modem connects to the internet. Sakis3g is located in /home/opi/usr/local/bin/sakis3g. Can someone offer guidance or an example that would execute the above command at startup please?
1.) So I have sakis3g installed
2.)
So I created a file : sudo nano /etc/sakis3g.conf  with the following info:
USBINTERFACE="3"
MODEM="19d2:0031"
3.) I created an autconnectnet script - sudo nano /etc/init.d/autoconnectnet with the following:
#! /bin/sh
# /etc/init.d/autoconnectnet
### BEGIN INIT INFO
# Provides:          noip
# Required-Start:    $remote_fs $syslog
# Required-Stop:     $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Simple script to start a program at boot
# Description:       A simple script from www.stuffaboutcode.com which will start / stop a program a boot / shutdown.
### END INIT INFO
case "$1" in
  start)
    sleep 10
    echo "connecting via sakis3g"
    # run application you want to start
    /usr/local/bin/sakis3g --sudo  "connect"
  stop)
    echo "dissconnecting via sakis3g"
    # kill application you want to stop
    /usr/local/bin/sakis3g --sudo  "disconnect"
    echo "Usage: /etc/init.d/autoconnectnet {start|stop}"
    exit 1
esac
exit 0
If I type: sudo /etc/init.d/autoconnectnet start or sudo /etc/init.d/autoconnectnet stop it starts and stops no problems.
4.) Now, when I switch the power off and back on, this .conf file seems to get corrupted or modified. The following is displayed when try to go back to this entry - sudo nano /etc/sakis3g.conf  and the editor is blank.
Error reading lock file /etc/.sakis3g.conf.swp: Not enough data read
What am I doing wrong? I want the modem to start after powering on.
:-) sorta right under my nose. I have cloned Armbian/config to my OPi. I went into /config folder and chmod +x the files but I cannot get the Debian-config menu system to show.
You can set it from a menu if you have exactly this Huawei 909 modem. I took the script from @Stanislav Sinyagin https://txlab.wordpress.com/ who is dealing more with those 3G/4G modems.
Just try to make it up/down the same way.
On 6/2/2018 at 5:07 PM, Igor said:
My OS crashed and seemed to no longer load beyond a certain point. So, I have reinstalled the .img along with PIAWARE. All is good. I have cloned the latest Armbian configuration and install utility but now I am lost? Is this meant to run from entering on the command line sudo delian-config .
Sudo armbian-config takes me to the old configuration utility that does not contain the LTE modem option.
This functionality is not yet arrived into the armbian-config stable package. Scripts are specifically designed for a modem which I have around (armbian-config will show you options to connect only if you have one of supported), for others init scripts, you need to look at @Stanislav Sinyagin blog. I sent you this link to peek into the code and DIY.
