Good Morning,
I would like to Power ON or Wake the Board by IR Remote.
However I cannot find instructions anywhere on how to enable the IR wake or what the code is for wake etc.
Can you please point me in the right direction?
From: https://loverpi.com/blogs/news/first-look-at-libre-computer-board-aml-s905x-cc-le-potato-hardware-overview
it states:
Other great features include the IR receiver. You can set the IR receiver to wake the board up with remotes provided you set the software bits up.
IR Shutdown works but then I cannot wake the board by IR.
Thank you for any help and for all the time the developers donate to this.
Much appreciated.
I guess in order to receive the wake up signal, some parts of the board must be powered. Where the little bit weird note here for Image 8 playes a role, but is it now an issue or is it fixed @Da Xue ?
Some known issues with this release and additional improvement work:
  • shutdown/suspend/wakeup
I am also wondering if the receiver does work with  NEC  and  Philips protocol, depending on the driver/software?
@Tido It needs microcode for the Cortex M chip to support suspend and then a lot of software work to get out of it. It will be quite a while before that kind of work gets mainlined if at all.
on the libre computer board CPU schematic I found an IRM-3638N3 Remote control receiver.
Is this correct:
  • 38 kHz
The most commonly used protocol is the NEC protocol, which specifies a carrier frequency of 38 kHz. The NEC protocol is used by the vast majority of Japanese-manufactured consumer electronics.
The Philips RC-5 and RC-6 protocols both specify a carrier frequency of 36 kHz.
If I attach an USB-IR-Receiver (SMK in the picture), is it possible to 'turn off' the onboard ir-receiver?   How would I do that?
And this is what the output looks like:
root@amlogic:~# dmesg
[  417.797405] usb 1-1.3: new full-speed USB device number 5 using xhci-hcd
[  417.898973] usb 1-1.3: New USB device found, idVendor=0609, idProduct=031d
[  417.898999] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  417.899013] usb 1-1.3: Product: eHome Infrared Transceiver
[  417.899027] usb 1-1.3: Manufacturer: SMK
[  417.899040] usb 1-1.3: SerialNumber: SM006evO
[  417.957099] Registered IR keymap rc-rc6-mce
[  417.957426] input: Media Center Ed. eHome Infrared Remote Transceiver (0609:031d) as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/rc/rc0/input5
[  417.958052] rc0: Media Center Ed. eHome Infrared Remote Transceiver (0609:031d) as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/rc/rc0
[  417.962495] IR NEC protocol handler initialized
[  417.964607] IR RC5(x) protocol handler initialized
[  417.967217] IR RC6 protocol handler initialized
[  417.967218] IR Sony protocol handler initialized
[  417.969599] IR JVC protocol handler initialized
[  417.970533] IR SANYO protocol handler initialized
[  417.970687] input: MCE IR Keyboard/Mouse (mceusb) as /devices/virtual/input/input6
[  417.972695] lirc_dev: IR Remote Control driver registered, major 219
[  417.974693] IR MCE Keyboard/mouse protocol handler initialized
[  417.975527] rc rc0: lirc_dev: driver ir-lirc-codec (mceusb) registered at minor = 0
[  417.975546] IR LIRC bridge handler initialized
[  418.197098] mceusb 1-1.3:1.0: Registered SMK eHome Infrared Transceiver with mce emulator interface version 1
[  418.197110] mceusb 1-1.3:1.0: 2 tx ports (0x0 cabled) and 2 rx sensors (0x0 active)
[  418.197194] usbcore: registered new interface driver mceusb
root@amlogic:~# lsusb
Bus 001 Device 005: ID 0609:031d SMK Manufacturing, Inc. eHome Infrared Receiver
well, I would need to spend some time playing with it, but I doubt the notch filters on those are so amazing that they don't see +/- 2 khz difference in carrier frequency, probably the reason for grabbing a 38 kHz, the other options look like 36 and 40 kHz.  I would need to sit down with one and play with it for a while to be sure though.
@Tido because of this issue with the IR being linked to the closed-source blobs (wakeup/suspend stuff), Khadas used a separate micro controller to handle those functions.  It doesn't look good.
Good question, at least according to the data sheet you can get it likewise - let's assume they are so amazing (I watched the log while clicking with the RC6 remote control - not one biep).
Would it make sense to find out "how to turn off" the onboard receiver  and  how to attach (make use of) an external USB ir-receiver like the one on the picture?
Or is this a waste of time (turn off onboard)  - as long as there are no interference with other remotes?
Tony, thank you for your investigation. So you found out about a sad and smart move in one.
Sad: it was less of a hassle (or cost) for Khadas to add an additional chip instead of getting Cortex M chip to take care of that tasks in standby (suspend).
Smart: they found a way to give the customer what they are looking for, like it was a product from one of the big players in streaming-business
It is a matter of time and money to get the standby implementation completed in mainline. Currently there are much higher priorities. Reducing the power consumption from 0.8W to 0.1W does have interesting applications. With a secondary MCU (not based on Amlogic's design), you would have to keep some out-of-tree power management code that is different from every other board in mainline. There are benefits and costs to that design decision although I don't think the MCU cost that much.
Are you refering to this Cortex M inside of s905x ?
Power Management
  • Power management auxiliary processor in a dedicated always-on (AO) power domain that can communicate with an external PMIC
  • Multiple external power domains controlled by PMIC, and internal ones controlled by software
  • Multiple sleep modes for CPU, system, DRAM, etc.
  • Multiple internal PLLs for DVFS operation
  • Multi-voltage I/O design for 1.8V and 3.3V
Is there no code at all to go to standby and turn on again ?
Power Management
I am referring specifically to the Khadas VIM. It uses a proprietary power sequence that is different than the Amlogic reference design (p212). That means if we sponsor work for mainline Linux support of suspend and resume of reference platforms, that code may or may not work for the VIM and it may require extra code has to be implemented specifically for their design.
3 hours ago, Da Xue said:
Khadas VIM
I am not interested in this VIM, I have a Le Potato. I was just answering to TonyMac's comment.
Let's return to Le Potato. To use suspend/standby
is there a binary Blob available that we could talk to, to use suspend or standby ?
It is probably in Amlogic's openlinux BSP.
The wakeup from power-off is indeed managed by the Cortex-M processor with some code loaded in the boot time.
This code can be modifier and is present in amlogic's u-boot source :
https://github.com/BayLibre/u-boot/blob/n-amlogic-openlinux-20170606/board/amlogic/gxl_p212_v1/firmware/scp_task/pwr_ctrl.c#L184
But, it's linked to the Amlogic kernel implementation, and supporting it with mainline linux will need some work.
May I ask some question  :-)
  • I guess in order to wake up the board, it must be able to go into suspend/standby mode on Cortex-M (A53 part is off) is you meant by power-off, right?
  • The code you link above (pwr_ctrl.c) has to be in the Linux Kernel ?
  • The code you link above (pwr_ctrl.c) must be referenced in the U-Boot ?
Power-Off and Suspend is managed by the same code.
The code I linked is build in the "FIP" binaries packages with U-boot, these can be changed to match the platform. It's technically part of u-boot, but is build in the same time in the amlogic source tree.
Under Linux, each driver would need to setup the registers to permit the Cortex-M3 to acknowledge the inputs and wakeup.
In order to have proper HW support (for KODI for example) I am running an older kernel: config-3.14.29
Is it easier to implement it there or about the same ?
I found something on the internet that I add here for the collection.. once someone get to it
a kernel setting implements ‘shutdown’ as a special reboot variant setting an u-boot flag. When you power down your device it reboots into u-boot, turns off almost everything and only the OpenRISC core inside the SoC remains active with minimal power consumption if your power supply is efficient.
Then you define wakeup sources (power button, IR, even BT or Wi-Fi are possible but this is all device dependent and you have to define the stuff correctly in the so called sys_config.fex) and as soon as such a wakeup event is triggered (press the power button on your IR remote) the OpenRISC core wakes the ARM cores and Android or Linux boot normally.
I would guess there are some similarities between the Allwinner method and the Amlogic one, both using a small mcu to handle the laundry and cooking.  ;-)  But, a look at the Amlogic kernel would be the most certain way to know
