ODroid XU4: nand-sata-install not using sda1 as root after reboot
I installed Armbian_5.00_Odroidxu4_Debian_jessie_3.10.96_desktop.raw on my ODroid, plugged a 2TB external drive into the USB 3 port, and ran nand-sata-install. I chose /dev/sda1 as the root.
After completing, and rebooting, it appears it installed an operating system on /dev/sda1, but I'm still using the SD card as the root:
root@odroidxu4:~# mount
/dev/mmcblk0p2 on / type ext4 (rw,noatime,nodiratime,errors=remount-ro,commit=600)
I tried changing boot.ini to point to /dev/sda1:
setenv bootrootfs "console=tty1 loglevel=1 root=/dev/sda1 rootwait ro fsck.repair=yes"
but it would not boot with this setting.
Is there any more information I can provide to help with this issue?
I think we haven't tested SATA installer on XU4 ... so it's possible that something important is missing from kernel. I can check and rebuild kernel in few days.
