rufik Posted June 2, 2018 Posted June 2, 2018 I've experienced some issue on my OPI PC running 4.14 kernel - it disconnects eth after some hours of running. It's very annoying for me because I'm running Home Assistant automations on it and it's located in remote location (not in my home), so I have to drive 50 km to reset/reconnect it manually First I thought OPI just froze somehow (kernel panic or so). But later I've set up heartbeat trigger on red led and it's blinking, so OPI just disconnects from eth. When I unplugged cable for a minute and plugged it in back, networking was restored and I could reach via ssh. I'd like to make some workaround for now and the simplest thing seems to be write a script and put into crontab every minute - check/ping network and make a networking restart if failed. But the question is - how is managed eth0 for OPI PC in mainline ubuntu server? Just ifdown/ifup eth0 or via nmcli? I ask because I can see that mncli shows eth0 unmanaged...what is the proper way? rufik@opi:~$ uname -a Linux opi 4.14.18-sunxi #24 SMP Fri Feb 9 16:24:32 CET 2018 armv7l armv7l armv7l GNU/Linux rufik@opi:~$ ifconfig eth0 Link encap:Ethernet HWaddr 02:81:fd:fc:ae:65 inet addr:192.168.9.2 Bcast:192.168.9.255 Mask:255.255.255.0 inet6 addr: fe80::81:fdff:fefc:ae65/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:5809 errors:0 dropped:0 overruns:0 frame:0 TX packets:5305 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:552340 (552.3 KB) TX bytes:980090 (980.0 KB) Interrupt:38 rufik@opi:~$ cat /etc/network/interfaces source /etc/network/interfaces.d/* # Wired adapter #1 allow-hotplug eth0 no-auto-down eth0 iface eth0 inet dhcp # Local loopback auto lo iface lo inet loopback rufik@opi:~$ sudo nmcli g STATE CONNECTIVITY WIFI-HW WIFI WWAN-HW WWAN connected none enabled enabled enabled enabled rufik@opi:~$ sudo nmcli c NAME UUID TYPE DEVICE rufik@opi:~$ sudo nmcli n enabled rufik@opi:~$ sudo nmcli d DEVICE TYPE STATE CONNECTION eth0 ethernet unmanaged -- lo loopback unmanaged --
Igor Posted June 2, 2018 Posted June 2, 2018 1 hour ago, rufik said: I ask because I can see that mncli shows eth0 unmanaged...what is the proper way? In current images, eth0 is still managed with ifupdown but for the future, we are moving to Network Manager. Old way of networking will remain supported but it will not be used by default anymore. Remove eth0 config from /etc/network/interfaces, restart and Network manager will take control over eth0 as well.
rufik Posted June 2, 2018 Author Posted June 2, 2018 Thanks a lot. Just did it and network manager have took control. Now I can just perform nmcli d disconnect/connect easily By the way, I wonder why I'm getting disconnected...it didn't happened for weeks until I've install mosquitto and home assistant...
