gq0 Posted June 18, 2018 Posted June 18, 2018 Hi guys, I am trying to install `ARMBIAN 5.38 stable Debian GNU/Linux 9 (stretch) 4.14.14-sunxi64` to the internal MMC with `nand-sata-install` but it seems that the internal MMC is not available after booting from SD. I tried to set the `sdc_detmode` as described here: https://forum.armbian.com/topic/1702-orange-pi-plus-2e-where-is-16ghz-and-sd/?tab=comments#comment-13163 But there is no `script.bin`. Any idea on how to flash the internal MMC on a Neo Core 2? Cheers! Robert
gq0 Posted June 18, 2018 Author Posted June 18, 2018 I used this one: https://dl.armbian.com/nanopineoplus2/nightly/Armbian_5.46.180602_Nanopineoplus2_Debian_stretch_next_4.14.47.7z I followed the download path here: https://www.armbian.com/nanopi-neo-core-2-lts/
Igor Posted June 18, 2018 Posted June 18, 2018 There are very slim chances that our images don't work. Is your board the same as on the picture below? 1 hour ago, gq0 said: I used this one: https://dl.armbian.com/nanopineoplus2/nightly/Armbian_5.46.180602_Nanopineoplus2_Debian_stretch_next_4.14.47.7z This image works perfectly fine: Boot from SD: http://ix.io/1dMY Installed and booted from eMMC: http://ix.io/1dN5
gq0 Posted June 19, 2018 Author Posted June 19, 2018 15 hours ago, Igor said: There are very slim chances that our images don't work. Is your board the same as on the picture below? It looks that we have the same board revision: I connected it to a shield but other than that it should be the same: Now I tried to use a DT (mainline) based on the Neo2 with features from the Neo Plus2. This is what I added to the Neo2 DT in terms of the MMC interface: &mmc2 { pinctrl-names = "default"; pinctrl-0 = <&mmc2_8bit_pins>; vmmc-supply = <®_vcc3v3>; bus-width = <8>; non-removable; cap-mmc-hw-reset; status = "okay"; }; Source: http://git.denx.de/?p=u-boot.git;a=blob;f=arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts;h=f1406c224b4526a5abbe95a707931d5eabffb5a3;hb=HEAD#l84 And it seems to work.
张国松 Posted October 17, 2018 Posted October 17, 2018 I have the same core 2 and mini shield. for me, Armbian does not work, when LED blinks but PUTTY cannot establish sessions. Tried official ROM but canot have LAN or USB WIFI, how do you solve this problem? I am doubting my mini shield failed but it is very rare that this could happen Core 2 LED blinks and shows boot without problem, but PUTTY cannot establish sessions, and this is a big trouble and I have no access at all. Plz help
5kft Posted October 19, 2018 Posted October 19, 2018 On 10/17/2018 at 11:27 AM, 张国松 said: for me, Armbian does not work, when LED blinks but PUTTY cannot establish sessions. Have you tried hooking up a USB-serial connection to the board so that you can log in and see what is going on, check/configure networking, etc.?
