sgei Posted October 10, 2020 Posted October 10, 2020 Hi, this fix does not work for BananaPi / BananaPi Pro. I have blacklisted the module nano /etc/modprobe.d/blacklist blacklist sun4i_drm_hdmi After that: update-initramfs -u But after a reboot, I still have ~10% cpu-load from a kworker process. What I get with linux-perf-5.8 is: Any idea? Steffen 1 Quote
jeloneal Posted December 16, 2020 Posted December 16, 2020 (edited) I can confirm what @sgei is reporting but on my cubietruck with the latest armbian buster release. See my screenshot: top shows some kworker thread "events_freezable_power_" every few seconds with 10% load. Seems to be related somehow. At least this leads to the CPU being almost continually clocking @960MHz. Edited December 16, 2020 by jeloneal Updated with better screenshot, now animated 1 Quote
jeloneal Posted January 9, 2021 Posted January 9, 2021 Can anyone else running a cubietruck confirm this findings? Is there anything we can do to fix or mitigate this behaviour? 0 Quote
Madozu Posted January 9, 2021 Posted January 9, 2021 4 hours ago, jeloneal said: Can anyone else running a cubietruck confirm this findings? Is there anything we can do to fix or mitigate this behaviour? I am running a headless cubietruck with Armbian standard kernel (5.10.4-sunxi as of now). System is Ubuntu Focal Fossa with "linux-focal-root-current-cubietruck 20.11.6" installed. Cubietruck has uboot and /boot on SD-Card and the system is on a SATA-attached SSD. CPU load average over 20s (vmstat 20) is like this: procs -----------memory---------- ---swap-- -----io---- -system-- ------cpu----- r b swpd free buff cache si so bi bo in cs us sy id wa st 0 0 0 1827484 18008 137776 0 0 0 0 121 78 0 5 94 0 0 1 0 0 1827484 18008 137772 0 0 0 0 109 70 0 5 95 0 0 0 0 0 1827232 18008 137776 0 0 0 0 96 57 0 5 95 0 0 1 0 0 1827232 18008 137776 0 0 0 0 102 56 0 5 95 0 0 1 0 0 1827232 18008 137776 0 0 0 0 109 72 0 5 95 0 0 1 0 0 1827232 18008 137776 0 0 0 0 92 49 0 5 95 0 0 2 0 0 1827232 18008 137776 0 0 0 0 95 49 0 5 95 0 0 1 0 0 1827232 18008 137776 0 0 0 0 112 75 0 5 95 0 0 0 0 0 1827232 18008 137776 0 0 0 0 92 52 0 5 95 0 0 This is better than what I saw with older (e.g. 4.x) kernels but still around 5% CPU usage coming from "kworker/1:3-events_freezable_power_". When removing the modules for ADC (sun4i_gpad and sun4i_gpad_iio) the CPU usage drops down to <1% in average: procs -----------memory---------- ---swap-- -----io---- -system-- ------cpu----- r b swpd free buff cache si so bi bo in cs us sy id wa st 1 0 0 1826784 18020 137772 0 0 0 9 41 46 0 0 100 0 0 1 0 0 1826540 18020 137772 0 0 0 0 52 60 0 0 99 0 0 1 0 0 1826540 18020 137772 0 0 0 0 39 44 0 0 100 0 0 1 0 0 1826540 18020 137772 0 0 0 0 39 44 0 0 100 0 0 1 0 0 1826532 18020 137776 0 0 0 1 61 69 0 0 99 0 0 1 0 0 1826532 18020 137776 0 0 0 0 45 48 0 0 100 0 0 1 0 0 1826532 18020 137776 0 0 0 0 34 40 0 0 100 0 0 1 0 0 1826532 18020 137776 0 0 0 0 62 69 0 0 99 0 0 1 0 0 1826532 18020 137776 0 0 0 0 35 41 0 0 100 0 0 1 0 0 1826532 18020 137776 0 0 0 0 34 40 0 0 100 0 0 However as stated previously, removing those kernel modules breaks the CPU temp sensor display in the OS. What I recommend to do is running this command to remove the modules contributing to the CPU consumption: sudo rmmod sun4i_gpadc sun4i_gpadc_iio If you're happy with the result, put the above statement into /etc/rc.local to run at every boot. Blacklisting the above modules in /etc/modprobe.d only partially works as module sun4i_gpadc is loaded anyway. 2 Quote
jeloneal Posted January 11, 2021 Posted January 11, 2021 Thanks for this info. Do I also need to put sudo in front of the statement in rc.local? 0 Quote
Madozu Posted January 12, 2021 Posted January 12, 2021 15 hours ago, jeloneal said: Thanks for this info. Do I also need to put sudo in front of the statement in rc.local? No, that's not needed as rc.local runs with root privileges. The "Sudo Prefix" however is needed when you use your normal login user id to test. 0 Quote
mikhailai Posted July 28, 2022 Posted July 28, 2022 Actually, there is a better way to eliminate this CPU load without disabling the ADC driver and losing the ability to access the SOC temperature. The Linux thermal management periodically polls the SOC temperature, and you can disable it by adding the following line to /etc/rc.local: echo disabled > /sys/devices/virtual/thermal/thermal_zone0/mode Details/background: The A20 ADC driver is very inefficient: it seems to be using a busy loop (as mentioned here: https://linux-sunxi.narkive.com/1UetD5rh/bug-report-kworker-issue-for-mailline-kernel-4-12) The Linux thermal management periodically polls the SOC temperature (runs the ADC) at around 0.9Hz. I presume this would be useful for controlling the CPU fan, but probably not applicable to most A20 systems. Disabling this polling (as above) removes the CPU load, while still allowing inefficient one-off reads of the CPU temperature, as well as other ADC usage. 1 Quote
wahlm Posted January 16, 2025 Posted January 16, 2025 Just fell over the same problem during reviving my ancient cubieboard 1 and Armbian community build "Armbian_community_25.2.0-trunk.195_Cubieboard_bookworm_current_6.6.62_minimal": around 10% cpu load of kworker events_freezable_power. I have tried mikhailai's solution but the issue remained. I then checked that the A10 has a "thermal_zone1", too. So I also disabled it and the load was gone. So the solution is correct, but not complete at least for the A10 based cubieboard 1. 0 Quote
