tyrion Posted July 1, 2018 Share Posted July 1, 2018 hey there, compilation noob here. I want to build my own image via vagrant and set it up already, because Armbian is the only OS* which provides an integrated option for an encrypted rootfs (preferrably on another drive than the sd-card, because of performance) without manually fiddling around. See: https://github.com/armbian/build/issues/947 My plan is to build it with the optional config, as written in post 2 of the link above: CRYPTROOT_ENABLE=yes CRYPTROOT_PASSPHRASE="MYSECRECTPASS" CRYPTROOT_SSH_UNLOCK=yes CRYPTROOT_SSH_PORT=2222 But I don't know where to put the optional build options and it's not clear to me where to look that up. I would be very thankful if someone give me a hint where to look - the documentation is not really "noobfriendly" or I'm not looking hard enough, maybe both ;) thank you in advance for any help. *) there may be other ones, but until now I couldn't find any Link to comment Share on other sites More sharing options...
Igor Posted July 1, 2018 Share Posted July 1, 2018 https://docs.armbian.com/Developer-Guide_User-Configurations/#user-provided-kernel-config Link to comment Share on other sites More sharing options...
tyrion Posted July 28, 2018 Author Share Posted July 28, 2018 Thank you and sorry for my late answer. Maybe I misunderstand something, because I can't get it to work... I copied the kernelconfig from ~/armbian/config/kernel and added at the beginning of the file the four optional parameters unchanged to test if the compilation process is actually using the config. The path to the config is ~/armbian/userpatches/linux-odroidxu4-dev.config which is pretty much the same as written in the documentation -> userpatches/linux-$KERNELFAMILY-$KERNELBRANCH.config but I cannot see at the beginning of the build process that it's using my manually edited config. What should be the actual content of the config file? Only those optional parameters or the whole config as written in the conf directory plus the optional parameters? And where can I see (if not at the beginning of the build process) which config has been used by the compilation process? Link to comment Share on other sites More sharing options...
Igor Posted July 29, 2018 Share Posted July 29, 2018 I see. It looks like I failed to merge LUKS encrypting function to the master branch and it is normal that is not yet mentioned in a documentation. I also haven't tried it yet. @zador.blood.stained I didn't pay much attention to its development ... Is it ready to merge and since I already dump the "development" branch ... do I need to restore it to merge it properly with commits and comments? @tyrion Wait that we sort this out first. Link to comment Share on other sites More sharing options...
tyrion Posted July 29, 2018 Author Share Posted July 29, 2018 Ok thank you - I'll give it a try if the ticket on github is closed by you. Link to comment Share on other sites More sharing options...
zador.blood.stained Posted July 29, 2018 Share Posted July 29, 2018 2 hours ago, Igor said: It looks like I failed to merge LUKS encrypting function to the master branch and it is normal that is not yet mentioned in a documentation. I also haven't tried it yet. @zador.blood.stained I didn't pay much attention to its development ... LUKS encryption was not merged to master as I tried to simplify and rework it, but did not finist it yet, not to mention that it needs more testing with different kernels. 2 hours ago, Igor said: do I need to restore it to merge it properly with commits and comments? The only thing I didn't pull to a separate branch was resize2s modification, but we can get the code from here, no need to restore the "development" branch Link to comment Share on other sites More sharing options...
tyrion Posted August 30, 2018 Author Share Posted August 30, 2018 Just for the curios: here's the ticket https://github.com/armbian/build/pull/1069 Link to comment Share on other sites More sharing options...
Igor Posted August 31, 2018 Share Posted August 31, 2018 14 hours ago, tyrion said: Just for the curios: here's the ticket https://github.com/armbian/build/pull/1069 Merged. If you have some time, a how-to summary with possible limitations: https://github.com/armbian/documentation/blob/master/docs/Developer-Guide_Build-Options.md Thanks. Link to comment Share on other sites More sharing options...
