martos Posted July 12, 2018 Posted July 12, 2018 Hello, My OS : Armbian_5.44_S9xxx_Debian_stretch_3.14.29_server_20180601 My Devise: X96 mini ( 1 G Ram 8 flash + SD 16 G sdcard ) I want to use hw codec of the aml with ffmpeg So i find https://github.com/roman-rybalko/FFlmpeg-aml/ so i try to compil : AML_LIBS git clone https://github.com/Owersun/c2_aml_libs.git cd c2_aml_libs make all -j4 make install cd .. copy all files from /usr/lib/aml_libs/ to /usr/local/lib (or change the path of the install ) cp /usr/lib/aml_libs/ld.so.conf /usr/local/lib/ld.so.conf cp /usr/lib/aml_libs/libamadec.so /usr/local/lib/libamadec.so cp /usr/lib/aml_libs/libamavutils.so /usr/local/lib/libamavutils.so cp /usr/lib/aml_libs/libamcodec.so /usr/local/lib/libamcodec.so NASM cd ~/ffmpeg_sources && \ wget https://www.nasm.us/pub/nasm/releasebuilds/2.13.03/nasm-2.13.03.tar.bz2 && \ tar xjvf nasm-2.13.03.tar.bz2 && \ cd nasm-2.13.03 && \ ./autogen.sh && \ PATH="$HOME/bin:$PATH" ./configure --prefix="$HOME/ffmpeg_build" --bindir="$HOME/bin" && \ make && \ make install Yasm sudo apt-get install yasm libx264 sudo apt-get install libx264-dev libx265 sudo apt-get install libx265-dev libnuma-dev libvpx sudo apt-get install libvpx-dev libfdk-aac sudo apt-get install libfdk-aac-dev libmp3lame sudo apt-get install libmp3lame-dev libopus sudo apt-get install libopus-dev git clone git: https://github.com/roman-rybalko/FFmpeg-aml rename directory FFmpeg-aml to ffmpeg cd ffmpeg && \ PATH="$HOME/bin:$PATH" PKG_CONFIG_PATH="$HOME/ffmpeg_build/lib/pkgconfig" ./configure \ --prefix="$HOME/ffmpeg_build" \ --pkg-config-flags="--static" \ --extra-cflags="-I$HOME/ffmpeg_build/include" \ --extra-ldflags="-L$HOME/ffmpeg_build/lib" \ --extra-libs="-lpthread -lm" \ --bindir="$HOME/bin" \ --enable-gpl \ --enable-libass \ --enable-libfdk-aac \ --enable-libfreetype \ --enable-libmp3lame \ --enable-libopus \ --enable-libvorbis \ --enable-libvpx \ --enable-aml \ --enable-decoder=h264_aml \ --enable-decoder=hevc_aml \ --enable-decoder=mpeg2_aml \ --enable-decoder=mpeg4_aml \ --enable-decoder=mpeg4v1_aml \ --enable-decoder=mpeg4v2_aml \ --enable-decoder=mpeg4v3_aml \ --enable-decoder=vc1_aml \ --enable-libx264 \ --enable-libx265 \ --enable-nonfree && \ PATH="$HOME/bin:$PATH" make && \ make install && \ hash -r the compil run at this moment. Do you know if the kernel of Armbian_5.44_S9xxx_Debian_stretch_3.14.29_server_20180601 have the kernel option at : CONFIG_ION=y If not can i compile with it ?
martos Posted July 13, 2018 Author Posted July 13, 2018 some errors so mc -e ffmpeg/libavcodec/amltools.h #include "amcodec/amports/vformat.h" to #include "/root/ffmpeg_sources/c2_aml_libs/amcodec/include/amports/vformat.h" And restart compil but : CC libavcodec/amltools.o libavcodec/amltools.c: In function ‘aml_get_vdec_type’: libavcodec/amltools.c:194:10: error: ‘CODEC_TAG_VC_1’ undeclared (first use in this function) case CODEC_TAG_VC_1: ^~~~~~~~~~~~~~ libavcodec/amltools.c:194:10: note: each undeclared identifier is reported only once for each function it appears in common.mak:60: recipe for target 'libavcodec/amltools.o' failed make: *** [libavcodec/amltools.o] Error 1
martos Posted July 13, 2018 Author Posted July 13, 2018 my fault bad vformat : /root/ffmpeg_sources/buildroot/package/multimedia/libplayer/src/amcodec/include/amports/vformat.h restart compil
martos Posted July 13, 2018 Author Posted July 13, 2018 Another error : libavcodec/libavcodec.a(amldec.o): In function `ffaml_write_codec_data': /root/ffmpeg_sources/FFmpeg-amlvideo/libavcodec/amldec.c:132: undefined reference to `codec_write' libavcodec/libavcodec.a(amldec.o): In function `ffaml_checkin_packet_pts': /root/ffmpeg_sources/FFmpeg-amlvideo/libavcodec/amldec.c:174: undefined reference to `codec_checkin_pts' libavcodec/libavcodec.a(amldec.o): In function `ffaml_decode': /root/ffmpeg_sources/FFmpeg-amlvideo/libavcodec/amldec.c:343: undefined reference to `codec_get_vbuf_state' libavcodec/libavcodec.a(amldec.o): In function `ffaml_close_decoder': /root/ffmpeg_sources/FFmpeg-amlvideo/libavcodec/amldec.c:273: undefined reference to `codec_close' libavcodec/libavcodec.a(amldec.o): In function `ffaml_init_decoder': /root/ffmpeg_sources/FFmpeg-amlvideo/libavcodec/amldec.c:237: undefined reference to `codec_init' /root/ffmpeg_sources/FFmpeg-amlvideo/libavcodec/amldec.c:244: undefined reference to `codec_resume' collect2: error: ld returned 1 exit status Makefile:131: recipe for target 'ffmpeg_g' failed make: *** [ffmpeg_g] Error 1
martos Posted July 14, 2018 Author Posted July 14, 2018 Could someone can help me ? i am shure it's a trouble with PATH of compil and the linking crash , but i don't find ...
martos Posted July 14, 2018 Author Posted July 14, 2018 i am shure it could be compil : https://forum.odroid.com/viewtopic.php?t=27624
martos Posted July 14, 2018 Author Posted July 14, 2018 i find last verion of am-libs https://ftp.yzu.edu.tw/Linux/archlinuxarm/aarch64/alarm/aml-libs-c2-r9.296f39b-1-aarch64.pkg.tar.xz bu i don't understand how compil
balbes150 Posted July 16, 2018 Posted July 16, 2018 On 7/12/2018 at 9:42 PM, martos said: copy all files from /usr/lib/aml_libs/ to /usr/local/lib (or change the path of the install ) Expand After moving the libraries to a new location, have you created settings and run "ldconfig" ?
martos Posted July 16, 2018 Author Posted July 16, 2018 Thank's a lot ... but it's my fault : I see your .deb package https://yadi.sk/d/pHxaRAs-tZiei/5.44/KODI-18.0_mali7 aml-codec_5.41.1_arm64.deb i install it : LOL , all it's include only change mc -e libavcodec/amltools.h #include "amcodec/amports/vformat.h" to #include "/usr/include/amports/vformat.h" Make the compil and finsih without error !!! Now i can test if the jernel is ok with the hw codec .
balbes150 Posted July 16, 2018 Posted July 16, 2018 On 7/16/2018 at 1:20 PM, martos said: Now i can test if the jernel is ok with the hw codec . Expand After checking the write result. If this works, there is a chance that it can be used on all s9xxx (including s912). This opens up the possibility to collect MPV or KODI with hardware acceleration and without libMali.
martos Posted July 16, 2018 Author Posted July 16, 2018 with this command : /root/bin/ffmpeg -vcodec h264_aml -i /root/Sintel.2010.1080p.mkv -vcodec copy /tmp/test.mp4 Works But to transcode : /root/bin/ffmpeg -vcodec h264_aml -i /root/Sintel.2010.1080p.mkv -vcodec h264 /tmp/test.mp4 -loglevel trace Successfully opened the file. detected 4 logical cores [graph 0 input from stream 0:0 @ 0x558ccb3e80] Setting 'video_size' to value '1920x818' [graph 0 input from stream 0:0 @ 0x558ccb3e80] Setting 'pix_fmt' to value '-1' [buffer @ 0x558d12f620] Unable to parse option value "-1" as pixel format [graph 0 input from stream 0:0 @ 0x558ccb3e80] Setting 'time_base' to value '1/1000' [graph 0 input from stream 0:0 @ 0x558ccb3e80] Setting 'pixel_aspect' to value '1/1' [graph 0 input from stream 0:0 @ 0x558ccb3e80] Setting 'sws_param' to value 'flags=2' [graph 0 input from stream 0:0 @ 0x558ccb3e80] Setting 'frame_rate' to value '24/1' [buffer @ 0x558d12f620] Unable to parse option value "-1" as pixel format [buffer @ 0x558d12f620] Error setting option pix_fmt to value -1. [graph 0 input from stream 0:0 @ 0x558ccb3e80] Error applying options to the filter. look for solution ( but i have a doubt on this old ffmpeg ) 1
martos Posted July 18, 2018 Author Posted July 18, 2018 OK i have the same wit all hardware codec when it's not work. So i ask to odroid forum odroid Try "ffplay" command to check whether the aml decoder works or not. You might need a Mali enabled SDL2 library to see the video. martos oh ffplay is not compiled ... i look for ... for SDL2 i have : libsdl2-2.0-0/stable,now 2.0.5+dfsg1-2 arm64 [installed,automatic] libsdl2-dev/stable,now 2.0.5+dfsg1-2 arm64 [installed] It's enought or i need a specific SDL2 with mali includ ? odroid It was included in our latest Ubuntu 18.04 Mate image. Do you use our Ubuntu 18.04 image or meveric's Debian image? If yes, both of them have the EGL powered SDL2 library by default. Otherwise, you have to build it. Refer this link. viewtopic.php?f=146&t=28899#p205856 So ffplay is not compiled when i make the compil, i have no error but i think we need something to use the hw codec. https://www.libsdl.org/hg.php Could this library must have the ref of arm-libs ? i don't know i must find .... if you have some idea ...
balbes150 Posted July 18, 2018 Posted July 18, 2018 The Mali libraries are in the aml-mali7 package. Try to install it and start a new build.
martos Posted July 18, 2018 Author Posted July 18, 2018 i think i have already install it : root@amlogic:~# cat /var/lib/dpkg/info/aml-mali7.list /. /usr /usr/include /usr/include/umplock /usr/include/umplock/umplock_ioctl.h /usr/include/ump /usr/include/ump/ump_debug.h /usr/include/ump/ump.h /usr/include/ump/ump_uk_types.h /usr/include/ump/ump_ref_drv.h /usr/include/ump/ump_osu.h /usr/include/ump/ump_platform.h /usr/lib /usr/lib/udev /usr/lib/udev/rules.d /usr/lib/udev/rules.d/99-mali.rules /usr/lib/libMali.so /usr/lib/libEGL.so.1 /usr/lib/libGLESv2.so.2.0 /usr/lib/libEGL.so /usr/lib/libGLESv2.so /usr/lib/libEGL.so.1.4 /usr/lib/libGLESv1_CM.so.1 /usr/lib/libGLESv1_CM.so.1.1 /usr/lib/libGLESv1_CM.so /usr/lib/libGLESv2.so.2 But i want to have an eyes on the olf ffmpeg , do it use the version 2 or old version 1 ( isee some post on this )
martos Posted July 18, 2018 Author Posted July 18, 2018 and the devel of this package ? where i can find it ?
balbes150 Posted July 18, 2018 Posted July 18, 2018 These are binary files that are provided in a ready-made form from ARM.
martos Posted July 18, 2018 Author Posted July 18, 2018 Try again but same error : /root/bin/ffmpeg -vcodec h264_aml -i /root/Sintel.2010.720p.mkv /temp.test9.avi ffmpeg version N-81550-g2349883fa1 Copyright (c) 2000-2016 the FFmpeg developers built with gcc 6.3.0 (Debian 6.3.0-18+deb9u1) 20170516 configuration: --prefix=/root/ffmpeg_build --pkg-config-flags=--static --extra-cflags=-I/root/ffmpeg_build/include --extra-ldflags=-L/root/ffmpeg_build/lib --extra-libs='-lpthread -lm' --bindir=/root/bin --enable-gpl --enable-libass --enable-libfdk-aac --enable-libfreetype --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-aml --enable-decoder=h264_aml --enable-decoder=hevc_aml --enable-decoder=mpeg2_aml --enable-decoder=mpeg4_aml --enable-decoder=mpeg4v1_aml --enable-decoder=mpeg4v2_aml --enable-decoder=mpeg4v3_aml --enable-decoder=vc1_aml --enable-libx264 --enable-ffplay --enable-libx265 --enable-nonfree libavutil 55. 29.100 / 55. 29.100 libavcodec 57. 54.102 / 57. 54.102 libavformat 57. 48.102 / 57. 48.102 libavdevice 57. 0.102 / 57. 0.102 libavfilter 6. 60.100 / 6. 60.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 1.100 / 2. 1.100 libpostproc 54. 0.100 / 54. 0.100 [h264_aml @ 0x5583d69320] Unknown Codec Tag 0x0, trying to override vdec type OPEN es DEVICE codec_init amstream version : 2.0 [codec_resume]p->has_audio=0 video_resume! [matroska,webm @ 0x5583d62700] decoding for stream 0 failed [codec_close_cntl]video codec close return=0! [matroska,webm @ 0x5583d62700] Could not find codec parameters for stream 0 (Video: h264 (High), none, 1280x544): unspecified pixel format Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, matroska,webm, from '/root/Sintel.2010.720p.mkv': Metadata: encoder : libebml v1.0.0 + libmatroska v1.0.0 creation_time : 2011-04-03T10:24:20.000000Z Duration: 00:14:48.03, start: 0.000000, bitrate: 6137 kb/s Chapter #0:0: start 0.000000, end 103.125000 Metadata: title : Chapter 01 Chapter #0:1: start 103.125000, end 148.667000 Metadata: title : Chapter 02 Chapter #0:2: start 148.667000, end 349.792000 Metadata: title : Chapter 03 Chapter #0:3: start 349.792000, end 437.208000 Metadata: title : Chapter 04 Chapter #0:4: start 437.208000, end 472.075000 Metadata: title : Chapter 05 Chapter #0:5: start 472.075000, end 678.833000 Metadata: title : Chapter 06 Chapter #0:6: start 678.833000, end 744.083000 Metadata: title : Chapter 07 Chapter #0:7: start 744.083000, end 888.032000 Metadata: title : Chapter 08 Stream #0:0(eng): Video: h264 (High), none, 1280x544, SAR 1:1 DAR 40:17, 24 fps, 24 tbr, 1k tbn, 1k tbc Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s Metadata: title : AC3 5.1 @ 640 Kbps Stream #0:2(ger): Subtitle: subrip Stream #0:3(eng): Subtitle: subrip Stream #0:4(spa): Subtitle: subrip Stream #0:5(fre): Subtitle: subrip Stream #0:6(ita): Subtitle: subrip Stream #0:7(dut): Subtitle: subrip Stream #0:8(pol): Subtitle: subrip Stream #0:9(por): Subtitle: subrip Stream #0:10(rus): Subtitle: subrip Stream #0:11(vie): Subtitle: subrip [buffer @ 0x5583d9ce40] Unable to parse option value "-1" as pixel format Last message repeated 1 times [buffer @ 0x5583d9ce40] Error setting option pix_fmt to value -1. [graph 0 input from stream 0:0 @ 0x5583d9d5f0] Error applying options to the filter. Error opening filters!
martos Posted July 19, 2018 Author Posted July 19, 2018 i think i find no sdl-config !!! ack 'sdl-config' configure 5843: SDL_CONFIG="${cross_prefix}sdl-config" apt-file search "sdl-config" libsdl1.2-dev: /usr/bin/sdl-config so apt-get install libsdl1.2-dev BETTER : locate sdl-config /usr/bin/sdl-config Restart compil now
martos Posted July 19, 2018 Author Posted July 19, 2018 now ffplay is compiled ... but alway the error with ffmpeg : Unable to parse option value "-1" as pixel format i look for this error when i launch ffplay with h264_aml : [ffplay_buffer @ 0x7f7c0014f0] Setting 'video_size' to value '1920x818' [ffplay_buffer @ 0x7f7c0014f0] Setting 'pix_fmt' to value '128' [ffplay_buffer @ 0x7f7c0014f0] Setting 'time_base' to value '1/1000' [ffplay_buffer @ 0x7f7c0014f0] Setting 'pixel_aspect' to value '0/1' [ffplay_buffer @ 0x7f7c0014f0] Setting 'frame_rate' to value '24/1' [ffplay_buffer @ 0x7f7c0014f0] w:1920 h:818 pixfmt:aml tb:1/1000 fr:24/1 sar:0/1 sws_param: [ffplay_crop @ 0x7f7c001fb0] Setting 'out_w' to value 'floor(in_w/2)*2' [ffplay_crop @ 0x7f7c001fb0] Setting 'out_h' to value 'floor(in_h/2)*2' [auto-inserted scaler 0 @ 0x7f7c0024b0] Setting 'flags' to value 'bicubic' [auto-inserted scaler 0 @ 0x7f7c0024b0] w:iw h:ih flags:'bicubic' interl:0 [ffplay_crop @ 0x7f7c001fb0] auto-inserting filter 'auto-inserted scaler 0' between the filter 'ffplay_buffer' and the filter 'ffplay_crop' Impossible to convert between the formats supported by the filter 'ffplay_buffer' and the filter 'auto-inserted scaler 0' [codec_close_cntl]video codec close return=0! [h264_aml @ 0x7f8c0d2c70] closed device /dev/video10 with fd=7 [h264_aml @ 0x7f8c0d2c70] amcodec closed successfully [AVIOContext @ 0x7f8c0091e0] Statistics: 15739945 bytes read, 0 seeks ffplay works with h264 codec ...
martos Posted July 19, 2018 Author Posted July 19, 2018 strange the ffplay works with : /root/bin/ffplay -vcodec mpeg4_aml /root/Sintel.2010.1080p.mkv
martos Posted July 19, 2018 Author Posted July 19, 2018 i try /root/bin/ffplay -vcodec h264_aml /root/Sintel.2010.1080p.mkv works 2 secondes after i have on error Impossible to convert between the formats supported by the filter 'ffplay_buffer' and the filter 'auto-inserted scaler 0' But if i use : /root/bin/ffplay -vcodec mpeg4_aml /root/Sintel.2010.1080p.mkv its works So Hw aml codecs works with ffplay but not in ffmpeg (pix_fmt value?)
Rosimildo Posted July 19, 2018 Posted July 19, 2018 Have you checked which is the codec for the video ? You could use media_info to check it, for example. I know there are all kind of video encoding for this sample video. R
martos Posted July 19, 2018 Author Posted July 19, 2018 in fact i test a lot of file with the same error : Source my receiver : /root/bin/ffmpeg -vcodec mpeg4_aml -i http://192.168.1.50:8001/+1:0:19:416:4:20FA:EEEE0000:0:0:0: /tmp/test.mp4 same error [buffer @ 0x55ae04db90] Unable to parse option value "0x0" as image size [buffer @ 0x55ae04db90] Unable to parse option value "-1" as pixel format [buffer @ 0x55ae04db90] Unable to parse option value "0x0" as image size [buffer @ 0x55ae04db90] Error setting option video_size to value 0x0. [graph 0 input from stream 0:0 @ 0x55adb90170] Error applying options to the filter. and works with h264. My check say it the amlcodec don't send good value of pix_fmt to ffmpeg ( it could be an integer variable ) so it's stop.
martos Posted July 19, 2018 Author Posted July 19, 2018 i find a post with a similar a bug in ffmpeg https://ffmpeg.org/pipermail/ffmpeg-user/2016-September/033420.html buffer @ 0x2873e00] Unable to parse option value "0x0" as image size [buffer@ 0x2873e00] Unable to parse option value "-1" as pixel format [buffer @ 0x2873e00] Unable to parse option value "0x0" as image size [buffer @ 0x2873e00] Error setting option video_size to value 0x0. resolution http://git.videolan.org/?p=ffmpeg.git;a=commitdiff;h=cef5bc0e6e2320d3903cf063d59cef83e91dbc3c i must find the same in aml ... so diifcult for me .... and i can't ask to ffmpeg because it's a aml fork ... And i am not a dev ...
martos Posted July 19, 2018 Author Posted July 19, 2018 Bad news i wrote to one dev and i replt ( thank's a lot again to him ) Hi, Bad news for you: Amlogic provides a very very bad support. The only way IMO to bring that board up is to find an old working binaries together with an old working kernel. Actually I have compiled ffmpeg for ordoird 16.x but the dirver in that kernel did not work, the decoded frames was like this one https://github.com/roman-rybalko/gst-aml-plugins/blob/master/cam.png. I would recommend to you give the ffmpeg up and try to enable Amlogic v4l2 driver. Look at this: https://magazine.odroid.com/article/enable-hardware-decoding-odroid-c2/ They added kernel options: V4L2 Video Support Amlogic v4l video device support = M Amlogic v4l video2 device support = yes If you manage to build & run that you then run hardware decoding via v4l using gstreamer or via ffmpeg with --enable-libv4l2 support (prebuilt binaries already have that). IMO running hardware decoding via V4L2 is the most proper way. Good luck! Two way : i find old kernel who works with or i retry since the start and try this with v4l2 ...
martos Posted July 19, 2018 Author Posted July 19, 2018 @balbes150 an you help me to make this special kernel ? ( make a patch for this distrib could be possible ? ) or do you have in archive old version who it can works ?
balbes150 Posted July 20, 2018 Posted July 20, 2018 On 7/19/2018 at 10:51 PM, martos said: an you help me to make this special kernel ? ( make a patch for this distrib could be possible ? ) or do you have in archive old version who it can works ? Expand The developer community LibreELEC now working to support v4l-m2m is mainly the core for AML. There is already some progress. I invite you to join this work. You agree ?
martos Posted July 20, 2018 Author Posted July 20, 2018 OK i can check but my trouble is easy : i can't modify the system easily ... apt-get There is no working 'apt-get'. 'apt-get' is a command to install, update and remove software which is stored in a non local repo. 'apt-get' does nothing then connecting to such repo, downloads the software, unpacks the software, updates a big local database with all filepaths and other informations about the installed software or removes or updates installed Software. With LibreELEC it is not possible to change the system for security and stability reasons so even 'apt-get' would not be able to do this. We also dont have and want to maintain such a repo for various other great reasons. Also Ubuntu or Debian packages are often outdated and not compatible with LibreELEC TIP: use XBMC's addon browser to enhance your LibreELEC system ffmpeg -sh: ffmpeg: not found
martos Posted July 20, 2018 Author Posted July 20, 2018 I install ffmpeg with package with last libreelec / coreelec / alexelec ... no hw codec at all in ffmpeg binarie ...
