the same with kavas:
[h264_v4l2m2m @ 0xaaaaf4606910] Could not find a valid device
[h264_v4l2m2m @ 0xaaaaf4606910] can't configure decoder
In my opinion i must have /dev/video0
( ely ): You should get a /dev/video0 node if the decoder probe was successful
And in dmesg
[    6.889112] libphy: stmmac: probed
[    7.129018] meson_pwrc_vdec_power_on
[    7.129024] meson_pwrc_vdec_setup_clk
[    7.129505] Requesting IRQ 32
[    7.129702] meson_pwrc_vdec_power_off
[    7.762147] vdec_open
[    7.762166] vdec_querycap
[    7.762305] vdec_close
And i don't have /dev/video0 and no vdec in dmesg ...
I think i need the PC to use cross-compilation, it seem easier to run the build on the device BUT i don't find an "how to" for make a VM for cross compiling vm kernel.
Could some one can give me some link to make it ?
Many clue you can find in armbian documentation... And you can compile "kernel only" for s9xx box from balbes150 fork https://github.com/150balbes/Build-Armbian
So install in my PC
https://www.virtualbox.org/wiki/Downloads
create vm ( 10 CPU 16 G Ram ) with
http://archive.ubuntu.com/ubuntu/dists/xenial-updates/main/installer-amd64/current/images/netboot/mini.iso
minimal +
sudo apt-get install sed wget cvs subversion git-core \
  coreutils unzip texi2html texinfo docbook-utils \
  gawk python-pysqlite2 diffstat help2man make gcc build-essential g++ \
  desktop-file-utils chrpath default-jre gettext zip
sudo apt-get update -qq && sudo apt-get -y install \
  autoconf \
  automake \
  build-essential \
  cmake \
  git-core \
  libass-dev \
  libfreetype6-dev \
  libsdl2-dev \
  libtool \
  libva-dev \
  libvdpau-dev \
  libvorbis-dev \
  libxcb1-dev \
  libxcb-shm0-dev \
  libxcb-xfixes0-dev \
  pkg-config \
  texinfo \
  wget \
  zlib1g-dev
sudo apt-get install yasm
sudo apt-get -y install bc curl gcc git libssl-dev libncurses5-dev lzop make u-boot-tools
sudo apt-get install locate mc
download kernel
git clone https://github.com/Elyotna/linux
sudo apt-get install flex bison
sudo apt-get install elfutils
make menuconfig
save
make -j10
waiting ...
Could you give me some information :
it's on the menuconfig where it's choose arm compile ? the S905 cpu ?
How i choose the dtb to compile ?
How i can install the kernel ? ( if i don't make mistake )
ps: it's the firts time where i see my PC at the max for long time ...  35 minutes ...
i find the command :
 cat /proc/config.gz | gunzip | less
give this :
# Automatically generated file; DO NOT EDIT.
# Linux/arm64 4.18.0-rc5 Kernel Configuration
# Compiler: aarch64-linux-gnu-gcc (Linaro GCC 7.2-2017.11) 7.2.1 20171011
CONFIG_ARM64=y
CONFIG_64BIT=y
CONFIG_MMU=y
CONFIG_ARM64_PAGE_SHIFT=12
CONFIG_ARM64_CONT_SHIFT=4
CONFIG_ARCH_MMAP_RND_BITS_MIN=18
CONFIG_ARCH_MMAP_RND_BITS_MAX=33
CONFIG_ARCH_MMAP_RND_COMPAT_BITS_MIN=11
CONFIG_ARCH_MMAP_RND_COMPAT_BITS_MAX=16
CONFIG_NO_IOPORT_MAP=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_ILLEGAL_POINTER_VALUE=0xdead000000000000
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
because i don(t find how create Elyotna kernel ,
I try to build Build-Armbian
 git clone https://github.com/150balbes/Build-Armbian
cd Build-Armbian
./compile.sh
but error :
[ error ] ERROR in function compile_kernel [ compilation.sh:362 ]
[ error ] Kernel was not built [ @host ]
[ o.k. ] Process terminated
Works if i don't choose dev :
[ o.k. ] Done building [ /home/martos/Build-Armbian/output/images/Armbian_5.44_S9xxx_Ubuntu_bionic_4.18.0-rc7-next-20180731-g85eac38-dirty_server.img ]
[ o.k. ] Runtime [ 29 min ]
So my vm it's ok, but i don't know how compile Elyotna kernel ...
ELY REPLY :
Before I write down a small guide, I want to make sure of a few things:
- The driver is not suitable for any production workflow at the moment. It's been tested with limited samples and will have bugs.
- There's no deinterlacing support, so if you capture from a DVB source it's likely going to look bad.
- What are you going to do with the decoded frames if you can't transcode them ? Encoding them with software might prove to be painfully slow as the frames' buffers are uncached for CPU.
With that said, here's a quick cross-compile-your-kernel guide:
1) Grab a toolchain such as gcc-linaro-7.2.1-2017.11-x86_64_aarch64-linux-gnu.
Uncompress it somewhere like /opt
2) cd into your kernel repository and create a file source-build. Edit it and put this as the content:
Code: Select all
export ARCH=arm64
export CROSS_COMPILE=/opt/gcc-linaro-7.2.1-2017.11-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
3) source it
Code: Select all
$ source ./source-build
4) Only to do once - initialize your default .config from defconfig
Code: Select all
$ make defconfig
This defconfig enables most arm64 things for every SoC.
5) Menuconfig to disable what you don't need (all the archs except MESON for instance..), and enable things like the vdec (CONFIG_VIDEO_AML_MESON_VDEC)
Code: Select all
$ make menuconfig
6) Build the Image and the dtb
Code: Select all
$ make -j10 Image amlogic/meson-gxbb-odroidc2.dtb
And then you can push those 2 files to your board, I don't know specifically how it's done with your distro though. Hopefully you have a mainline u-boot and the kernel/dtb are somewhere in /boot.
The dtb will end up at ./arch/arm64/boot/dts/amlogic/meson-gxbb-odroidc2.dtb, while Image will be at the root directory.
If you want to use the vdec, you'll also need to download additional firmware from here. Place the meson directory in /lib/firmware on your board.
Compil Armbian_5.44_S9xxx_Ubuntu_bionic_4.18.0-rc7-next-20180731-g85eac38-dirty_server ok
Compil Elyotna kernell ok
Now i make the test Armbian with Elyotna kernel
1 test
boot
Boot ok
ok i have the file "Image" of Elyotna kernell
But the Armbian at the boot i have
zImage
and vmlinuz-4.18.0-rc7-next-20180731-aml-s9xxx-g85eac38-dirty ( same size i think this file it not use )
How i can change the kernel ?
i try to rename Image in zImage and copy into vmlinuz-4.18.0-rc7-next-20180731-aml-s9xxx-g85eac38-dirty
But it's not work ...
Someone have an idea ?
i can change :
to
make -j10 zImage amlogic/meson-gxl-s905x-khadas-vim.dtb
i have : make: *** Aucune règle pour fabriquer la cible « zImage ». Arrêt.
Rename Image it to zImage. Process with mkimage vmlinuz-4.18.0-rc7-next-20180731-aml-s9xxx-g85eac38-dirty utility to get a uInitrd file (this is an initrd in a format that understands u-boot) and copy these files with replacement to the BOOT (FAT) partition.
And don't forget to copy the kernel modules.
Stop all !
It's works !!!
i try last librelec dev  ( LibreELEC-Khadas_VIM.arm-9.0-devel-20180731153357-778b48a.img.gz )
i see the meson firmware installed
When i launch
 ffmpeg -vcodec h264_v4l2m2m -i http://192.168.1.50:8001/+1:0:19:401:4:20FA:EEEE0000:0:0:0: -s 320x240 /tmp/test.mp4
the drivers is used :
[h264_v4l2m2m @ 0x295e490] driver 'meson-vdec' on card 'AMLogic Video Decoder'
[h264_v4l2m2m @ 0x295e490] Using device /dev/video0
Stream mapping:
  Stream #0:0 -> #0:0 (h264 (h264_v4l2m2m) -> mpeg4 (native))
  Stream #0:1 -> #0:1 (eac3 (native) -> aac (native))
Press [q] to stop, [?] for help
[aac @ 0x29582d0] Using a PCE to encode channel layout
i begin to test .
ely have repy :
I'm confident the performance is going to be poor when doing software scale/encode on v4l2 frames.
(with HW )
ffmpeg -c:v h264_v4l2m2m -i Sintel.2010.720p.mkv -c:a copy -vcodec mpeg4 -s 320x240 /tmp/test.mp4
frame=  191 fps=8.5 q=4.7 Lsize=    1136kB time=00:00:10.52 bitrate= 884.2kbits/s speed=0.466x
(without HW )
ffmpeg -i Sintel.2010.720p.mkv -c:a copy -vcodec mpeg4 -s 320x240 /tmp/test.mp4
frame= 1345 fps= 79 q=17.9 Lsize=    5990kB time=00:00:56.19 bitrate= 873.2kbits/s speed=3.28x
The reason behind this is that the frames that come out of the decoder via V4L2 have pages with CPU cache disabled, so any software access is very, very slow.
BUT memeka ( dev who use hardware accelerator for exynos chip with MFC who use too v4l2m2m ) ask:
can something like this: https://github.com/mihailescu2m/linux/compare/b5edc85935d83e48a973a6e730706ac3cd255746...53f47a87e0aa8e25e960d42ee56ef79c5c91e9c8 be done for S905 SoC as well?
So i am waiting to make new test ...
ELY had a cache to improve performance (memeka proposal):
So, I could *sorta* replicate the patches, I had to drop the cache maintenance because it was crashing but could still enable read cache (although of course it's not really usable since some of the data will be corrupted by cache).
Software decoding:
ffmpeg -i Sintel.2010.720p.mkv -an -vcodec mpeg4 -s 320x240 -vframes 1500 -f null -
frame= 1500 fps= 79 q=10.2 Lsize=N/A time=00:01:02.50 bitrate=N/A speed=3.28x
ffmpeg -i bbb_sunflower_1080p_60fps_normal.mp4 -an -vcodec mpeg4 -s 320x240 -vframes 1500 -f null -
frame= 1500 fps= 40 q=31.0 Lsize=N/A time=00:00:25.03 bitrate=N/A speed=0.673x
HW decoding + read cache:
ffmpeg -c:v h264_v4l2m2m -i Sintel.2010.720p.mkv -an -vcodec mpeg4 -s 320x240 -vframes 1500 -f null -
frame= 1500 fps= 84 q=10.2 Lsize=N/A time=00:01:02.50 bitrate=N/A speed= 3.5x
ffmpeg -c:v h264_v4l2m2m -i bbb_sunflower_1080p_60fps_normal.mp4 -an -vcodec mpeg4 -s 320x240 -vframes 1500 -f null -
frame= 1500 fps= 40 q=31.0 Lsize=N/A time=00:00:25.03 bitrate=N/A speed=0.661x
720p had a slight advantage (6%).
On the 1080p sample the bottleneck was elsewhere (probably mpeg4 encoder not being able to take full multi-thread advantage on such a small resolution), as CPU usage was 300% for software decoding and 100% for HW decoding.
The performance gains would probably be more significant if encoding at a higher resolution or with x264.
when the code isok, i can test h264 to know if we can have 1080p -> 320x240 with speed 1.x
hi
after compile build
i  tested libreelec 9 with kernel 4.18 r7  for wetek play 2
video is work  fine  nice  i  tested hd  x264   p1080
some change
but i don't think its important change ...
vdec: Rework the recycle mechanism
Now the thread code appears only once in vdec.c. Added can_recycle and recycle codec ops. Also remove "meson" from the dts compatibles. I've decided to no longer force push into my dev branch to better track the changes I make. Patchset will be redone cleanly for 4.19.
Yes, I make it with V4l2-m2m , but this way don't use all the hardware ,
so we can use use for decode in realtime (it's not perfect at all ) , but not for encode .
So for Amlogic ( or other device using the v4l2_m2m ) it's not enough ok for me ( just reduce cpu using )
For rockchip i wait the encode hardware in mpp ( in the roadmap this year ) and someone in the ffmpeg team have a look on my ticket ( open 6 month ago )
I am interested in decoding for S9xxx. You can write details, what kernel do you use, what kernel config do you use ? What are the FFMPEG source code and build option ?
normaly i write all i use in the begining of the post, but i try it again this week end ( i m not at home this week) with the new kernel and put here the details.
I figured out the FFMPEG build. Details in this post. Testing the decoder seems to work correctly (there is a noticeable difference with the soft mode), but so far there is an incomprehensible situation with the use of FFPLAY.
Hello, I have encountered a similar problem, I want to use ff-mpeg hardware accelerated decoding on the s905D armbian system, but I did not find the relevant information on the Internet, and s905 on the le kodi can be hardware accelerated decoding. Do you know what I should do on armbian.
I look forward to your reply, thank you very much!
  • Werner locked this topic
