CarlosPuyana Posted July 30, 2018 Posted July 30, 2018 Hi, I'm trying to set up an Orange Pi Zero with Armbian, so that I can use it as a Network Card (i.e. when I plug it into a computer it's automatically recognized as a Network Card). It seems there isn't enough documentation about this issue. Can anybody help me, please? Thanks in advance. Kind Regards.
WarHawk_AVG Posted August 1, 2018 Posted August 1, 2018 You want it to have a static IP on the ethernet port? https://docs.armbian.com/User-Guide_Getting-Started/#how-to-set-fixed-ip
Igor Posted August 1, 2018 Posted August 1, 2018 On 7/30/2018 at 1:17 PM, CarlosPuyana said: I'm trying to set up an Orange Pi Zero with Armbian, so that I can use it as a Network Card (i.e. when I plug it into a computer it's automatically recognized as a Network Card). @WarHawk_AVG He probably means this: http://linux-sunxi.org/USB_Gadget/Ethernet 1
tkaiser Posted August 1, 2018 Posted August 1, 2018 On 7/30/2018 at 1:17 PM, CarlosPuyana said: It seems there isn't enough documentation about this issue This is kernel functionality. For the H3 legacy kernel we had to add a mini patch (contained in our kernel by default since more than 2 years now): https://forum.armbian.com/topic/1417-g_ether-driver-h3-device-as-ethernet-dongle/ With mainline kernel it also should 'just work': see comments here: https://github.com/armbian/build/issues/538 You just need to make sure to disable g_serial module since only one USB gadget module can be active at the same time and by default we provide a serial console on the Micro USB port by default. More info can be found by using Google Site Search for 'g_ether'. 1
