CarlosPuyana Posted July 30, 2018 Share Posted July 30, 2018 Hi, I'm trying to set up an Orange Pi Zero with Armbian, so that I can use it as a Network Card (i.e. when I plug it into a computer it's automatically recognized as a Network Card). It seems there isn't enough documentation about this issue. Can anybody help me, please? Thanks in advance. Kind Regards. Link to comment Share on other sites More sharing options...
WarHawk_AVG Posted August 1, 2018 Share Posted August 1, 2018 You want it to have a static IP on the ethernet port? https://docs.armbian.com/User-Guide_Getting-Started/#how-to-set-fixed-ip Link to comment Share on other sites More sharing options...
Igor Posted August 1, 2018 Share Posted August 1, 2018 On 7/30/2018 at 1:17 PM, CarlosPuyana said: I'm trying to set up an Orange Pi Zero with Armbian, so that I can use it as a Network Card (i.e. when I plug it into a computer it's automatically recognized as a Network Card). @WarHawk_AVG He probably means this: http://linux-sunxi.org/USB_Gadget/Ethernet 1 Link to comment Share on other sites More sharing options...
tkaiser Posted August 1, 2018 Share Posted August 1, 2018 On 7/30/2018 at 1:17 PM, CarlosPuyana said: It seems there isn't enough documentation about this issue This is kernel functionality. For the H3 legacy kernel we had to add a mini patch (contained in our kernel by default since more than 2 years now): https://forum.armbian.com/topic/1417-g_ether-driver-h3-device-as-ethernet-dongle/ With mainline kernel it also should 'just work': see comments here: https://github.com/armbian/build/issues/538 You just need to make sure to disable g_serial module since only one USB gadget module can be active at the same time and by default we provide a serial console on the Micro USB port by default. More info can be found by using Google Site Search for 'g_ether'. 1 Link to comment Share on other sites More sharing options...
