How to set up an Orange Pi Zero with Armbian as a USB Network Card
CarlosPuyana
Hi,
I'm trying to set up an Orange Pi Zero with Armbian, so that I can use it as a Network Card (i.e. when I plug it into a computer it's automatically recognized as a Network Card).
It seems there isn't enough documentation about this issue.
Can anybody help me, please?
Thanks in advance.
Kind Regards.
This is kernel functionality. For the H3 legacy kernel we had to add a mini patch (contained in our kernel by default since more than 2 years now): https://forum.armbian.com/topic/1417-g_ether-driver-h3-device-as-ethernet-dongle/
With mainline kernel it also should 'just work': see comments here: https://github.com/armbian/build/issues/538
You just need to make sure to disable g_serial module since only one USB gadget module can be active at the same time and by default we provide a serial console on the Micro USB port by default. More info can be found by using Google Site Search for 'g_ether'.
