pepesuriano Posted August 8, 2018 Posted August 8, 2018 Hi, new to armbian here! I'm coming from libreelec looking for a less limited operating system keeping mediacenter features of libreelec (mostly kodi) I installed Armbian_5.44_S9xxx_Debian_stretch_3.14.29_server_20180601.img.xz (it boots only versions with 3.14 kernel, others don't work), I found that it has not wifi drivers because it is not working, just eth0 is shown with "ip a". Is it possible that drivers for this box are missing? With libreelec it works like a charm. Thanks in advance!
pepesuriano Posted August 8, 2018 Author Posted August 8, 2018 On 8/8/2018 at 8:38 AM, balbes150 said: Cool! It worked with dhd Is it possible to do this with a fresh installed image (without first boot yet)? Just to avoid having to make this every time the sd is burn and make first run script usable for networking.
olivluca Posted October 12, 2018 Posted October 12, 2018 @pepesuriano if you're still following the forum, does the dvb-s2 tuner work with armbian? 1
olivluca Posted November 11, 2018 Posted November 11, 2018 Taking advantage of several 11.11 coupons I just bought one, any hint while I wait for it to arrive?
erbas Posted January 25, 2019 Posted January 25, 2019 On 10/12/2018 at 11:31 PM, olivluca said: @pepesuriano if you're still following the forum, does the dvb-s2 tuner work with armbian? Expand I would like to know the same! @pepesuriano Good friend let me know did you get any results with the new kernel 4.xx in the armbian installation? I've been trying for 1 months Install the Libreelec version of the kernel version 4.xx! Unsuccessfullyhttps://forum.libreelec.tv/thread/12330-test-libreelec-images-with-kodi-18-for-s9xxx/?pageNo=21 I have the same box KI Pro (S905D) If you got some success tell us how? Thank you,
C0NPAQ Posted January 29, 2019 Posted January 29, 2019 Hello, has someone tried ArchlinuxARM vs. Armbian on this box Mecool Ki Pro specifically? I have also already used LibreELEC with it off SD card, since internal flash is busted, and LibreELEC ran all sorts of stuff it can do, like DVB-C tuner with TVHeaded2. So basically there should be no reason it won't all run on the bigger distributions (or not? ..). Someone wrote online, that the Ki Pro has possibly the best LibreELEC support of all boxes. But I am wondering, e.g. about xorg graphics drivers and kernel versions. Which one, ArchlinuxARM or Armbian, has newer and better stuff for the Ki Pro? The Ki Pro is like the Odroid-2 in specs, but it won't boot a normal ext4 partition you need to use u-boot stuff or something, which rather needs to be provided by an IMG file. Here Archlinux links: https://yadi.sk/d/BbH_N6HFzvjhm https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/606133-linux-images-for-s802-s805-s812-s905-s905x-s912-sd-usb-emmc https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905/tronsmart-ac/firmware-roms-tools-at/565449-running-linux-from-sd-card-or-usb-flash-drive-using-balbes150-method-and-files OK, so here are the steps to install Archlinux on the Mecool Ki Pro : 1. First link, download any of S9xxxx images, like S9xxx_ArchLinux_MATE_20180207_3_14.img.xz - then extract .xz archive 2. Use this http://hddguru.com/software/HDD-Raw-Copy-Tool/HDDRawCopy1.10Portable.exe to write .img file to SD card (I believe, its simply like dd on linux) Now on Windows a new FAT partition appears (let's call that F:\ ). There you have to do two things: 3. Copy the file F:\dtbs\gxl_p230_k1_pro.dtb to F:\dtb.img 4. Rename F:\s905_autoscript to F:\aml_autoscript Now you can test if the SD card boots by unplugging the device, holding the power button until you see whatever picture, and plugging power back in while you hold it. You do not need to make any system modifications to boot from SD card, as described in the links above. It boots SD cards while holding power when powering on as factory default. If you fail to do any of the above steps, it won't work. And the last step is mentioned nowhere afaik. I only tried it because I recognized the file from libreELEC. You can also copy the appropriate remote.conf somewhere over from the LibreELEC site or here https://file.io/iUytX9 . I have a real keyboard/touchpad remote, so I don't care about that at all. Now, still at your PC, you can also do this: 5. Remove second partition, recreate, then use resize2fs to fit full size of SD card. (I have no idea how you would do that on Windows. It can't be done from the running system.) 6. Modify the F:\hdmi.sh to change screen resolution and stuff.
C0NPAQ Posted January 31, 2019 Posted January 31, 2019 Btw. you need to load all the modules manually, as far as I gathered. Including wifi. Its called ... 8723bs I believe. And yes, it works.
C0NPAQ Posted January 31, 2019 Posted January 31, 2019 I also tried to boot the images with the 4.XX kernels and it won't work. Only the 3.14 - no issues there. Why is that?
balbes150 Posted January 31, 2019 Posted January 31, 2019 On 1/31/2019 at 12:12 AM, C0NPAQ said: I also tried to boot the images with the 4.XX kernels and it won't work. Only the 3.14 - no issues there. Why is that? Expand As long as you do not provide a log to start a new kernel from the UART console, no one will help you.
C0NPAQ Posted January 31, 2019 Posted January 31, 2019 Thanks a lot. I will provide actual UART console output in a few days, when I get a new adapter.
olivluca Posted January 31, 2019 Posted January 31, 2019 On 1/31/2019 at 12:12 AM, C0NPAQ said: I also tried to boot the images with the 4.XX kernels and it won't work. Only the 3.14 - no issues there. Why is that? Expand Because there is no dtb that works for the KI pro. The dtb for 3.14 cannot be used since the format changed.
C0NPAQ Posted January 31, 2019 Posted January 31, 2019 On 1/31/2019 at 6:02 PM, olivluca said: Because there is no dtb that works for the KI pro. The dtb for 3.14 cannot be used since the format changed. Expand There are all the dtb files for Ki Pro, Kii Pro, Kiii Pro, Ki Plus, p230 in the images provided by balbes150 (see his post in this thread). This is exactly why I am asking about it. I am not trying to do something dumb, like boot without dtb file. They really exist, whereever he got them from. Both the P230 and the Ki Pro dtb ought to work 100%. Mostly all of the mentioned Mecool Boxes' dtb files should possibly work, since they are virtually identical in specs. They only have more or less RAM or don't ship with the DVB module, and stuff like that.
olivluca Posted February 1, 2019 Posted February 1, 2019 the dtb you mention are only available for kernel 3.14, they won't work for any later kernel
C0NPAQ Posted February 1, 2019 Posted February 1, 2019 On 2/1/2019 at 12:02 AM, olivluca said: the dtb you mention are only available for kernel 3.14, they won't work for any later kernel Expand You are in total error. Like I said, those files exist in the dtb folder in the images from balbes150 with the 4+ kernels Armbian, and they belong to that kernel. Please check the images yourself, if you are in doubt.
balbes150 Posted February 1, 2019 Posted February 1, 2019 On 2/1/2019 at 12:53 AM, C0NPAQ said: You are in total error. Like I said, those files exist in the dtb folder in the images from balbes150 with the 4+ kernels Armbian, and they belong to that kernel. Please check the images yourself, if you are in doubt. Expand These DTB appeared in the images of the patch from Libreelec. But nobody checked them and there are no guarantees that they are working at all.
olivluca Posted February 1, 2019 Posted February 1, 2019 Is it this one? https://github.com/150balbes/Amlogic_s905-kernel/blob/master/arch/arm64/boot/dts/amlogic/meson-gxl-s905d-ki-pro.dts if so it seems it just adds the dvb hardware to meson-gxl-s905d-p230 and that didn't work when I tried it, so I doubt it will work but I'd be delighted to be proven wrong.
C0NPAQ Posted February 2, 2019 Posted February 2, 2019 @olivluca: Do you have UART console, what did it say? We got to get this working somehow. These new kernels in balbes150 images got all sorts of miracles going, like hardware accel for video. I hope my new UART module arrives today.
olivluca Posted February 2, 2019 Posted February 2, 2019 On 2/2/2019 at 11:45 AM, C0NPAQ said: Do you have UART console, what did it say? Expand I didn't open the box (yet ), I'm happy enough with libreelec, though I'd like a real linux system to tinker with, but consider that I have less and less time to tinker
C0NPAQ Posted February 2, 2019 Posted February 2, 2019 Ok, so here is the problem ... Quote load dtb from 0x1000000 ...... Amlogic multi-dtb tool Single dtb detected ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND [rsvmem] fdt get prop fail. Loading Ramdisk to 73b57000, end 73ea1250 ... OK Loading Device Tree to 000000001fff6000, end 000000001ffff2aa ... OK fdt_instaboot: no instaboot image Starting kernel ... uboot time: 7758695 us Expand Note that I was using the meson-gxl-s905d-p230.dtb on the Armbian 5.44 image, and on the 5.73 I was using the meson-gxl-s905d-ki-pro.dtb file. The issue is the same though. Also I tried both ttyS0 and ttyAML0, none worked. @balbes150: So can something possibly be done? Here are the full logs: Mecool_Ki_Pro_boot_sd_card_with_Armbian_5.44_S9xxx_Debian_stretch_3.14.29_xfce_20180729.img.txtFetching info... Mecool_Ki_Pro_boot_sd_card_with_Armbian_5.44_S9xxx_Debian_stretch_4.18.0-rc5_xfce_20180806.img.txtFetching info... Mecool_Ki_Pro_boot_sd_card_with_Armbian_5.73_Aml-s905_Debian_stretch_default_4.20.2_desktop_20190130.img.txtFetching info...
C0NPAQ Posted February 2, 2019 Posted February 2, 2019 I also tried different dtbs on the 3.14 kernel .... 3.14 gxl_p230_k1_pro.dtb : works 3.14 gxl_p230_2g.dtb : works 3.14 gxl_p200.dtb: the kernel hangs after outputting one line 4.XX (I tried over a dozen dtbs): nothing works, no output
balbes150 Posted February 2, 2019 Posted February 2, 2019 1. The output from the first log (3.14) shows that the system is normally running and waiting for the user to log in for the initial setup. Debian GNU/Linux 9 aml ttyS0 aml login: 2 and 3. The log with the kernel 4.18 and 4.20 . An unsuitable dtb is used. It is necessary to select a working option. Try all the file groups gxl and gxm. Try the option file that I posted in the topic for AndreDB.
C0NPAQ Posted February 2, 2019 Posted February 2, 2019 I literally tried all the dtb files in the 5.XX kernel image (plus the one you mentioned meson-gxm-q201-1gb.dtb), and the issue is always the same. I can't really believe that this is related to an improper DTB file, because: 1. In the 3.14 kernel, the gxl_p230_k1_pro.dtb and gxl_p230_2g.dtb worked well. Other dtbs also produced some kind of output over serial console, although they didn't boot completely. 2. So its not like we only had this one single proprietary DTB blob from the manufacturer to begin with, that only works with the 3.XX kernel. 3. Now although there are like 10 DTB files that are compatible and should run, for Ki Pro, Ki Plus, Kii Pro, P230 a, P230 b, etc. etc. - none work? 4. What about the FDT_ERR_NOTFOUND error? I read online, that more or less this relates to some bug in uboot? Excuse my doubts. This is all new to me. Maybe it is a uboot issue? Reveal hidden contents DTBs I tried: meson-g12a-u200.dtb meson-axg-s400.dtb meson-gxl-s805x-libretech-ac.dtb meson-gxbb-nanopi-k2.dtb meson-gxbb-nexbox-a95x.dtb meson-gxbb-odroidc2.dtb meson-gxbb-p200.dtb meson-gxbb-p201.dtb meson-gxbb-vega-s95-meta.dtb meson-gxbb-vega-s95-pro.dtb meson-gxbb-vega-s95-telos.dtb meson-gxbb-wetek-hub.dtb meson-gxbb-wetek-play2.dtb meson-gxl-s905x-hwacom-amazetv.dtb meson-gxl-s805x-p241.dtb meson-gxl-s905d-p230.dtb meson-gxl-s905d-p231.dtb meson-gxl-s905d-phicomm-n1.dtb meson-gxl-s905w-p281.dtb meson-gxl-s905w-tx3-mini.dtb meson-gxl-s905x-libretech-cc.dtb meson-gxl-s905x-khadas-vim.dtb meson-gxl-s905x-nexbox-a95x.dtb meson-gxl-s905x-p212.dtb meson-gxm-khadas-vim2.dtb meson-gxm-nexbox-a1.dtb meson-gxm-q200.dtb meson-gxm-q201.dtb meson-gxm-rbox-pro.dtb meson-gxm-vega-s96.dtb meson-gxm-q201-1gb.dtb
balbes150 Posted February 2, 2019 Posted February 2, 2019 On 2/2/2019 at 5:45 PM, C0NPAQ said: I literally tried all the dtb files in the 5.XX kernel image (plus the one you mentioned meson-gxm-q201-1gb.dtb), and the issue is always the same. I can't really believe that this is related to an improper DTB file, because: 1. In the 3.14 kernel, the gxl_p230_k1_pro.dtb and gxl_p230_2g.dtb worked well. Other dtbs also produced some kind of output over serial console, although they didn't boot completely. 2. So its not like we only had this one single proprietary DTB blob from the manufacturer to begin with, that only works with the 3.XX kernel. 3. Now although there are like 10 DTB files that are compatible and should run, for Ki Pro, Ki Plus, Kii Pro, P230 a, P230 b, etc. etc. - none work? 4. What about the FDT_ERR_NOTFOUND error? I read online, that more or less this relates to some bug in uboot? Excuse my doubts. This is all new to me. Maybe it is a uboot issue? Expand 1. The described error does not affect anything, you can ignore it. 2. You can believe it or not. I write the, that himself many times tested. If I see such a conclusion, it is almost always decided by the correct dtb. 3. Perhaps those DTBS that you have tried do not fit your model and need more in-depth study and comparison of the parameters in the dtb. 4. There is another reason, when running the new kernel - very old u-boot. This can be checked by running a clean system entirely from external media ( along with the new u-boot). If you have a firmware file to recover via USB Burn Tool, this can be checked.
C0NPAQ Posted February 2, 2019 Posted February 2, 2019 How do I run the new uboot? My box has its internal MMC busted. I have USB Burn tool. Also check out this file I extracted from the Amlogic IMG file. Is it good for anything? dtb_from_amlogic_img_file.txtFetching info... dtb_from_amlogic_img_file_2.txt
balbes150 Posted February 3, 2019 Posted February 3, 2019 On 2/2/2019 at 7:24 PM, C0NPAQ said: My box has its internal MMC busted. Expand You do not work eMMC ? Have you checked the start-up of 5.73 with this dtb ?
C0NPAQ Posted February 3, 2019 Posted February 3, 2019 Result is identical with previous ones. It does not work.
balbes150 Posted February 3, 2019 Posted February 3, 2019 On 2/3/2019 at 1:38 PM, C0NPAQ said: Result is identical with previous ones. It does not work. Expand Then wait until I can check the dtb you sent from kernel 3.14 and build a new version. It's not going to be fast. 2
balbes150 Posted February 8, 2019 Posted February 8, 2019 Try running the latest image with this DTB. I am interested in the overall startup and output of the UART console with this DTB. https://yadi.sk/d/C9sVm6Faw8Xu_w
