Hi NicoD !
Thanks for your suggestion.
Tried that, but it fails to apply the new mode: screen blanks for a couple of seconds then xrandr spits an error "configure crtc 0 failed" :
~$ cvt 2560 1440 60
# 2560x1440 59.96 Hz (CVT 3.69M9) hsync: 89.52 kHz; pclk: 312.25 MHz
Modeline "2560x1440_60.00"  312.25  2560 2752 3024 3488  1440 1443 1448 1493 -hsync +vsync
~$ xrandr --newmode "2560x1440_60.00"  312.25  2560 2752 3024 3488  1440 1443 1448 1493 -hsync +vsync
~$ xrandr --addmode HDMI-1 "2560x1440_60.00"
~$ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 3840 x 2160
HDMI-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 527mm x 296mm
   1920x1200     59.95
   1920x1080     60.00*   60.00    50.00    59.94    24.00    23.98
   1920x1080i    60.00    60.00    50.00    59.94
   1600x1200     60.00
   1680x1050     59.88
   1280x1024     75.02    60.02
   1280x800      59.91
   1152x864      75.00
   1280x720      60.00    60.00    50.00    59.94
   1024x768      75.03    60.00
   800x600       75.00    60.32
   720x576       50.00    50.00
   720x480       59.94    59.94    59.94
   640x480       75.00
   2560x1440_60.00  59.96
~$ xrandr --output HDMI-1 --mode 2560x1440_60.00
xrandr: Configure crtc 0 failed
Any ideas ?
[edit 2020/16] tried with many other refresh rates and even copying the modeline data from my desktop while hooked to the same display: same error.
Starting to wonder whether this a95x's s905x is really capable of outputing any resolution beyond 1080p.... ??
  On 2/9/2020 at 4:50 PM, almotra said:
With version 5.5, on my x96mni the command ./install.sh does not work.
On version 5.3, it works.
why it does not work in 5.5?
I can't find exlinux.conf and uEnv.ini, what should I change? just uEnv.txt ???
Expand
Nobody to answer me ????
@balbes150 I tried to install it on a s10 tv box, has a s913,  3gb ram 1gb lan. I was able to get working letting the auto-selection find on dtb (selected vim2).
But I wanted to work using the original dtb files, I got the original firmware dtb, but it's does but.  this is the dts https://gist.github.com/nmocruz/a0baaf537808335ddc8bab2042131624
there's any reason why it fails?
I don't have a way to debug uart because the board has not pins, I has to solder something or what in the middle of mainboard
  On 3/7/2020 at 5:16 PM, hexdump said:
@Nuno Cruz - the original dtb is for android and most probably for another kernel version too, so there is no way to make it work without a lot of adaption work
Expand
@hexdump Got it. There's a generic dtb for this s912 3rb ram 1 gb ethernet. It's possible  to get from the original dts information missing on this?
I'm not expert to edit this dts files, but I would like to compile the ogirinal without any setting that is causing this compatitiblity issue
  On 3/8/2020 at 12:58 AM, hexdump said:
@Nuno Cruz - it is sometimes possible to extract some information from the original dtb and use it to adjust a mainline one, but its not easy and not always possible ...
Expand
Cool, I gonna try that approach,  use the vim2 dts to compile with bit from the original dts if needed
  On 8/25/2019 at 2:20 PM, balbes150 said:
The new version Armbiam 20190825 kernel 5.3.0. In this version the temperature display on G12 works.
For reasons not yet clear, the G12 has a conflict with this kernel with PULSEAUDIO. To turn the sound on models with G12 (s905x2 S922x a311d) you need to perform these steps.
1. Remove package "pulseaudio".
2. Reboot the system.
3. Once run the command "sudo /root/g12_sound.sh".
When you remove the pulseaudio package, not volume control.
Alternatively, you can install the "pnmixer" package that works with ALSA.
Khadas VIM3 and Ugoos AM6
Full-screen 1080p video playback from Youtube (Chromium) to works at a temperature no higher than 55 (without a fan). :)
Expand
I did as specified in this post and got the hdmi audio working. Though it only worked after I set the hdmi output to i2c in the alsamixer.
I could reinstall pulseaudio after that without problem.
BUT the analog audio sitll not working (by analog audio I mean the aundio on the AV jack, the one that cames along with the analog video signal).
I allready tried every possible combination on the alsamixer but to no avail.
I really need to that working because I want to use the box with an old analog TV.
My box is an X92 (S912) [2Gb RAM].
The image I'm currently running is Armbian_20.05.0_Arm-64_focal_current_5.6.0-rc4_desktop_20200306.img.
Any idea what else can I try?
How do I flash this image to a MicroSD card?
With previous armbian image, after flashing I have a BOOT partition for me to edit the uEnv.ini
but with this image Armbian_20.02.0-rc1.037_Aml-s9xxx_bionic_current_5.5.0-rc6_20200205.img.xz
after flashing using balenaEtcher or Rufus, I can't seem to find the BOOT partition?
Thanks.
Edit:
Ok, the image needs to be unpacked first and use Rufus. balenaEtcher doesn't work
Edited by rampagepi
How do I config this build to run from MicroSD card on H96 Pro Plus?
The old version I had runs fine, but this new build won't boot by default.
Old version uEnv.ini
dtb_name=/dtb/meson-gxm-khadas-vim2.dtb
bootargs=root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
Old version extlinux.conf
LABEL Armbian
  LINUX /zImage
  INITRD /uInitrd
  FDTDIR /dtb
#  FDT /dtb/meson-gxm-khadas-vim2.dtb
  APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
With this new build, for the uEnv.ini
it is
# aml s9xxx
FDT=/dtb/amlogic/meson-g12b-odroid-n2.dtb
APPEND=root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
Actually I've tried both
FDT=/dtb/amlogic/meson-gxm-khadas-vim2.dtb
and
dtb_name=/dtb/amlogic/meson-gxm-khadas-vim2.dtb
in uEnv.ini with the new build, but it won't boot.
So what should it be?
Expand
New versions do not have the file uEnv.ini. To work with new versions, the universal multiload must be updated using the image you are trying to use.
Cool.
The first floor in this topic mentioned both universal multi-boot is required and uEnv.ini, it's a bit confusing.
Maybe this part should be removed or commented out?
Major change. A new algorithm for the use of the dtb. Starting with this version, you no longer need to copy the dtb files and rename it to "dtb.img." In order to specify which dtb file to use, you need to edit the file 'uEnv.ini" (specify the desired file name for use dtb). This is a plain text file and can be easily edited. This change will make it easy to update the kernel from the "deb" file in the future. The new algorithm is now used in the eMMC system installation script.
Expand
I read your topic about activate universal multi-boot again,
option A
- Connect the prepared media to the device and turn on the power, boot into Android
- Open the app "Update&Backup"
- Click on "Select" local update and chose the file on the removable media aml_autoscript.zip
- Start "Update"
- System will reboot twice and start running the system from external media.
option B
-  try using the "toothpick method"
Expand
However my tv box's Android is corrupted, it won't boot or restored or recovered. So option A is not for me.
Tried option B, but it won't boot with the new build on the MicroSD card.
I try to install to eMMc over the script install-aml.sh - without any errors - then i shutdown the box put the microsd card out and try a boot - black screen ....if i put the microsd back into that device and boot again - it will boot over microsd card
any idea ? what have I done wrong?
how do i access the emmc, do i have to adapt the dtb again?
Expand
Wait for psychics who will guess what model you have, what image, what steps you take, and so on.
Expand
Armbian_20.02.0-rc1.038_Aml-s9xxx_bullseye_current_5.5.0-rc6_20200205
and a F1 A95X with S905W (Before Copy to eMMc - Android 8.1)
Only the script install-aml.sh - i use the p281 dtb file on the microsd
  On 4/1/2020 at 2:06 PM, balbes150 said:
When running, the script displays information on the screen. I need this conclusion.
Expand
root@LBOX:~# bash install-aml.sh
Start script create MBR and filesystem
/dev/mmcblk1
Start backup u-boot default
4+0 records in
4+0 records out
4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.816897 s, 5.1 MB/s
Start create MBR and partittion
Start restore u-boot
442+0 records in
442+0 records out
442 bytes copied, 0.00973483 s, 45.4 kB/s
8191+0 records in
8191+0 records out
4193792 bytes (4.2 MB, 4.0 MiB) copied, 0.536154 s, 7.8 MB/s
Done
Start copy system for eMMC.
Formatting BOOT partition...mkfs.fat 4.1 (2017-01-24)
done.
Cppying BOOT...done.
Edit init config...done.
Formatting ROOT partition...
/dev/mmcblk1p2 contains a ext4 file system labelled 'ROOT_EMMC'
        last mounted on /ddbr/install on Tue Mar 31 21:19:53 2020
e2fsck 1.45.6 (20-Mar-2020)
ROOT_EMMC: clean, 11/895840 files, 82870/3583232 blocks
done.
Copying ROOTFS.
Copy BIN
Create DEV
Copy ETC
Copy HOME
Copy LIB
Create MEDIA
Create MNT
Copy OPT
Create PROC
Copy ROOT
Create RUN
Copy SBIN
Copy SELINUX
Copy SRV
Create SYS
Create TMP
Copy USR
Copy VAR
Copy fstab
Complete copy OS to eMMC
I don't see any critical errors. Try waiting 5-7 minutes for the first launch. Or try using a different DTB.
Expand
but where can i change the dtb for emmc? i know the ini for MicroSD but dont know the folder /path for emmc and why should it be necessary to change it if the one for the microsd card works? does he use a different one when copying?
@balbes150
thanks for your great work!
I have a question:
I run Armbian_20.02.0-rc1.037_Aml-s9xxx_bionic_current_5.5.0-rc6_20200205.img.xz on Tanix-tx5-max, using the dtb provided with the image.
My device has 4gb RAM, but the system shows only 3367852
Is it a known issue?
Any recommendations?
