apollon77 Posted July 30, 2015 Author Posted July 30, 2015 Did you delete your last post with question on uboot? I had installed new uboot as I tried to upgrade to 3.4.108 from 3.4.107. worked without an error. Then I needed to setup /boot newly from sd with the 3.4.108 image if you remember ... is uboot on that or not?! Do I need to install uboot packet manually now (again)?
Igor Posted July 30, 2015 Posted July 30, 2015 Yes I did. It was irrelevant. The problem is that if you are using NAND, you are using NAND uboot. So Uboot is not related - at least not the one on SD card Are you using any "strange" applications?
apollon77 Posted July 30, 2015 Author Posted July 30, 2015 And while fixing my kernel-update problems I installed the nand completely new from sd.SO it should be the correct one as in the 3.4.108 sd-image. Does the rootfs on sata come into play somehow? I use the Cubietruck for home automation. There are two node.js apps running and I installed ups-tools for my apc. I have set up some "Monitoring" where some ports and the IP itself are "Ping"ed every minute to detect if the port or machine goes offline. But nothing more ...
Igor Posted July 30, 2015 Posted July 30, 2015 I am almost out of suggestions. Try two things: - boot from SD and leave everything as is. SATA install yes but not boot from NAND. This part is critical in any case since it's based on some very old boot procedure. - use rather kernel 4.x if you can use with your hardware - change SD card, PSU
apollon77 Posted July 30, 2015 Author Posted July 30, 2015 What would I need to do to boot from sd and use rootfs on sata without ioverwriting all sata content :-) What do I need to change on sd card that rootfs is used from sata?
Igor Posted July 30, 2015 Posted July 30, 2015 If you already have your roofs on sata all you need is to change parameter: from root=/dev/mmcblk0p1 to root=/dev/sda1 inside boot.cmd and conver it to boot.scr.
apollon77 Posted July 30, 2015 Author Posted July 30, 2015 Will all updates and such work after that like normal or do I need to think of special things ?
Igor Posted July 30, 2015 Posted July 30, 2015 No, if you were booting from NAND and running from SATA before.
apollon77 Posted July 30, 2015 Author Posted July 30, 2015 Thwn I will go that way ... will do tomorrow :-) Thank you for all your help!!
apollon77 Posted July 30, 2015 Author Posted July 30, 2015 PS: I hope the "no" meaned that I do NOT need anything special and all updates will work before ...
apollon77 Posted August 1, 2015 Author Posted August 1, 2015 How can I see if the boot was done by SD card? I changed that line and recreated the scr-file and rebootet with sd-card in the slot. Reboot was successfull, but /boot is mounted to /dev/nand1 ... ?! So this is not the correct place at latest when an update should be done, or ?!
Igor Posted August 1, 2015 Posted August 1, 2015 If /dev/nand1 is mounted under boot your SD card boot was most likely ignored. I suggest you to forget about NAND and use good/fast SD card for best performance with less troubles as possible.
apollon77 Posted August 1, 2015 Author Posted August 1, 2015 Yes I want to get away from nand, but I need rootfs on sata because the home-automation applicated make much i/o ... and ideally do not want to need to install everything new :-( Before I changed the boot.scr it was always booted from sd when the card was inserted. Then I changed the rootfs-location and generated new src file and rebooted as you said. Should cleaning /dev/nand1 (where boot is mounted on) bring an effect? Or should I try to resize my sata to have a second partition sda2 and then use fresh sd-boot-image and install to sda2 with script and then change rootfs to sda1 ? Or installing anything new ...?!
Igor Posted August 1, 2015 Posted August 1, 2015 If SD is inserted and there is an u-boot on it than it will always start from SD card. Forget about my install procedures. They are only good for fresh start. 1. Create SD card 2. Boot, wait that it finish first boot 3. Login and alter boot scripts to point root to /dev/sda1 4. Copy /lib/modules/ to /dev/sda1 to make sure you have right modules 5. Reboot I think that's all.
apollon77 Posted August 1, 2015 Author Posted August 1, 2015 Ok, 1. Done 2. Done 3. first line of boot.cmd is now after change: setenv bootargs console=tty1 root=/dev/sda1 rootwait rootfstype=ext4 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reser ve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=1 After this: root@cubietruck:/boot# mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr Image Name: Created: Sat Aug 1 21:30:04 2015 Image Type: ARM Linux Script (uncompressed) Data Size: 1480 Bytes = 1.45 kB = 0.00 MB Load Address: 00000000 Entry Point: 00000000 Contents: Image 0: 1472 Bytes = 1.44 kB = 0.00 MB 4. Were already there 5. Done ... result after reboot: root@cubietruck:~# df Filesystem 1K-blocks Used Available Use% Mounted on rootfs 961433632 1819268 910776288 1% / /dev/root 961433632 1819268 910776288 1% / devtmpfs 1023328 0 1023328 0% /dev tmpfs 131072 252 130820 1% /run tmpfs 5120 0 5120 0% /run/lock tmpfs 131072 0 131072 0% /run/shm /dev/nand1 16334 6010 10324 37% /boot tmpfs 1048576 0 1048576 0% /tmp So effect as before ... Is there any way to check which files used to boot up? Maybe the mountpoint for /boot is stored somewhere on sata and therefor I need to unmount /boot and mount to /boot on sd card one time so that correct files are used?
Igor Posted August 1, 2015 Posted August 1, 2015 Maybe the mountpoint for /boot is stored somewhere on sata and therefor I need to unmount /boot and mount to /boot on sd card one time so that correct files are used? Yes it is Forgot about that, alter /etc/fstab on your hard drive and you are fine.
apollon77 Posted August 1, 2015 Author Posted August 1, 2015 And what would be the correct content for /boot for sd? /dev/mmcblk0p1 /boot vfat defaults 0 2 which I found via google :-)
apollon77 Posted August 3, 2015 Author Posted August 3, 2015 when I do this then the system boots but there is nbo /boot mounted ... hm ... which boot files were used now?
Igor Posted August 3, 2015 Posted August 3, 2015 There is no extra boot partition if you boot from SD. One partition, boot is under /boot
apollon77 Posted August 3, 2015 Author Posted August 3, 2015 But to the question from above: When my rootfs comes from sata and I boot from SD - what do I need to have in my /etc/fstab? I thought that I need to mount the "/boot" directory from SD card as "/boot" in my system in order that the files are correctly used for booting AND also for the next kernel-updates or such that modify filesin the "/boot" on SD ... Or do I missunderstand something completely?
Igor Posted August 3, 2015 Posted August 3, 2015 OK, for proper future updating you need to mount the media of your boot. But if you boot from SD it's a bit more complex. Under /boot you need to mount a directory /boot from SD card - device /dev/mmcblk0p1 /dev/mmcblk0p1 /media/mmc ext4 defaults 0 0 /media/mmc/boot /boot none bind 0 0
apollon77 Posted August 3, 2015 Author Posted August 3, 2015 Hm, still not visible when calling "mount" or "df" ... first ... Then I created /media/mmc as direciry and rebooted again ... now it seems to work: root@cubietruck:~# df Filesystem 1K-blocks Used Available Use% Mounted on rootfs 961433632 1830376 910765180 1% / /dev/root 961433632 1830376 910765180 1% / devtmpfs 1023328 0 1023328 0% /dev tmpfs 131072 256 130816 1% /run tmpfs 5120 0 5120 0% /run/lock tmpfs 131072 0 131072 0% /run/shm /dev/mmcblk0p1 30687916 971196 28464012 4% /media/mmc /dev/mmcblk0p1 30687916 971196 28464012 4% /boot tmpfs 1048576 0 1048576 0% /tmp So solved mow. You are great!! Thank you for all your help!!
apollon77 Posted August 3, 2015 Author Posted August 3, 2015 I can remove all other files from sd except /boot ... correct?!
