otimp2 Posted August 22, 2018 Share Posted August 22, 2018 I tested with Armbian Stretch image on NanoPi-NEO-Core2. PJSIP VoIP Client. MIC input does not work. Additional USB sound cards work well. In FriendelyARM original firmware, MIC input works well. I hope that this issue will be resolved. Please help me. Link to comment Share on other sites More sharing options...
otimp2 Posted August 23, 2018 Author Share Posted August 23, 2018 The NanoPiDuo board is the same symptom. The following logs are left. root@nanopiduo:~# arecord -vv -f dat /dev/null Recording WAVE '/dev/null' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo Plug PCM: Hardware PCM card 0 'H3 Audio Codec' device 0 subdevice 0 Its setup is: stream : CAPTURE access : RW_INTERLEAVED format : S16_LE subformat : STD channels : 2 rate : 48000 exact rate : 48000 (48000/1) msbits : 16 buffer_size : 24000 period_size : 6000 period_time : 125000 tstamp_mode : NONE tstamp_type : MONOTONIC period_step : 1 avail_min : 6000 period_event : 0 start_threshold : 1 stop_threshold : 24000 silence_threshold: 0 silence_size : 0 boundary : 1572864000 appl_ptr : 0 hw_ptr : 0 arecord: pcm_read:2103: read error: Input/output error root@nanopiduo:~# aplay -l **** List of PLAYBACK Hardware Devices **** card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 root@nanopiduo:~# Link to comment Share on other sites More sharing options...
Igor Posted August 23, 2018 Share Posted August 23, 2018 On 8/22/2018 at 2:26 AM, otimp2 said: Please help me. Which kernel version were you using here and there? Link to comment Share on other sites More sharing options...
otimp2 Posted August 24, 2018 Author Share Posted August 24, 2018 22 hours ago, Igor said: 어떤 커널 버전을 사용하고 있습니까? I am useing "Armbian_5.59_Nanopineocore2_Debian_stretch_next_4.14.65.7z" image. Link to comment Share on other sites More sharing options...
Igor Posted August 24, 2018 Share Posted August 24, 2018 On 8/22/2018 at 2:26 AM, otimp2 said: In FriendelyARM original firmware, MIC input works well. And which was the original firmware? Was it kernel 3.10.y? Link to comment Share on other sites More sharing options...
tkaiser Posted August 24, 2018 Share Posted August 24, 2018 53 minutes ago, Igor said: which was the original firmware? Was it kernel 3.10.y? They abandoned 3.10 pretty early and there was never support for the Core2 based on Allwinner's BSP. They started with 4.11 and are now at 4.14 (based on @megous branches): https://github.com/friendlyarm/linux/commits/sunxi-4.14.y Link to comment Share on other sites More sharing options...
Igor Posted August 24, 2018 Share Posted August 24, 2018 16 minutes ago, tkaiser said: They abandoned 3.10 pretty early and there was never support for the Core2 based on Allwinner's BSP. They started with 4.11 and are now at 4.14 (based on @megous branches): https://github.com/friendlyarm/linux/commits/sunxi-4.14.y Perhaps we could use this for our NEXT/4.14.y branch? It shouldn't be worse. Link to comment Share on other sites More sharing options...
tkaiser Posted August 24, 2018 Share Posted August 24, 2018 1 hour ago, Igor said: Perhaps we could use this for our NEXT/4.14.y branch? It shouldn't be worse Well, I believe FriendlyELEC did as much as possible to support their own H3 and H5 boards (partially doing things incompatible to upstream kernel/u-boot -- see their way to define DRAM clockspeeds and automagically detect the boards based on specific pin settings) but I doubt they ever took care about other platforms than H3/H5. So no idea how much efforts it would take for this stuff to work since some of their stuff relies on using their (patched) u-boot anyway (of course me not being that interested in Allwinner hardware any more -- my only hope is that Armbian follows a conservative upgrade policiy and bricked boards after kernel or u-boot updates will never happen again) Link to comment Share on other sites More sharing options...
otimp2 Posted October 30, 2018 Author Share Posted October 30, 2018 The same problem is still continuing. The first is the abnormal operation status log, and the second is the normal operation status log. The first one works with the Armbian Debian_stretch_next_4.14.78 firmware and the second one with the FrandelyARM firmware. Is there any way to improve this? Log #1 root@nanopineo:~# arecord -vv -f dat /dev/null Recording WAVE '/dev/null' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo Plug PCM: Hardware PCM card 0 'H3 Audio Codec' device 0 subdevice 0 Its setup is: stream : CAPTURE access : RW_INTERLEAVED format : S16_LE subformat : STD channels : 2 rate : 48000 exact rate : 48000 (48000/1) msbits : 16 buffer_size : 24000 period_size : 6000 period_time : 125000 tstamp_mode : NONE tstamp_type : MONOTONIC period_step : 1 avail_min : 6000 period_event : 0 start_threshold : 1 stop_threshold : 24000 silence_threshold: 0 silence_size : 0 boundary : 1572864000 appl_ptr : 0 hw_ptr : 0arecord: pcm_read:2103: read error: Input/output error Log #2 root@NanoPi-NEO-Core:~# arecord -vv -f dat /dev/null Recording WAVE '/dev/null' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo Hardware PCM card 2 'H3 Audio Codec' device 0 subdevice 0 Its setup is: stream : CAPTURE access : RW_INTERLEAVED format : S16_LE subformat : STD channels : 2 rate : 48000 exact rate : 48000 (48000/1) msbits : 16 buffer_size : 24000 period_size : 6000 period_time : 125000 tstamp_mode : NONE tstamp_type : MONOTONIC period_step : 1 avail_min : 6000 period_event : 0 start_threshold : 1 stop_threshold : 24000 silence_threshold: 0 silence_size : 0 boundary : 1572864000 appl_ptr : 0 hw_ptr : 0##+ | 02%^C Aborted by signal Interrupt... # + | 02% Link to comment Share on other sites More sharing options...
otimp2 Posted October 30, 2018 Author Share Posted October 30, 2018 This issue is common to the NanoPi NEO Duo (H2 + Core) / NanoPi NEO Core (H3 Core) / NanoPi NEO Core2 (H5 Core). Link to comment Share on other sites More sharing options...
OpenglMan Posted August 19, 2019 Share Posted August 19, 2019 Solution for MIC not working in H5 Boards For H5 boards with Armbian Mainline Kernel, 4.19.67-sunxi64 #5.94 SMP Sun Aug 18 14:35:13 EDT 2019 aarch64 GNU/Linux The solution can be found at the end of this other following post... https://forum.armbian.com/topic/7216-orange-pi-zero-problem-with-onboard-soundcard/ Link to comment Share on other sites More sharing options...
