erazor Posted August 22, 2018 Posted August 22, 2018 Hi there, I got some NanoPi-NEO running and need to update the kernel, modules and dtb's. With 4.18 the Ethernet does not seem to get started correctly. I noticed a change in u-boot and the newer Armbian releases have Ethernet-Support in u-boot. So my basic idea is to not just copy the kernel files but also update u-boot via dd command. I suppose there are at least 3 regions in the image: 1. the partition table which I don't want to change. 2. the u-boot configuration which I'd like to keep. 3. the u-boot runtime. So for #2 and #3 I'll need an image file. I'm trying to set-up a build environment for Armbian but what I'm probably missing is the offset and count parameters for dd. Is there some kind of "HowTo update u-boot for H3" somewhere? Thanks for your help.
Igor Posted August 22, 2018 Posted August 22, 2018 1 hour ago, erazor said: Is there some kind of "HowTo update u-boot for H3" somewhere? Thanks for your help. If you use armbian, this is all done standard way, via packages. We have a post-install script which does the actual update. If you want to understand details about the boot process, peek here .
erazor Posted August 27, 2018 Author Posted August 27, 2018 I simply copied the uboot stuff from an existing image: # dd if=mmcblk0_new of=/dev/mmcblk0 bs=1024 skip=8 seek=8 count=$((1024-8)) I got the numbers from http://linux-sunxi.org/Bootable_SD_card : 1 block = 1024 bytes (-> bs=1024) first 8 blocks is MBR + partition-table (-> skip=8 seek=8) first partition starts at 1024 blocks (-> count=$((1024-8)))
martinayotte Posted August 27, 2018 Posted August 27, 2018 Don't do "skip" and "seek" on the same command, use "skip" only when doing backup and "seek" only on the restore.
