cond080 Posted August 27, 2018 Posted August 27, 2018 hello there! after update rpimonitor to 2.13-beta6 by Xavier Berger, can't monitor, any temperature , memory usage. But CPU freq, Sd card and network work OK. my spec : Orange pi pc + ARMBIAN 5.38 stable Ubuntu 16.04.5 LTS 3.4.113-sun8i
Igor Posted August 27, 2018 Posted August 27, 2018 And if you install the previous version https://github.com/XavierBerger/RPi-Monitor-deb/tree/develop/packages is ok?
cond080 Posted August 27, 2018 Author Posted August 27, 2018 can't do this, it says sudo dpkg --install rpimonitor_2.9.1-1_all.deb dpkg-deb: error: 'rpimonitor_2.9.1-1_all.deb' is not a debian format archive sorry I not very good in linux
cond080 Posted August 27, 2018 Author Posted August 27, 2018 I tried also : sudo aptitude install rpimonitor=2.9.1 no luck, it want install version 2.13-beta6
Igor Posted August 27, 2018 Posted August 27, 2018 wget https://rawgit.com/XavierBerger/RPi-Monitor-deb/develop/packages/rpimonitor_2.12-r0_all.deb dpkg -i rpimonitor_2.12-r0_all.deb
cond080 Posted August 27, 2018 Author Posted August 27, 2018 something missing after installation, I guess some dependencies web interface shows ERROR: Can not get information (dynamic.json) from RPi-Monitor server.
cond080 Posted August 27, 2018 Author Posted August 27, 2018 Oh I forgot to say I did : sudo apt autoremove rpimonitor to completely remove rpimonitor to install it fresh
cond080 Posted August 27, 2018 Author Posted August 27, 2018 shoud I install rpimonitor first with dependencies and then . downgrade it with .dpkg -i rpimonitor_2.12-r0_all.deb . ?
cond080 Posted August 27, 2018 Author Posted August 27, 2018 error output: sudo dpkg -i rpimonitor_2.12-r0_all.deb Selecting previously unselected package rpimonitor. (Reading database ... 74105 files and directories currently installed.) Preparing to unpack rpimonitor_2.12-r0_all.deb ... Unpacking rpimonitor (2.12-r0) ... dpkg: dependency problems prevent configuration of rpimonitor: rpimonitor depends on librrds-perl; however: Package librrds-perl is not installed. rpimonitor depends on libhttp-daemon-perl (>= 6.0.0) | libwww-perl (<< 6.0.0); however: Package libhttp-daemon-perl is not installed. Package libwww-perl is not installed. rpimonitor depends on libjson-perl; however: Package libjson-perl is not installed. rpimonitor depends on libipc-sharelite-perl; however: Package libipc-sharelite-perl is not installed. rpimonitor depends on libfile-which-perl; however: Package libfile-which-perl is not installed. dpkg: error processing package rpimonitor (--install): dependency problems - leaving unconfigured Processing triggers for systemd (229-4ubuntu21.4) ... Processing triggers for ureadahead (0.100.0-19) ... Processing triggers for man-db (2.7.5-1) ... Errors were encountered while processing: rpimonitor
cond080 Posted August 28, 2018 Author Posted August 28, 2018 please share template folder from orange pi pc+ etc/rpimonitor/template
Goerlitzer Posted August 29, 2018 Posted August 29, 2018 The same with NanoPi neo. After upgrade no temperature. After I installed the rpimonitor (2.12-r0) version, no data is shown.
Igor Posted August 29, 2018 Posted August 29, 2018 6 minutes ago, Goerlitzer said: The same with NanoPi neo. After upgrade no temperature. After I installed the rpimonitor (2.12-r0) version, no data is shown. 2.13-beta6 version was removed from the repository. That's all that can be done.
