Igor Posted September 25, 2018 Posted September 25, 2018 On 9/24/2018 at 7:51 AM, FoodGenius said: would be nice to publish these images in https://dl.armbian.com/espressobin/u-boot/ in a subfolder "rescue". Expand Done. Do we have some quick sum of how to use them? BTW. I received a new board today but it still has Winbond flash. It was also mentioned that it will be probably a 4G model, but it's 1G. Basically, it is the same model that I already have with some changes to PCB which need to be inspected. Reveal hidden contents
ebin-dev Posted September 25, 2018 Posted September 25, 2018 On 9/25/2018 at 11:51 AM, Igor said: BTW. I received a new board today but it still has Winbond flash. It was also mentioned that it will be probably a 4G model, but it's 1G. Basically, it is the same model that I already have with some changes to PCB which need to be inspected. Expand So it is a system still with two ddr ram chips - and it comes with a huge heat sink :-)) .
ebin-dev Posted September 26, 2018 Posted September 26, 2018 On 9/25/2018 at 11:51 AM, Igor said: Do we have some quick sum of how to use them? Expand Along the lines of the summary provided by FoodGenius, recovery with these UART images should work like this: * jumper your board to "UART-Bootmode" * use a terminal and connect to espressobin by usb * you now see the recovery prompt ">" instead of "Marvell>>" so type the command 'wtp' followed by enter. board is now in a mode to receive the temporary bootloader.. so close the terminal. * use the marvell tool to flash the UART recovery images to RAM ./WtpDownload_linux -P UART -C 0 -R 115200 -B TIM_ATF.bin -I wtmi_h.bin -I boot-image_h.bin -E * reset the board.
skandalfo Posted September 27, 2018 Posted September 27, 2018 On 9/26/2018 at 3:55 PM, ebin-dev said: ./WtpDownload_linux -P UART -C 0 -R 115200 -B TIM_ATF.bin -I wtmi_h.bin -I boot-image_h.bin -E * reset the board. Expand Not enough. The recovery image is loaded to RAM only, so when you reset it goes away and you boot again from a borked image once jumpers are back to normal. What you need to do is use the image in RAM you just booted from to flash a good one to SPI. After WtpDownload finishes, going back to the serial terminal and pressing enter a couple of times should give you a working uboot prompt (with your UART image that now can write to your flash). From there you should be able to use the bubt command like explained here, or some other of the commands in that page to make your changes permanent. 1
skandalfo Posted September 29, 2018 Posted September 29, 2018 So, I just checked that I could use the images in this folder to flash the current ones in its grand-parent one, and that I still was able to boot from the Armbian already installed in my SD card with a Macronix chip. Thanks a lot for these fixed images! Steps: Had to use miniterm: miniterm --eol CR /dev/ttyUSB0 115200 rather than minicom. Minicom would interfere with the transfer from WtpDownload by trying to reopen the serial port once it had lost it; and then WtpDownload_linux would get interrupted. Set the jumpers for UART recovery and powered the board. In miniterm I hit enter until I got the E prompt, then entered "wtp". Then I ran the upload: <path>/<to>/WtpDownload_linux -P UART -C 0 -R 115200 -B TIM_ATF.bin -I wtmi_h.bin -I boot-image_h.bin -E As my bootable SD card was in, the just-downloaded bootloader in RAM would quickly go and start Linux from the SD card. If your EspressoBIN is borked, you probably should just remove any boot device. In my case I didn't bother; I just restarted miniterm quickly after WtpDownload had finished and pressed enter a number of times to interrupt the boot sequence. I plugged in a USB stick with flash-image-2g-2cs-1000_800.bin in it. I flashed it to SPI: Marvell>> bubt flash-image-2g-2cs-1000_800.bin spi usb Burning U-BOOT image "flash-image-2g-2cs-1000_800.bin" from "usb" to "spi" USB0: Register 2000104 NbrPorts 2 Starting the controller USB XHCI 1.00 USB1: USB EHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 1 for devices... 2 USB Device(s) found reading flash-image-2g-2cs-1000_800.bin Image checksum...OK! SF: Detected mx25u3235f with page size 256 Bytes, erase size 64 KiB, total 4 MiB Updating, 8% 126859 B/s Updating, 16% 127704 B/s Updating, 31% 167458 B/s Updating, 39% 155994 B/s 262144 bytes written, 593344 bytes skipped in 2.249s, speed 389342 B/s Done! I then powered the board off, switched the boot jumpers back to their default position, and powered it on again. The board booted Armbian from SD card as usual. 2
