Rex Posted August 30, 2018 Posted August 30, 2018 Dear all I am using BPI-M3 this board I got some questions first I can't use Uart other than Debug Uart (maybe Uart1 or Uart2) Debug Uart can call /dev/ttyS0 use it i don't know how to driver /dev/ttyS1~7 so GPIO header pin 8 /10 only have normal GPIO features and i install Armbian_5.55_Bananapim3_Debian_stretch_next_4.17.12 i try to use WiringPI control my GPIO pin is can be work [git clone https://github.com/BPI-SINOVOIP/BPI-WiringPi.git -b BPI_M3] but now i install Armbian_5.59.180823_Bananapim3_Debian_stretch_dev_4.18.4 and Armbian_5.59_Bananapim3_Debian_stretch_dev_4.18.5 install WiringPi and WiringPi2 can't Work for this Version ==== gpio version: 2.26 Copyright (c) 2012-2015 Gordon Henderson This is free software with ABSOLUTELY NO WARRANTY. For details type: gpio -warranty Unable to determine hardware version. I see: Hardware : Allwinner A83t board , - expecting BCM2708 or BCM2709. Please report this to projects@drogon.net ==== gpio version: 2.44 Copyright (c) 2012-2017 Gordon Henderson This is free software with ABSOLUTELY NO WARRANTY. For details type: gpio -warranty Unable to determine hardware version. I see: Hardware : Allwinner A83t board , - expecting BCM2708, BCM2709 or BCM2835. If this is a genuine Raspberry Pi then please report this to projects@drogon.net. If this is not a Raspberry Pi then you are on your own as wiringPi is designed to support the Raspberry Pi ONLY. ==== why ? I need some answers about these thank for all!
Igor Posted August 30, 2018 Posted August 30, 2018 On 8/30/2018 at 2:47 PM, Rex said: can't Work for this Version Expand This image is not supported which means you are more or less on your own. Perhaps there will be others who will be interesting to push this board forward. We manipulate board functions with overlays, but A83T is not supported and we have no plans to devel that. This means you need to edit DT manually to enable/disable this and that. For wiring pi to work you will need to have patched kernel or patched wiring pi. Extra, since they, Banana folks, adjust it for their prehistoric kernel.
