i like to work with 1wire 18b20 sensors on my Oragne Pi one , with the latest Armbian Bionic .
root@orangepione:~# uname -r
4.14.65-sunxi
In this forum and in the orange pi forum, there are some instructions, but I think they are out of date.
1.edit your /etc/default/cpufrequtils
After edit.
$ cat /etc/default/cpufrequtils
ENABLE=true
MIN_SPEED=480000
MAX_SPEED=1200000
GOVERNOR=interactive
2.reboot
Edited by nopnop2002 at 2017-8-5 17:10
After edit.
ENABLE=true
MIN_SPEED=480000
MAX_SPEED=1200000
2.reboot
3.driver load
sudo modprobe w1-gpio
sudo modprobe w1-therm
Until here, this works but then I get:
# sudo modprobe w1-sunxi
modprobe: FATAL: Module w1-sunxi not found in directory /lib/modules/4.14.65-sunxi
I aktivated W1 gpio in armbian-config/system/hardware
this is the output of dmesg:
[    1.245629] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
[    1.245640] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000)
[    1.245985] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
[    1.247906] NOHZ: local_softirq_pending 80
[    1.248715] NOHZ: local_softirq_pending 02
[    1.249027] of_cfs_init
[    1.249111] of_cfs_init: OK
[    1.249216] vdd-cpux-dummy: disabling
[    1.249220] vcc3v0: disabling
[    1.249225] vcc5v0: disabling
[    1.249227] usb0-vbus: disabling
[    1.251585] Freeing unused kernel memory: 1024K
[    1.317269] NOHZ: local_softirq_pending 80
[    1.321935] NOHZ: local_softirq_pending 80
[    1.327276] NOHZ: local_softirq_pending 80
[    1.332280] NOHZ: local_softirq_pending 80
[    1.831391] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.831398] [drm] No driver support for vblank timestamp query.
[    1.841228] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_platform_driver_exit [sun8i_mixer])
[    1.841528] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[    1.841549] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops sun4i_tcon_platform_driver_exit [sun4i_tcon])
[    1.966469] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
[    1.967468] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
[    1.967817] sun4i-drm display-engine: bound 1ee0000.hdmi (ops sun8i_dw_hdmi_ops [sun8i_dw_hdmi])
[    1.967857] [drm] Cannot find any crtc or sizes
[    1.968291] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    2.091399] rc_core: IR keymap rc-cec not found
[    2.091420] Registered IR keymap rc-empty
[    2.091827] rc rc0: RC for dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0
[    2.092441] input: RC for dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0/input0
[    2.499851] random: fast init done
[    2.531421] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    3.006461] [drm] Cannot find any crtc or sizes
[    3.242165] systemd[1]: System time before build time, advancing clock.
[    3.280369] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.303396] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    3.304234] systemd[1]: Detected architecture arm.
[    3.343442] systemd[1]: Set hostname to <orangepione>.
[    4.097778] random: systemd: uninitialized urandom read (16 bytes read)
[    4.104921] systemd[1]: Created slice System Slice.
[    4.106034] random: systemd: uninitialized urandom read (16 bytes read)
[    4.106314] systemd[1]: Listening on Journal Audit Socket.
[    4.106607] random: systemd: uninitialized urandom read (16 bytes read)
[    4.106852] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.107954] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    4.108581] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    4.109049] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    4.109338] systemd[1]: Reached target Swap.
[    4.238551] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    4.459317] systemd-journald[232]: Received request to flush runtime journal from PID 1
[    4.918711] Driver for 1-wire Dallas network protocol.
[    5.078820] thermal thermal_zone0: failed to read out thermal zone (-110)
[    5.166527] asoc-simple-card sound: i2s-hifi <-> 1c22800.i2s mapping ok
[    5.407723] zram: Added device: zram0
[    5.421363] zram: Added device: zram1
[    5.423905] zram: Added device: zram2
[    5.424657] zram: Added device: zram3
[    5.425578] zram: Added device: zram4
[    5.680041] zram1: detected capacity change from 0 to 64659456
[    6.145450] thermal thermal_zone0: failed to read out thermal zone (-110)
[    6.505614] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search.
[    6.753330] random: crng init done
[    6.753342] random: 7 urandom warning(s) missed due to ratelimiting
[    6.778463] Adding 63140k swap on /dev/zram1.  Priority:5 extents:1 across:63140k SSFS
[    6.780763] zram2: detected capacity change from 0 to 64659456
[    6.798117] Adding 63140k swap on /dev/zram2.  Priority:5 extents:1 across:63140k SSFS
[    6.800323] zram3: detected capacity change from 0 to 64659456
[    6.817613] Adding 63140k swap on /dev/zram3.  Priority:5 extents:1 across:63140k SSFS
[    6.819763] zram4: detected capacity change from 0 to 64659456
[    6.837622] Adding 63140k swap on /dev/zram4.  Priority:5 extents:1 across:63140k SSFS
[    6.875993] zram0: detected capacity change from 0 to 52428800
[    7.166308] EXT4-fs (zram0): mounted filesystem without journal. Opts: (null)
[    7.166323] thermal thermal_zone0: failed to read out thermal zone (-110)
[    8.472331] Generic PHY 0.1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0.1:01, irq=POLL)
[    8.486641] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[    8.486658] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[    8.487103] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   11.582988] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   11.583031] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   51.682236] w1_master_driver w1_bus_master1: Attaching one wire slave 00.800000000000 crc 8c
[   51.686179] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered.
[  107.822458] w1_master_driver w1_bus_master1: Attaching one wire slave 00.400000000000 crc 46
[  107.826367] w1_master_driver w1_bus_master1: Family 0 for 00.400000000000.46 is not registered.
[  152.680655] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c00000000000 crc ca
[  152.684609] w1_master_driver w1_bus_master1: Family 0 for 00.c00000000000.ca is not registered.
[  220.102887] w1_master_driver w1_bus_master1: Attaching one wire slave 00.200000000000 crc 23
[  220.106738] w1_master_driver w1_bus_master1: Family 0 for 00.200000000000.23 is not registered.
[  276.242980] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a00000000000 crc af
[  276.246926] w1_master_driver w1_bus_master1: Family 0 for 00.a00000000000.af is not registered.
[  309.798495] w1_master_driver w1_bus_master1: Attaching one wire slave 00.600000000000 crc 65
[  309.806800] w1_master_driver w1_bus_master1: Family 0 for 00.600000000000.65 is not registered.
I cant find the gpio for 1 wire like this:
$dmesg
[   34.067409] W1_SUNXI: Added w1-gpio on GPIO-10
so how I can find the right pin to use 1wire
pls help
thx
maybe the instructions are for older kernels. on bionic it possible that are some features are missing/dont work, because is mostly in testing/dev state
