mark99 Posted September 6, 2018 Posted September 6, 2018 (edited) Hello, I am the owner of this board. I have some questions for developers 1. when will the reboot fix and what is the problem? 2 after last upgrading to 5.59.180904, armbian is no longer loaded at all. log the error: [ 2.319975] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.18 [ 2.328255] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.335488] usb usb5: Product: MUSB HDRC host driver [ 2.340462] usb usb5: Manufacturer: Linux 4.18.5-sunxi64 musb-hcd [ 2.346562] usb usb5: SerialNumber: musb-hdrc.1.auto [ 2.351855] hub 5-0:1.0: USB hub found [ 2.355641] hub 5-0:1.0: 1 port detected [ 2.360991] sunxi-mmc 4020000.mmc: Got CD GPIO [ 2.390847] sunxi-mmc 4020000.mmc: base:0x(____ptrval____) irq:11 [ 2.397105] vcc-gmac-3v3: supplied by vcc-ac200 [ 2.402360] dwmac-sun8i 5020000.ethernet: PTP uses main clock [ 2.408239] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000000 [ 2.417031] Mem abort info: [ 2.419835] ESR = 0x96000004 [ 2.422899] Exception class = DABT (current EL), IL = 32 bits [ 2.428824] SET = 0, FnV = 0 [ 2.431887] EA = 0, S1PTW = 0 [ 2.435036] Data abort info: [ 2.437923] ISV = 0, ISS = 0x00000004 [ 2.441768] CM = 0, WnR = 0 [ 2.444744] [0000000000000000] user address but active_mm is swapper [ 2.451105] Internal error: Oops: 96000004 [#1] SMP [ 2.455980] Modules linked in: [ 2.459039] CPU: 3 PID: 36 Comm: kworker/3:1 Not tainted 4.18.5-sunxi64 #155 [ 2.466081] Hardware name: Orange Pi One+ (DT) [ 2.470531] Workqueue: events deferred_probe_work_func [ 2.475669] pstate: 80000005 (Nzcv daif -PAN -UAO) [ 2.480460] pc : sun8i_dwmac_probe+0x164/0x518 [ 2.484903] lr : sun8i_dwmac_probe+0x20c/0x518 [ 2.489343] sp : ffff00000907bb30 [ 2.492656] x29: ffff00000907bb30 x28: 0000000000000000 [ 2.497966] x27: 0000000000000000 x26: ffff000008b7d878 [ 2.503278] x25: ffff800037fe5268 x24: ffff800036bcbc10 [ 2.508588] x23: ffff800036bcbc00 x22: ffff80003509b018 [ 2.513900] x21: ffff8000361a6218 x20: ffff000008bcf000 [ 2.519211] x19: ffff000008d08000 x18: ffffffffffffffff [ 2.524521] x17: ffff0000089f8c98 x16: ffff0000089f8c98 [ 2.529832] x15: ffff000008d088c8 x14: ffff000008c0d000 [ 2.535142] x13: 0000000000000008 x12: 0000000000000030 [ 2.540452] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f [ 2.545763] x9 : feff727264626260 x8 : ffff00000907b808 [ 2.551073] x7 : 0000000000000000 x6 : 0000000000000003 [ 2.556384] x5 : 0000000000000002 x4 : 0000000000000003 [ 2.561694] x3 : 0000000000000000 x2 : ffff00000907bba0 [ 2.567005] x1 : ffff80003509b400 x0 : ffff800036bcbc10 [ 2.572318] Process kworker/3:1 (pid: 36, stack limit = 0x(____ptrval____)) [ 2.579273] Call trace: [ 2.581721] sun8i_dwmac_probe+0x164/0x518 [ 2.585816] platform_drv_probe+0x50/0xa0 [ 2.589824] driver_probe_device+0x21c/0x2f8 [ 2.594093] __device_attach_driver+0x98/0xf0 [ 2.598450] bus_for_each_drv+0x64/0xc8 [ 2.602285] __device_attach+0xd8/0x130 [ 2.606120] device_initial_probe+0x10/0x18 [ 2.610302] bus_probe_device+0x90/0x98 [ 2.614136] deferred_probe_work_func+0x9c/0x140 [ 2.618756] process_one_work+0x1e8/0x338 [ 2.622765] worker_thread+0x240/0x478 [ 2.626514] kthread+0x128/0x130 [ 2.629743] ret_from_fork+0x10/0x18 [ 2.633321] Code: f94012a3 9101c3a2 aa1803e0 f9400463 (a9401464) [ 2.639411] ---[ end trace e3ce312d880ab2e3 ]--- [ 2.692531] mmc0: host does not support reading read-only switch, assuming write-enable [ 2.704156] mmc0: new high speed SDHC card at address 59b4 [ 2.710547] mmcblk0: mmc0:59b4 SD16G 14.7 GiB [ 2.716648] mmcblk0: p1 thanks to the developers for the firmware, I can work as a tester, if necessary Also the question such is: on an official image of ubuntu server in half of cases loading is interrupted by such log. is it a hardware problem or a bootloader problem? On armbian no such. In any case, on aliexpress I demanded compensation that I can not use the fee as intended at the moment [49]HELLO! BOOT0 is starting! [53]boot0 commit : 8 [66]PMU: AXP806 [70]set pll start [73]set pll end [74]rtc[0] value = 0x00000000 [77]rtc[1] value = 0x00000000 [80]rtc[2] value = 0x0000000f [83]rtc[3] value = 0x0000a102 [86]rtc[4] value = 0x00000000 [89]rtc[5] value = 0x00000000 [92]DRAM VERSION IS V2_1 [94]PMU:Set DDR Vol 1200mV OK. [97]PMU:Set DDR Vol 1200mV OK. [102]BYTE0 GATE ERRO IS = 00000002 [105]BYTE1 GATE ERRO IS = 00000002 [109]BYTE2 GATE ERRO IS = 00000002 [112]BYTE3 GATE ERRO IS = 00000002 [117]BYTE0 GATE ERRO IS = 00000000 [121]BYTE1 GATE ERRO IS = 00000000 [124]BYTE2 GATE ERRO IS = 00000000 [127]BYTE3 GATE ERRO IS = 00000000 [131]scan dram size fail ! [134]initializing SDRAM Fail. Edited September 6, 2018 by mark99
mark99 Posted September 7, 2018 Author Posted September 7, 2018 12 hours ago, Igor said: What is the name of the image you start with? Armbian_5.59.180824_Orangepioneplus_Debian_stretch_dev_4.18.0-rc7.img md5 CA60139D4E2DDF1EFF8D1B7B9AEBCA51 sha1 AC0711F79048569F963A072FBDC4CBC7D705923F
Igor Posted September 7, 2018 Posted September 7, 2018 6 minutes ago, mark99 said: Armbian_5.59.180824_Orangepioneplus_Debian_stretch_dev_4.18.0-rc7.img Strange. It works fine for me: http://ix.io/1m57 (build from sources yesterday) Well, those builds are still in their early phase. I also had issues that sometimes it doesn't boot at all and it stuck on reboot plus probably more unknown issues.
mark99 Posted September 7, 2018 Author Posted September 7, 2018 2 minutes ago, Igor said: Strange. It works fine for me: http://ix.io/1m57 (build from sources yesterday) Well, those builds are still in their early phase. I also had issues that sometimes it doesn't boot at all and it stuck on reboot plus probably more unknown issues. If there are important fixes in the update, could you lay out the full image for installation? Another reboot-related issue, when will the issue be resolved?
Igor Posted September 7, 2018 Posted September 7, 2018 Just now, mark99 said: If there are important fixes in the update, could you lay out the full image for installation? No, we don't provide support for development versions - it is too expensive. They work or not. You need to build an image on your own. 1 minute ago, mark99 said: Another reboot-related issue, when will the issue be resolved? Perhaps next week, this year, perhaps it is already solved but needs to be implemented. In any case, I can't answer such questions. This is best effort amateur development. Anything you do for the project helps that issues are solved faster. That's all.
mark99 Posted September 7, 2018 Author Posted September 7, 2018 1 minute ago, Igor said: Perhaps next week, this year, perhaps it is already solved but needs to be implemented. In any case, I can't answer such questions. This is best effort amateur development. Anything you do for the project helps that issues are solved faster. That's all. If you want, I can test any build, but to build my own yet necessary skills. In any case, thank you for the firmware.
Igor Posted September 7, 2018 Posted September 7, 2018 1 minute ago, mark99 said: If you want, I can test any build, but to build my own yet necessary skills. In any case, thank you for the firmware. Check if you have any board that is missing here (https://beta.armbian.com/buildlogs/report.html): https://github.com/armbian/testings
mark99 Posted September 7, 2018 Author Posted September 7, 2018 47 minutes ago, Igor said: Check if you have any board that is missing here (https://beta.armbian.com/buildlogs/report.html): https://github.com/armbian/testings I do not see orangepi one plus, I just have it
Igor Posted September 7, 2018 Posted September 7, 2018 1 minute ago, mark99 said: I do not see orangepi one plus, I just have it Look once again
gounthar Posted September 18, 2018 Posted September 18, 2018 Is this build supposed to have something display on screen, or just on the console? My screen power button blinks (ready/sleeping/...). Thanks.
Igor Posted September 18, 2018 Posted September 18, 2018 1 hour ago, gounthar said: just on the console? Console only.
OMTDesign Posted September 19, 2018 Posted September 19, 2018 Hello fellow OrangePi One Plus owners! Do the power indicator lights work for any of you? When I use armbian 4.18rc7 bionic it doesn't light up, but when using provided image from OrangePi, they work. Also I am having trouble trying to start the system for a second time? I when I first write the armbian image to the SDcard, and turn of my OrangePi, it boots and works fine. But after I shut it down, and then try to boot up again the system hangs at the boot screen. I see that Igor said that it is best to build the image myself, which I will try right now. Thanks
Igor Posted September 19, 2018 Posted September 19, 2018 3 hours ago, OMTDesign said: Hello fellow OrangePi One Plus owners! Do the power indicator lights work for any of you? When I use armbian 4.18rc7 bionic it doesn't light up, but when using provided image from OrangePi, they work. Also I am having trouble trying to start the system for a second time? I when I first write the armbian image to the SDcard, and turn of my OrangePi, it boots and works fine. But after I shut it down, and then try to boot up again the system hangs at the boot screen. I see that Igor said that it is best to build the image myself, which I will try right now. Thanks Lower your expectations. (modern) kernel for this board is still months away. Provided images are good only for testing, experimenting and development. 1
