Hi!
I'm using Banana PI and latest Armbian_5.00_Bananapi_Debian_jessie_3.4.110.  SInce it came without xservert and fact that I like to only use board in "kiosk" mode, I should execute only couple of application which use xserver. One is matchbox-keyboad and other is pyQT application. So....
Using apt-cache search xfce I got list of packages for xfce desktop. So I presume i have to install at least:
xfce4 - Meta-package for the Xfce Lightweight Desktop Environment
xfconf - utilities for managing settings in Xfce
xfwm4 - window manager of the Xfce project
xfe - lightweight file manager for X11
Since I'm newbee in linux I'd like to know what I have to installl, just to execute "graphical" application withot whole desktop?
Thank you!
Mladen
Latest?
1) http://www.armbian.com/banana-pi-pro/(5.04 trusty comes with desktop acceleration)
2) http://www.armbian.com/documentation/("How to upgrade into simple desktop environment?")
apt-get -y install xorg lightdm xfce4 tango-icon-theme gnome-icon-theme
reboot
Check this site for others.
(just quoted from the documentation link above)
Hi  tkaiser.
Thank you for fast response !
Regarding image I'm not sure is possibel to install banana pi pro files to "simple" banana pi. I downloaded mentioned image from Igor's FTP http://mirror.igorpecovnik.com/
However, I installed all files you suggested and it's work great.... But   :(
That is not wnat I ment, sorry.  What I ment is to just execute one graphical application without loading desktop. How's that possible ?
Igor switched to the Banana Pro being the default (since when we ship one image for Banana Pi/Pro/M1/M1+ we ship with activated WiFi settings/driver and can then detect whether we're running on Pro/M1+ or Pi/M1). But I would believe here's a small piece of code missing: https://github.com/igorpecovnik/lib/blob/master/scripts/firstrun#L97-L100since the script.bin link and/or dtb/dts should be replaced when running on Banana Pi/M1.
Regarding your desktop/graphical questions I fear I can't help (most of the times I run the boards headless and quite a few of them were never connected to a display over years :) )
  On 3/12/2016 at 7:34 PM, RagnerBG said:
If i understand right, you only need xorg (apt-get install xorg), without anything else. Additionally you can install - Mali binary driver for framebuffer and fbturbo.
Please do not recommend following outdated LeMaker instructions when using Armbian. With the desktop images (at least for sunxi: A10/A20 or H3) we're already shipping with all this stuff enabled. So choosing/building a desktop image is the way to go. Our desktop images boot into the user account that was created on installation and that's already 'just xorg' without a whole desktop environment.
At least one of our devs is working on re-packaging this stuff so you would get both CedarX and GPU acceleration also when upgrading one of our 'server' images to a desktop image sometimes in the future.
And then it depends on the needs. I had one time the requirement to display status informations and used Iceweasel in kiosk mode for this (IIRC). Now I would give pygame a try...
I fixed that in the meantime and tested whether all this HW acceleration works with a desktop Armbian build: https://github.com/igorpecovnik/lib/pull/225
It does, just tested the image (made for Pro but automagically detecting that it runs on Banana Pi instead on first boot:
 ____                                  ____  _
| __ )  __ _ _ __   __ _ _ __   __ _  |  _ \(_)
|  _ \ / _` | '_ \ / _` | '_ \ / _` | | |_) | |
| |_) | (_| | | | | (_| | | | | (_| | |  __/| |
|____/ \__,_|_| |_|\__,_|_| |_|\__,_| |_|   |_|
Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.110-sun7i
System load:   0.03            Up time:       12 min
Memory usage:  17 % of 872Mb  IP:            192.168.83.44
CPU temp:      48°C
Usage of /:    30% of 7.3G   storage/:      24% of 466G
[ 12 updates to install: apt-get upgrade ]
tk@bananapi:~$ ls -al /boot/script.bin
lrwxrwxrwx 1 root root 22 Mar 12 22:16 /boot/script.bin -> /boot/bin/bananapi.bin
Close to unbelievable but I'm watching now a 1080p/H.264 movie on this little board :)
In case anyone wants to give it a try here's a preliminary build for A20.
What player you using ?
The preinstalled mpv of course. I simply doubleclicked on a movie file and this one opened.
Im looking forward to the day we can do this on an OrangePiOne... roll on the mainline kernerl support...
