inos Posted September 18, 2018 Share Posted September 18, 2018 it seems that the kernel-header version is not updated to the actual kernel version: $ uname -a Linux cubietruck 4.14.65-sunxi #11 SMP Tue Aug 21 10:02:12 CEST 2018 armv7l GNU/Linux install header using armbian-config tool doesn't work - no error message thereafter: installed header manually: linux-headers-next-sunxi dpkg: warning: version '4.14.18-sunxi 4.14.65' has bad syntax: invalid character in revision number Building for 4.14.65-sunxi Module build for kernel 4.14.65-sunxi was skipped since the kernel headers for this kernel does not seem to be installed. Link to comment Share on other sites More sharing options...
Igor Posted September 18, 2018 Share Posted September 18, 2018 24 minutes ago, inos said: is not updated True. Will be fixed upon next upgrade which I am working virtually round the clock. In case you can wait, use nightly automated build. It should work and it should be safe on this board. Link to comment Share on other sites More sharing options...
inos Posted September 18, 2018 Author Share Posted September 18, 2018 Thank's for the quick reply! I'll try the nightly build but it's not time-critical so don't rush! Link to comment Share on other sites More sharing options...
Igor Posted September 20, 2018 Share Posted September 20, 2018 On 9/18/2018 at 7:07 PM, inos said: Thank's for the quick reply! I'll try the nightly build but it's not time-critical so don't rush! Now this must work on a stable build. Link to comment Share on other sites More sharing options...
inos Posted September 24, 2018 Author Share Posted September 24, 2018 yes it works - thank you very much!!! Link to comment Share on other sites More sharing options...
