I have tried to use the nand-sata-install to allow me to boot the roots from an external USB HDD. It goes through the process but after rebooting, the "loading kernel" message appears and then nothing - I have tried this a few times and even used the latest version of the script on GitHub.
Any ideas on how to make this work - I have a external USB HDD (500mB).
Can you provide a boot log and boot script /boot/boot.cmd to see what went wrong?
as a noob - I don't know how to do this since it does not come up after than changes....must I insert SD into another system and where would I find them ?
Original boot.cmd:
setenv bootargs "console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup-enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=1"
after nand-sata-install - (before reboot)
root@bananapim2:/boot# cat boot.cmd
setenv bootargs "console=tty1 root=/dev/sda1 rootwait rootfstype=ext4 cgroup-enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=1"
After reboot red light goes off, display clears, UDB HDD led comes on and then nothing else shows on display.
