I've tried to the best of my abilities, but it seems that the current Bionic image does not support the K1 Plus wifi?
Is that correct? In armbian-config there is no option to setup wireless and I cannot get the board to recognise a wlan0 device by changing the interfaces configurtation..
Is there some trick?
The trick is that you need to supply logs when asking such questions. Always.
Type:
armbianmonitor -u
Edit: It seems that we have a problem with wifi on kernel 4.14.y. Update image and switch to DEV kernel (4.18.y) within armbian-config and wireless will work.
