renard Posted October 26, 2018 Posted October 26, 2018 After update to Armbian 5.60 (Debian 9) hostapd became unable to start. ``` # /usr/sbin/hostapd -B -P /run/hostapd.pid /etc/hostapd/hostapd.conf.orig -dd random: Trying to read entropy from /dev/random Configuration file: /etc/hostapd/hostapd.conf.orig ctrl_interface_group=0 nl80211: Supported cipher 00-0f-ac:1 nl80211: Supported cipher 00-0f-ac:5 nl80211: Supported cipher 00-0f-ac:2 nl80211: Supported cipher 00-0f-ac:4 nl80211: Supported cipher 00-0f-ac:6 nl80211: Using driver-based off-channel TX nl80211: interface wlan0 in phy phy0 nl80211: Set mode ifindex 3 iftype 3 (AP) nl80211: Failed to set interface 3 to mode 3: -1 (Operation not permitted) nl80211: Try mode change after setting interface down nl80211: Set mode ifindex 3 iftype 3 (AP) nl80211: Failed to set interface 3 to mode 3: -1 (Operation not permitted) Could not set interface wlan0 flags (UP): Operation not permitted nl80211: Failed to set interface up after switching mode nl80211: Interface mode change to 3 from 0 failed nl80211: Could not configure driver mode nl80211: deinit ifname=wlan0 disabled_11b_rates=0 nl80211: Remove monitor interface: refcount=0 netlink: Operstate: ifindex=3 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP) nl80211: Set mode ifindex 3 iftype 2 (STATION) nl80211 driver initialization failed. hostapd_interface_deinit_free(0xaaaac3834970) hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1 hostapd_interface_deinit(0xaaaac3834970) wlan0: interface state UNINITIALIZED->DISABLED hostapd_bss_deinit: deinit bss wlan0 wlan0: AP-DISABLED hostapd_cleanup(hapd=0xaaaac3835c20 (wlan0)) hostapd_free_hapd_data: Interface wlan0 wasn't started hostapd_interface_deinit_free: driver=(nil) drv_priv=(nil) -> hapd_deinit hostapd_interface_free(0xaaaac3834970) hostapd_interface_free: free hapd 0xaaaac3835c20 hostapd_cleanup_iface(0xaaaac3834970) hostapd_cleanup_iface_partial(0xaaaac3834970) hostapd_cleanup_iface: free iface=0xaaaac3834970 ``` ``` # cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepiprime BOARD_NAME="Orange Pi Prime" BOARDFAMILY=sun50iw2 VERSION=5.60 LINUXFAMILY=sunxi64 BRANCH=next ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image # cat /etc/debian_version 9.5 # uname -a Linux mxopipr01 4.14.70-sunxi64 #274 SMP Wed Sep 19 12:09:30 CEST 2018 aarch64 GNU/Linux ``` ``` # whoami root # iwconfig wlan0 mode master Error for wireless request "Set Mode" (8B06) : SET failed on device wlan0 ; Operation not permitted. ``` ``` # iw list Wiphy phy0 max # scan SSIDs: 9 max scan IEs length: 2304 bytes max # sched scan SSIDs: 0 max # match sets: 0 max # scan plans: 1 max scan plan interval: -1 max scan plan iterations: 0 Retry short limit: 7 Retry long limit: 4 Coverage class: 0 (up to 0m) Supported Ciphers: * WEP40 (00-0f-ac:1) * WEP104 (00-0f-ac:5) * TKIP (00-0f-ac:2) * CCMP-128 (00-0f-ac:4) * CMAC (00-0f-ac:6) Available Antennas: TX 0 RX 0 Supported interface modes: * IBSS * managed * AP * monitor Band 1: Bitrates (non-HT): * 1.0 Mbps * 2.0 Mbps * 5.5 Mbps * 11.0 Mbps * 6.0 Mbps * 9.0 Mbps * 12.0 Mbps * 18.0 Mbps * 24.0 Mbps * 36.0 Mbps * 48.0 Mbps * 54.0 Mbps Frequencies: * 2412 MHz [1] (20.0 dBm) * 2417 MHz [2] (20.0 dBm) * 2422 MHz [3] (20.0 dBm) * 2427 MHz [4] (20.0 dBm) * 2432 MHz [5] (20.0 dBm) * 2437 MHz [6] (20.0 dBm) * 2442 MHz [7] (20.0 dBm) * 2447 MHz [8] (20.0 dBm) * 2452 MHz [9] (20.0 dBm) * 2457 MHz [10] (20.0 dBm) * 2462 MHz [11] (20.0 dBm) * 2467 MHz [12] (20.0 dBm) (no IR) * 2472 MHz [13] (20.0 dBm) (no IR) * 2484 MHz [14] (20.0 dBm) (no IR) Supported commands: * new_interface * set_interface * new_key * start_ap * new_station * set_bss * join_ibss * set_pmksa * del_pmksa * flush_pmksa * frame * set_channel * connect * disconnect Supported TX frame types: * IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 Supported RX frame types: * IBSS: 0xd0 * managed: 0x40 0xd0 * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0 * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0 * P2P-client: 0x40 0xd0 * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0 WoWLAN support: * wake up on anything (device continues operating normally) software interface modes (can always be added): * monitor interface combinations are not supported Device supports scan flush. ``` Also have lots of this logs ``` # dmesg -T | tail -n 3 [Fri Oct 26 14:47:45 2018] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin [Fri Oct 26 14:47:45 2018] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin [Fri Oct 26 14:47:46 2018] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin # ll /lib/firmware/rtlwifi/ total 856 drwxrwxr-x 2 root root 4096 Oct 25 17:47 ./ drwxrwxr-x 19 root root 4096 Oct 25 17:47 ../ -rw-rw-r-- 1 root root 11216 Sep 19 08:07 rtl8188efw.bin -rw-rw-r-- 1 root root 13904 Sep 19 08:07 rtl8188eufw.bin -rw-rw-r-- 1 root root 16192 Sep 19 08:07 rtl8192cfw.bin -rw-rw-r-- 1 root root 14818 Sep 19 08:07 rtl8192cfwU.bin -rw-rw-r-- 1 root root 16332 Sep 19 08:07 rtl8192cfwU_B.bin -rw-rw-r-- 1 root root 16014 Sep 19 08:07 rtl8192cufw.bin -rw-rw-r-- 1 root root 16116 Sep 19 08:07 rtl8192cufw_A.bin -rw-rw-r-- 1 root root 16096 Sep 19 08:07 rtl8192cufw_B.bin -rw-rw-r-- 1 root root 16116 Sep 19 08:07 rtl8192cufw_TMSC.bin -rw-rw-r-- 1 root root 31376 Sep 19 08:07 rtl8192defw.bin -rw-rw-r-- 1 root root 31818 Sep 19 08:07 rtl8192eefw.bin -rw-rw-r-- 1 root root 25264 Sep 19 08:07 rtl8192eu_ap_wowlan.bin -rw-rw-r-- 1 root root 31818 Sep 19 08:07 rtl8192eu_nic.bin -rw-rw-r-- 1 root root 25878 Sep 19 08:07 rtl8192eu_wowlan.bin -rw-rw-r-- 1 root root 80208 Sep 19 08:07 rtl8192sefw.bin -rw-rw-r-- 1 root root 122328 Sep 19 08:07 rtl8712u.bin -rw-rw-r-- 1 root root 22172 Sep 19 08:07 rtl8723aufw_A.bin -rw-rw-r-- 1 root root 24118 Sep 19 08:07 rtl8723aufw_B.bin -rw-rw-r-- 1 root root 19200 Sep 19 08:07 rtl8723aufw_B_NoBT.bin -rw-rw-r-- 1 root root 30746 Sep 19 08:07 rtl8723befw.bin -rw-rw-r-- 1 root root 20886 Sep 19 08:07 rtl8723bs_ap_wowlan.bin -rw-rw-r-- 1 root root 32108 Sep 19 08:07 rtl8723bs_nic.bin -rw-rw-r-- 1 root root 26398 Sep 19 08:07 rtl8723bs_wowlan.bin -rw-rw-r-- 1 root root 20886 Sep 19 08:07 rtl8723bu_ap_wowlan.bin -rw-rw-r-- 1 root root 32108 Sep 19 08:07 rtl8723bu_nic.bin -rw-rw-r-- 1 root root 26398 Sep 19 08:07 rtl8723bu_wowlan.bin -rw-rw-r-- 1 root root 11662 Sep 19 08:07 rtl8723fw.bin -rw-rw-r-- 1 root root 22996 Sep 19 08:07 rtl8723fw_B.bin -rw-rw-r-- 1 root root 28984 Sep 19 08:07 rtl8821aefw.bin -rw-rw-r-- 1 root root 19858 Sep 19 08:07 rtl8821aefw_wowlan.bin ``` No ideas yet. Thanks in advance!
Igor Posted October 26, 2018 Posted October 26, 2018 I did a quick test to confirm there is nothing wrong on our side. 1. Download latest Debian Stretch, setup AP within armbian-config, test AP with a phone, ... 2. Upgrade to latest Nightly packages and test AP. Working fine. If you use some manual operations, you have to know exactly what you are doing. Logs: http://ix.io/1q6A 1
renard Posted October 30, 2018 Author Posted October 30, 2018 Hm... Just flashed fresh clean armbian 5.59 into sd with default configuration. It worked there. Then rebooted to my old sd with 5.60, and it magically started working in 5.60 with my old configuration. Yet I am 100% sure that I made several reboots with 5.60 already without any changes before. Maybe some hardware issue (or firmware "loading" issue). As we see below it is only one attempt to "acquire FW from file:rtlwifi/rtl8723bs_nic.bin" as opposed to lots of them before. Thanks for your attempts to help, and sorry for your time for checking. ``` # dmesg -T | grep -i rtl8723bs [Tue Oct 30 13:01:27 2018] RTL8723BS: module init start [Tue Oct 30 13:01:27 2018] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40 [Tue Oct 30 13:01:27 2018] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40 [Tue Oct 30 13:01:27 2018] RTL8723BS: rtw_ndev_init(wlan0) [Tue Oct 30 13:01:27 2018] RTL8723BS: module init ret =0 [Tue Oct 30 13:01:34 2018] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin [Tue Oct 30 13:01:38 2018] RTL8723BS: rtw_cmd_thread(wlan0) pcmd->sctx [Tue Oct 30 13:01:38 2018] RTL8723BS: assoc success [Tue Oct 30 13:01:38 2018] RTL8723BS: set group key camid:1, addr:00:00:00:00:00:00, kid:1, type:AES [Tue Oct 30 13:01:41 2018] RTL8723BS: set group key camid:1, addr:00:00:00:00:00:00, kid:1, type:AES [Tue Oct 30 13:01:41 2018] RTL8723BS: send eapol packet [Tue Oct 30 13:01:41 2018] RTL8723BS: send eapol packet [Tue Oct 30 13:01:41 2018] RTL8723BS: set pairwise key camid:4, addr:3c:05:18:8c:eb:03, kid:0, type:AES [Tue Oct 30 13:02:00 2018] RTL8723BS: send eapol packet [Tue Oct 30 13:02:00 2018] RTL8723BS: send eapol packet [Tue Oct 30 13:02:00 2018] RTL8723BS: set pairwise key camid:5, addr:58:c5:cb:1e:f3:a3, kid:0, type:AES [Tue Oct 30 13:11:38 2018] RTL8723BS: send eapol packet [Tue Oct 30 13:11:38 2018] RTL8723BS: send eapol packet [Tue Oct 30 13:11:38 2018] RTL8723BS: set group key camid:2, addr:00:00:00:00:00:00, kid:2, type:AES ```
