constantius Posted October 30, 2018 Posted October 30, 2018 Your build Armbian 5.65 kernel 4.4 and my build 5.65 the same kernel - system has sound only via HDMI monitor. Is it possible to enabled audio via 3.5 jack or external USB sound card?
NicoD Posted October 30, 2018 Posted October 30, 2018 Have you tried with pulseaudio? I'll start my Rock64 to check.
NicoD Posted October 30, 2018 Posted October 30, 2018 Indeed. The 3.5 mm jack doesn't work. I've tried 2 different usb sound cards. Both work fine.
constantius Posted October 31, 2018 Author Posted October 31, 2018 https://botland.com.pl/akcesoria-odroid/6537-konwerter-usb-audio-jack-karta-dzwiekowa-do-odroid.html I have only one sound card. It works with other SBC i have. Rock64 Ubuntu bionic kernel 4.4 does not recognize it.
NicoD Posted October 31, 2018 Posted October 31, 2018 On 10/31/2018 at 7:28 AM, constantius said: https://botland.com.pl/akcesoria-odroid/6537-konwerter-usb-audio-jack-karta-dzwiekowa-do-odroid.html Expand I`ve got exactly the same adapter and it works immediatly here. Armbian Bionic kernel 4.4.162-rockchip. Are you using the volume control? Here it finds the adapter and puts the sound thru the moment I connect. 2
