armremote Posted November 3, 2018 Posted November 3, 2018 (edited) Hi, I've been building nanopineoplus2 stretch images with armbian build on commit c3f02be362aa216f2d3ee011916f9a18baf58291 (August 4, 2018) and it worked fine until earlier this week. My last successful build was on 10/28/2018. Could this be failing because armbian-firmware 5.55 or some older packages were taken off the apt repo? Here is the log output: [[0;32m o.k. [0m] Installing packages for [[0;33m Armbian [0m] Reading package lists... Building dependency tree... Reading state information... [[0;31m error [0m] ERROR in function create_rootfs_cache [[0;33m debootstrap-ng.sh:213 [0m] [[0;31m error [0m] Installation of Armbian packages failed [[0;32m o.k. [0m] Process terminated [[0;31m error [0m] ERROR in function unmount_on_exit [[0;33m image-helpers.sh:59 [0m] [[0;31m error [0m] debootstrap-ng was interrupted [[0;32m o.k. [0m] Process terminated Thank you. Edited November 3, 2018 by armremote
Igor Posted November 3, 2018 Posted November 3, 2018 Nothing has been taken from the repository. Screen output tells only the obvious - that there is something wrong. Look into debug directory. 10 hours ago, armremote said: c3f02be362aa216f2d3ee011916f9a18baf58291 You are on your own when you detach from HEAD. Armbian rootfs with stock configuration was successfully bootstrapped yesterday in all possible combinations: https://dl.armbian.com/_rootfs/
